Old 06-12-2012, 09:47 PM   #1
adamturbo
Drives: mitsubishi evo 9
AMT machine shop, sti brakes mounted.
So working on a customers car and we fitted sti calipers and rotors on his car. very simple. The rotors needed redrilling to 5x 100, the calipers bolted right on. then all we need is a 15 mm or maybee slightly thicker wheel spacer for the factory wheels to clear the caliper. ARP lexus IS 300 extended studs fit perfectly, you will need to change to 12 x 1.5 wheel nuts though. these will be cleaned up before final install but you get the idea.
adamturbo is offline   Reply With Quote
The Following User Says Thank You to adamturbo For This Useful Post:
Metabrz (06-20-2012)
Old 06-12-2012, 10:14 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Change the bleeder over or do you have the differential pistons backwards?
It's been known for months they "fit". You could have also just used 2004 STi rotors without redrilling them.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-20-2012, 01:08 AM   #3
ZILLA
BRZ #575
ZILLA's Avatar
Drives: 2013 BRZ #575
LoL!
ZILLA
BRZ #575 SWP Limited
18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video]
ZILLA is offline   Reply With Quote
Old 06-20-2012, 03:32 AM   #4
adamturbo
it was what the customer supplied for goodness sakes!!!. Yes the bleeders have been switched over so the pistons are in the correct orientation.
Old 06-20-2012, 02:53 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
How difficult is it to switch the bleeders? Simply drill, tap. install, and cap the other side?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-20-2012, 08:08 PM   #6
adamturbo
there are threaded allen head plugs they are in there nice and tight if you try to just crack them loose you WILL round the head out . you need to heat up the caliper right were the plugs are and use a fair load on the allen key while you are heating. The plug will crack loose . only use as much heat as needed to crack them loose you dont want to overheaten the calipers. this WILL burn the clearcoat off the area . other than that just flip the bleeders to the other side and reinstall the plugs.
civicdrivr (06-21-2012)
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
ESBJIUJITSU's FRS DD GRIP MACHINE WISH LIST ESBjiujitsu Member's Car Journals 8 05-16-2012 11:41 AM
2012 MAX ORIDO D1GP NEW MACHINE TOYOTA V8 86 SHAKEDOWN jdmEGO FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 03-31-2012 11:46 AM
Photo Proof: Scion FR-S loaded with 4 mounted wheels and track tools ahausheer FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 74 02-17-2012 06:18 PM
Legacy low-mounted turbo oil pump aspera Engine, Exhaust, Transmission 0 06-16-2010 03:41 PM
