go_a_way1
Old 06-09-2013, 12:30 AM   #1485
onthemove
Drives: ...
Originally Posted by ill86 View Post
Rear is okay.
Be careful with front tire size up front. (Inner clearance) 235 will fit, 245 will be close.
Can ya give me anymore info then that?
Am I gonna get anymore clearance in the front with 17x8+45 instead of 17x9+35, or is it not worth the hassle and shall I run 17x9+35 square?
onthemove is offline   Reply With Quote
Old 06-09-2013, 12:32 AM   #1486
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
wouldn't want +45 17x8's up front, can you get 17x8 +35 up front?
Old 06-09-2013, 12:34 AM   #1487
onthemove
Drives: ...
Tire rack only has the +45 offset so I'm not sure... with some more searching around I could probably find something
Old 06-09-2013, 12:59 AM   #1488
onthemove
Drives: ...
just found this link: http://www.ft86club.com/forums/showthread.php?t=10257
seems like 17x8+45 wl be ok for the front...
Old 06-09-2013, 01:08 AM   #1489
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Yes. 3mm. However, 9" +35 sticks out 23mm more. A noticeable difference.
That is your riddle. Not mine. :-)
Different handling characteristics square to stagger. Plus tire rotations to consider.
Your choice, bro.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-09-2013, 01:10 AM   #1490
ill86
ill86's Avatar
Drives: iG FR-S
Yep, just limits your tire width. He didn't say it wouldn't fit. :-)
I would rather have a 8" +35 than a +45. But that's just me. (And JB lol)
The Following User Says Thank You to ill86 For This Useful Post:
JoeBoxer (06-09-2013)
Old 06-09-2013, 01:11 AM   #1491
ill86
ill86's Avatar
Drives: iG FR-S
@onthemove, where in PA are you? I am on the western side if you need help.
Old 06-09-2013, 01:17 AM   #1492
onthemove
Drives: ...
im on the east side unfortunatly, but thanks!
Old 06-09-2013, 05:50 PM   #1493
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
Spacers?
I'm here to help also guys better to ask than end up with less than ideal fitment.
What adjustment or changes is needed to make this fitment ok?
Scion FRS dropped by Tein S Springs - website states 1.3 for front / 1.1 for rear
Stock struts/ shocks
Enkie Kojin wheels 18 x 9.5 square set up.
Tires are Yokohama 255x35 18
I have read that spacers would be needed for the front end to clear the struts.
How much is needed to make this work ?
Side note : car is mainly for daily driving only.
Thanks in advance
j2digit is offline   Reply With Quote
Old 06-09-2013, 06:46 PM   #1494
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Thanks in advance
You didn't specify what the offset is, but I'd say you'd probably need a net of +30 or lower. So just take your wheel offset and subtract 30 to get min spacer thickness needed.
If you're using camber bolts, these will change the distance to the perch. Using a bolt in the lower hole gives just a smidge more clearance as opposed to using the top hole. Probaby just a couple of mm, but that can make all the difference.
I'm going off of fitment of my 17x8s (+48) with 225. Tire is almost rubbing the perch, but with an 18, I think the rim itself will be in that area.
Where am I getting the +30 from?
http://forums.nasioc.com/forums/show....php?t=2421193
These guys are running 18x9.5 +30 with 265s, originally this was on stock suspension and camber bolts in the lower holes, then they went to lowering springs (MachV ~1"). They said they had minimal rubbing, which I think was fixed with more negative camber.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
j2digit (06-10-2013)
Old 06-10-2013, 01:48 AM   #1495
j2digit
j2digit's Avatar
i believe the offset is 45 , thanks again
Old 06-10-2013, 02:22 AM   #1496
Verge
Verge's Avatar
Drives: 2013 Scion FRS
does anyone know if WORK Kiwami CR Ultimate 5x100 18x9.5 +38 will fit on stock suspension? i wont be getting coilovers for at least 6 months so need to find out if stock suspension will work.
Verge is offline   Reply With Quote
Old 06-10-2013, 07:26 AM   #1497
jshadeck
jshadeck's Avatar
Yes. (Please read back through this thread, this fitment has been discussed a number of times as to how it clears, but just. This is my current setup as well)
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
Verge (06-10-2013)
Old 06-10-2013, 01:24 PM   #1498
Verge
Verge's Avatar
do you have any pics so i can see how they fill out??
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
