Old 06-05-2013, 07:11 PM   #1
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Strange noise at 2500 RPM
I'm getting a strange grinding noise noise everytime I pass 2500RPM in any gear, is anyone else having an issue like this? it only happens between 2500-2600 RPM.
current mods are uel headers, full header back, perrin drop in and tune.
Build Thread
Instagram
Old 06-05-2013, 07:17 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Video would help
Old 06-05-2013, 07:35 PM   #3
sw20kosh
Drives: 2013 Black FR-S
Sounds like you have an exhaust frequency at that RPM that is vibrating something like a heat shield or a loose bolt or etc. It is probably the exhaust considering that is what you changed out.
Old 06-06-2013, 01:05 AM   #4
troek
troek's Avatar
Drives: 2012 Toyota 86
thats my guess as well. alot of people have had a problem with the heat shield over the stock muffler area.
troek is offline   Reply With Quote
Old 06-06-2013, 04:49 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm going to agree with these other genius's here. I am pretty sure it has to do with the exhaust system upgrade (a video or sound clip would help by the way). A lot of people complained about squeaks and grinds after full exhaust or catback exhaust upgrades, meaning something can take the extra vibrations or noise and just decides to rattle away. Also does this happen at a stand still in neutral? it could help you to diagnose the location of the rattle/grind. I wouldn't doubt there's a fix on here somewhere because you are not the only person with this issue. Also where exactly does the sound emanate from?
everyone on here will be sure to help you out
Old 06-07-2013, 07:40 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
maybe a rattle, but i've never heard an exhaust cause anything close to what I would describe as a "grind" like OP described.
Old 06-07-2013, 08:58 AM   #7
troek
troek's Avatar
ive heard a very distinct grinding noise caused by some exhausts and the oem heat shield over the muffler. theres a youtube video of it somewhere, but im having trouble finding it.
edit: found it.
[ame="http://www.youtube.com/watch?v=cujLV7coC1I"]frs j2 exhaust quad tip - YouTube[/ame]
Old 06-07-2013, 09:01 AM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
I sometimes hear a metal rattle/grind on my car (all stock) at around 1.5-2k on lower gears, but I thought maybe i'm just lugging the engine and just shift at a higher RPM now.
TM is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Strange Tapping noise from under car after use rhood168 Issues | Warranty | Recalls / TSB 10 02-12-2013 02:16 AM
Strange noise at 2k RPMs Cajun Issues | Warranty | Recalls / TSB 3 11-29-2012 10:30 PM
BRZ/FRS automatic owners ... Strange noise Delacruzmd Issues | Warranty | Recalls / TSB 6 10-16-2012 07:16 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
