go_a_way1
Old 06-03-2013, 11:11 PM   #1471
sybrite
Drives: 2013 Subaru BRZ
Originally Posted by Slick View Post
Sure will, 225/40R18 is a good fit for 18x8. Pretty much perfect diameter too. The 235/35R18 is a pretty rare tire size anyways.
Good. I was beginning to gather that when I saw how much the recommended size costs. I think I will go with the Bridgestone Potenza S-04 in that case. Thanks for the response.
sybrite is offline   Reply With Quote
Old 06-05-2013, 12:16 AM   #1472
loogs
Drives: on cruise control
got to page 4 and decided to just post. sorry if this has been answered but i need an answer for me.
i ordered the enkei RPF1's in 17x9 +45 with 245/40/17's
anything that should worry me there?
im lowered an inch on eibachs and want to do coil overs next year. thanks
loogs is offline   Reply With Quote
Old 06-05-2013, 05:01 AM   #1473
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
You will be dangerously close to the front spring perch/strut.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-05-2013, 09:18 AM   #1474
loogs
Then why do they offer it? I've never heard of anything like this
Old 06-05-2013, 09:21 AM   #1475
jshadeck
jshadeck's Avatar
Different fitments for different cars...
Not every car comes with 17x7 +48 nor does every car have the same backspacing, suspension placement, fender clearance, etc. if every rim fit every car there would be no "will this fit" forum
jshadeck is offline   Reply With Quote
Old 06-05-2013, 01:13 PM   #1476
ill86
ill86's Avatar
Drives: iG FR-S
Just because they make it doesn't mean it will fit the FR-S/BRZ.
Read this thread and you will not only hear about it but learn what fits.
Peace
Old 06-05-2013, 01:30 PM   #1477
tha7osavage
Works xd9 18x10 +38 front and rear.
Planning to lower my car with tein basic coils.
What will be required to makes this functional for a daily driver?
All help is appreciated.
tha7osavage is offline   Reply With Quote
Old 06-05-2013, 02:37 PM   #1478
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Because technically they do fit. The 17" wheel lip sits below the spring perch so the wheel will not hit it, but the tire will depending how wide you choose.
You may be okay with a 225/40R17, anything more I suggest that you check the forums, and search for RPF1 and I'm sure you will find "some" guys that are running this wheel.
If you are running coilovers, you are gaining inside clearance, so maybe that's how the others are fitting this wheel.
In the end, it is your choice, do your research though!
This is the perfect track wheel, but in 17x9 +35. I love those RPF1's!!
Slick is offline   Reply With Quote
Old 06-05-2013, 04:29 PM   #1479
JerryMichaels7
Drives: Whiteout FRS
15x10 weld's any idea what backspacing would be needed to run these in the rear( only at the track) or if its even possible?
JerryMichaels7 is offline   Reply With Quote
Old 06-05-2013, 05:03 PM   #1480
loogs
i just got back from the tire store. the spring perch clears but at full lock, the rim does hit the tie rod. im gonna just live with it as its a rare scenario that the wheel is at full lock and at least its not going to affect the performance.
thanks for all the info
Old 06-09-2013, 12:49 AM   #1481
onthemove
Drives: ...
I've been doing some research but I still have a question about wheel fitment, as I'm about to purchase a set of rpf1's.
I was originally looking to do a square setup of 17x9 +35 offset, but it seems the front wheel would be too close to rubbing for personal comfort.
I now am looking into a staggered setup and do 17x8 +45 on the front and 17x9 +45 in the rear... I'm thinking the front will be OK but now I'm worried about the rear...
So my question is, will a 17x8+45 front, and 17x9+45 rear be a good setup?
Like I said I've been looking around and I know this had to have been covered before. I must have missed something, any help is appreciated.
onthemove is offline   Reply With Quote
Old 06-09-2013, 12:54 AM   #1482
Asphalt~86
Drives: Asphalt AT
I am getting ready to put some 18x9 +40 on 235/40/18 with stock suspension. Any issues? I have coilovers coming but was told it's about 2 weeks out and I am incredibly impatient.
Asphalt~86 is offline   Reply With Quote
Old 06-09-2013, 01:24 AM   #1483
ill86
ill86's Avatar
Drives: iG FR-S
Rear is okay.
Be careful with front tire size up front. (Inner clearance) 235 will fit, 245 will be close.
Old 06-09-2013, 01:25 AM   #1484
ill86
ill86's Avatar
Drives: iG FR-S
Good luck :-) very close front inside clearance.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
