Old 06-05-2013, 12:50 PM   #15
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by FM Wheels View Post
5. Applied properly plastidip looks just like powdercoating
6. Powdercoat adds weight.
5. Not even close. I've used plasti-dip on several trim pieces so I'm familiar with the application and I know it has its place. But it is not a glossy, durable finish. It's rubber and has a textured look.
6. So does plasti-dip. And paint. And brake dust. Saving weight would be replacing the heavy stock wheels. Powdercoated wheels won't slow the car down any amount that you could notice.
Originally Posted by Chimpo View Post
Why not use wheel paint? I've used a few different duplicolor colors with great results, and they last a lot longer than a few months. I've done multiple sets that have been on the road for years and they still look fine.
^This. I've done the same. The only issue I had was not letting the paint cure long enough before getting tires mounted, so there were some scores on the paint. A few days would have made all the difference. Still looked great, though. Love that Duplicolor bronze wheel paint. Lay a bunch of clear over the paint and you've got a damn nice finish for the cost of one powdercoated wheel.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following 2 Users Say Thank You to 2point0 For This Useful Post:
Chimpo (06-05-2013), qoncept (06-05-2013)
Old 06-05-2013, 01:07 PM   #16
2point0
2point0's Avatar
FYI - I'm not saying plasti-dip is terrible. I've seen some great examples, like the link posted above of the gold stockers. Cheap way to make stock wheels look better.
But saying it looks like powdercoat is a big stretch.
Old 06-05-2013, 01:15 PM   #17
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I know that powder coating involves heating during the process, isn't that risky for the wheels strength ?
adprokid is offline   Reply With Quote
Old 06-05-2013, 01:21 PM   #18
2point0
2point0's Avatar
Many powdercoating shops are accustomed to doing wheels. Just talk with them about it first. The shop I went to used stripper to remove the old powdercoating from my wheels because they didn't want to damage them. It would work, but would take lots of concentrated blasting in one spot to remove the old p/c and that would generate a good deal of extra heat that they didn't want to subject the aluminum to.
Old 06-05-2013, 02:55 PM   #19
qoncept
qoncept's Avatar
Powder can be cured at 250f. That's not that hot. Maybe I'll hit my hubs with a pyrometer this weekend but I'm sure the center of the wheel gets at least close to that during heavy braking at a track day.
Anyway, powdercoating and Plastidip are hardly interchangeable. My true answer to "why not plastidip" is because I think it's ugly as hell.
Unfortunately a DIY paint job, isn't much better. It's hard to paint like a pro using a rattle can. I've done it a couple times and, IMO, there is no way anyone would think it looked better than the stock finish on our wheels. And it wasn't nearly as durable as a factory finish. Maybe someone else can do it better than I can but in general DIY paint is going to look about as good as plastidip, with the option of a lot more colors and gloss finish.
FWIW, I actually AM going to plastidip my stock wheels. But only as protection because they are my track wheels.
qoncept is offline   Reply With Quote
Old 06-05-2013, 03:02 PM   #20
brunofrs
Drives: frs white tri-coat
haha here in quebec , canada i have a place who make the wheels for 100$ but they not have a big choice of colors...
brunofrs is offline   Reply With Quote
Old 06-05-2013, 03:54 PM   #21
FM Wheels
FM Wheels's Avatar
Drives: a car with nice wheels.
To answer some questions..
The OP wanted a flat gray look, not a glossy finish. Prep and application is what's most important, i've done a lot of wheels and they come out looking like textured powder coat. We don't do straight flat powdercoats because they scratch very easily and can't be buffed out.
It's not a matter of saving weight, it adds weight overall to the wheel, it's not much (5-7oz) but the wheels will need to be rebalanced. That's another cost added.
Yes, low temp powders can be cured at this temp but not all shops use them. Make sure you ask your powder coating shop first. Btw, when we powdercoat wheels they are always chemically stripped, degassed, and then a 2 stage powder coat is applied.
FM Wheels is offline   Reply With Quote
Old 06-05-2013, 04:07 PM   #22
qoncept
qoncept's Avatar
5-7oz??
http://snailmotorsports.com/index.ph...01returnid=177
If you're powdercoating wheels you're doing it with the tires off, which means they'll need to be balanced again anyway.
The Following User Says Thank You to qoncept For This Useful Post:
shaunsweeney (12-21-2013)
Old 06-05-2013, 04:15 PM   #23
2point0
2point0's Avatar
Nice link! Makes sense that multiple layers of paint/clear would weigh more than powder for the same coverage. Especially in terms of DIY rattle can. I had to lay down SO MUCH paint to cover, I think I went through a can per wheel at least.
qoncept, I can totally see where you're coming from regarding DIY paint jobs, as I've seen some that look absolutely terrible, but some look really good. I don't know what my secret ingredient was, but my bronze LGT wheels came out great. I even got through painting two of my 5Zigens white before I got a new job and decided to just have them powdercoated. The white paint was beautiful, but I ended up getting some crap blowing in the wind and settling in the clear.
Old 09-04-2013, 09:38 AM   #24
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
I realize this topic is dead but I have a question. I am thinking about buying XXR 527's and I want them to be white so I was thinking about powder coating. Since the wheel will not be on the tire yet I won't have to pay the extra fee. If I do go this route what color should I buy them before they are powdercoated? Silver?
Thanks.
Old 09-04-2013, 09:41 AM   #25
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by CAMBAM_6 View Post
for anything over 50 dollars per wheel is retarted..buy new wheels
Only new wheels I can find for $50 are steelies, lol
(PICS) Another AMAZING Opti Coat in Arizona by Windows and Wheels Yruyur Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 04-09-2013 09:29 PM
Powder Coated Wheels Safe for the Track?!? BlaineWasHere Tracking / Autocross / HPDE / Drifting 21 03-24-2013 09:46 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Powder Coated stock wheels on a Firestorm? .Woody FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 01-26-2013 09:09 AM
17x9 wheels came in - considering powder coating them Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-06-2012 11:01 AM
