Old 05-16-2012, 12:33 AM   #1
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
ESBJIUJITSU's FRS DD GRIP MACHINE WISH LIST
Now obviously I wont start off with all of this, but I hope to build to this. I have been looking for a platform just like the brz/frs for a while and I plan big things off of it. The items with a star by them will be mods done asap! My main focus is on grip mountain driving and hill climbs. Feel free to let me know what you think.
I train jiu jitsu late and come home full of energy so I put my energy to work so why not post it ENJOY and remember this is just my personal vision of my frs. I know a lot of people wont like the aero styling or my
tuning choices but thats to be expected. Im just simply laying out my plan to draw out opinions to help me
question what im looking for, so all comments are welcome. Thanks! I hope to turn this into an ever evolving check list once i actually purchase the car
Whiteout Manual FRS
Wheel/Tire-
* Dezod Motorsports Custom Enkei RPF1-5x100 17x9 +35 F1 Silver 17.4lbs
* 245/40R17 Cooper Zeon RS3-S Tires
Aero-
* Carbon Fiber Front diffuser w/ supports
* APR Carbon fiber Canards
* APR Carbon fiber GT3 Mirrors w/ blue tint
Carbon Fiber Side Diffusers
* carbon fiber Tommykaira wing
carbon fiber fender insert w/ vent
* Vented stock hood w/ custom intake induction system
Acrylic Window w/ vent
Full under body covers
carbon Roof Replacement
Rain Guards
Engine-
* HKS GT Supercharger Kit
* F-Con Emanage
* Cusco Street Oil Catch Can
Lightened Crank Pully
Lightened Flywheel
Header
High Flow Cat
* exhaust w/ turn downs
Interior-
Push Button Start
* Cusco D1 Chromoly Roll cage
* Sparco Tuner Harness - 4-Point Bolt-In
Short Shifter
2.5in Shift lever Extender
* Weighted Shift Knob
* Custom Carbon Fiber bezels
* Boost gauge w/carbon cage mounted cups
Temp Gauges
* Lower Dash and below full gutted and cleaned
Clarion Mirage touch screen app head unit
TRD Door stabilizers
AC Ducting replacement / rerouting
Suspension-
* Coil over SEtup
Adjustable Pillow ball upper mount
WRX 18mm Rear Sway Bar
Race replacement bushings
Brakes-
EBC Black slotted rotors
* EBC Red Stuff Brake Pads
Steal Braided Brake Lines
Custom Brake ducting
PS if any Photoshop wizaers want to make my dream a reality feel free otherwise im slowly working on attempting to learn to photoshop but it may be a while
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-16-2012, 12:41 AM   #2
#87
I usually post drunk
#87's Avatar
I will be interested in this build as I want to do several of the things you listed here.
Quick question, what make you choose 245/45 over 245/40?
#87 is offline   Reply With Quote
Old 05-16-2012, 08:12 AM   #3
ESBjiujitsu
not available in the tires i would like to run they have 235/35 also. I would assume the tire width would be smaller though with that setup. And thanks. Ill keep updating my list and also updating when I get the car and which upgrades i actually complete. i may end up numbering them in order at some point. Anything to keep my idle mind moving until I can purchase the frs I cant wait to get some renderings done. Maybe ill offer someone some $ here to make something up for me. Any takers???
Old 05-16-2012, 08:24 AM   #4
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Hey ESB. I also like listing out future mods
As for your tires 245/45 is going to be a full 26mm/1.1 inches taller than stock. There are plenty of tire options out there at 245/40 which are only 2mm taller than stock and would probably be a better option.
Last edited by MattR; 05-16-2012 at 08:25 AM. Reason: Clarified stock tire size as basis for statement.
MattR is offline   Reply With Quote
Old 05-16-2012, 08:44 AM   #5
ESBjiujitsu
also please if anyone has any other suggestions that would prove useful in my grip bias setup please let me know. and yes i plan on DDing this car, so i will keep Ac and heat but will take out all the original ducting and replace it with lite weight material and a much more direct and simple setup. Also I will gut from the btm of the lower dash paneling down. Will remove all sound dampening material and will clean and repaint the metal if necessary. I will then add new patches of rubber grip material in the particular spots where my feet and the passengers feet would rest on the bare metal floor board. I will remove the back seats clean up all wiring and again remove all waste and clean. Radio and speakers will remain. I love music Im hoping even with the addition of the roll cage between the rims, carbon fiber parts, and gutting that i can still lower the over all weight a bit and maintain at least 250hp. So long as i have all the grip i need, I see it being a very thrilling mountain car and DD
Old 05-16-2012, 09:19 AM   #6
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
Serious question: how do you make ducting lighter than the flimsy plastic that it already is? And when you say clean up wiring do you mean re-run and hide wiring?
Cheers.
PS. I'm liking the build! I have some similar ideas myself but maybe not so hardcore
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 05-16-2012, 10:04 AM   #7
ESBjiujitsu
Cheers.
I will remove all the plastic ducting and hardware and replace with something similar to this http://www.flexfab.com/Products/Aero...ting/ultra.htm and just simplify. YOu only need one split to shot two directions up top and two down at your feet. Much more simple and stream line and no hardware needed just drop the ducting and zip tie to near by dash bracket, and keep under the dash so its not visible.
As far as the wiring goes yes and no. I have found a great way to wide wire is vinyl film with psa backing. Just bundle wires and cover with strips of the material. You can usually not even see were the wires are run. Obviously if you can tuck and hide wires thats easy as well. I just want the interior to look as seamless as possible as to look fresh from the factory, but still gutted and race inspired. I love that feeling of being in a race car.
Old 05-16-2012, 11:30 AM   #8
Turbowned
Turbowned's Avatar
Cool! Thanks for posting the link to that ducting. I now know what to run for brake cooling ducts!
Old 05-16-2012, 11:41 AM   #9
ESBjiujitsu
no problem i run the same for brake cooling. Guess i need to update my list .... hahahaha thank you!
one more car list... Axel Off-Topic Lounge [WARNING: NO POLITICS] 20 12-18-2013 06:17 AM
2012 MAX ORIDO D1GP NEW MACHINE TOYOTA V8 86 SHAKEDOWN jdmEGO FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 03-31-2012 11:46 AM
The grip dilemma - tires swift996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 03-23-2012 11:35 PM
$500 Deposit = First on List IntenseDVDA BRZ First-Gen (2012+) — General Topics 373 02-21-2012 04:44 PM
more grip? aesthetect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 12-19-2011 10:51 PM
