Old 06-06-2013, 12:30 PM   #1
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
So my key FOB was put in the washing machine....
...And it surprisingly still works perfectly. Happened a couple weeks ago, left them in my jeans and passed them through the wash cycle. I have the actual key with fob, not the keyless entry fob.
glad to see something was made to last!
Kayzer Soze is offline   Reply With Quote
Old 06-06-2013, 12:41 PM   #2
ST185RC
Drives: White Out FR-S
That's nothing, I took a dip into the hot springs full of minerals, salts and other savoury flavours, forgetting that I had my key in my trunks after I grabbed my flipflops from my car. Still works like a champ.
ST185RC is offline   Reply With Quote
Old 06-06-2013, 01:55 PM   #3
Shaun.
Drives: '13 Silver BRZ Limited MT
Electronics aren't inherently damaged by water—it's the short-circuiting that happens when power is applied that does the damage.
Shaun. is offline   Reply With Quote
Old 06-06-2013, 02:16 PM   #4
DeeezNuuuts83
Drives: 2006 Evo IX SE
What if you drop an iPhone (or another smartphone) already turned off into water, then turn it back on only after everything has dried?
DeeezNuuuts83 is offline   Reply With Quote
Old 06-06-2013, 02:17 PM   #5
gily25
Drives: Silica BRZ 6MT
Ditto...if they get spoiled ziplocking them with some white rice or a bowl of rubbing alcohol will usually dry up the water. I've learned a lot about drying water out of electronics by owning a Jeep
gily25 is offline   Reply With Quote
Old 06-06-2013, 02:18 PM   #6
DeeezNuuuts83
Did you just put your Jeep in a big pool of rice?
Old 06-06-2013, 02:19 PM   #7
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
As long as it didn't corrode it should be fine.
BlueSTaR is offline   Reply With Quote
Old 06-06-2013, 02:41 PM   #8
#87
I usually post drunk
#87's Avatar
No he went to the local herrafrush meet
wait wut
#87 is offline   Reply With Quote
The Following 6 Users Say Thank You to #87 For This Useful Post:
BRZNutt (06-06-2013), DeeezNuuuts83 (06-06-2013), King Tut (06-07-2013), meWant (06-06-2013), OrbitalEllipses (06-06-2013), shirker (06-06-2013)
Old 06-06-2013, 02:43 PM   #9
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
The fobs and keyless fob have a rubber gasket that seals the actual electronics when the two halves are clicked together. I've taken mine apart a few times, just messing around mostly. On another note, it would be soooo easy for apple to spray there electronics with a water resistant coating like some R/C electronics are. My R/C truck is water proof! And with the brushless technology now being dominant they are also becoming quite water resistant if not completely water proof too.
Gords_zenith is offline   Reply With Quote
Old 06-06-2013, 02:44 PM   #10
DeeezNuuuts83
That would take away from the incentive to buy AppleCare
The Following User Says Thank You to DeeezNuuuts83 For This Useful Post:
Squishy86 (06-07-2013)
Old 06-06-2013, 09:52 PM   #11
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
It will corrode.
Ganthrithor is offline   Reply With Quote
Old 06-07-2013, 11:43 AM   #12
chandz05
chandz05's Avatar
Drives: CBS BRZ limited MT
Also, correct me if I'm wrong because my last chemistry class was 5 years ago, but I'm pretty sure pure water is NOT conductive, but rather the salts/impurities etc found in water actually carries the current. I think pure, de-ionized water can be used to rinse of electronics safely. I think.
chandz05 is offline   Reply With Quote
Ryeong86's Ultramarine SOLO Machine Ryeong86 Member's Car Journals 0 04-26-2013 04:19 PM
Local machine shop (NoVA/DC/MD)? swift996 Mid-Atlantic 2 03-28-2013 07:34 AM
FR-S TIME MACHINE - THOUGHTS? Davyator Scion FR-S / Toyota 86 GT86 General Forum 26 07-20-2012 12:32 PM
AMT machine shop, sti brakes mounted. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-20-2012 08:08 PM
ESBJIUJITSU's FRS DD GRIP MACHINE WISH LIST ESBjiujitsu Member's Car Journals 8 05-16-2012 11:41 AM
