Old 05-29-2013, 11:07 AM   #141
ayau
Drives: Some rust bucket
Originally Posted by swift996 View Post
Thanks for the feedback guys. I don't know if I'll have enough time to remount and get an alignment.
Do you think it would better to leave as is or remount and go w/o an alignment? I'm about to take a 300 mile or so trip.
I'd worry the most about the toe in/out. A misaligned toe can cause extra scrubbing of the tire, thus decreasing treadlife. If the toe was already fixed, I'd leave it as is and remount/align after the trip.
Ideally I'd just take another car for the trip, but I'm not sure if you have another car.
Old 05-29-2013, 11:10 AM   #142
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by ayau View Post
You sure the top plates have caster adjustment? You can only move the shock side to side for camber, not front and back for caster.
Yes, I'm sure. See channel machined into the top plate mounting bolts. Like I said.. it's a good design just wish the damper valving was better.
RYU is offline   Reply With Quote
Old 05-29-2013, 11:11 AM   #143
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Not only is your camber gain minimal, but your caster is completely off which will have an effect on ride quality and handling. I would recommend remounting it as soon as possible but not without an alignment.
Jackson is offline   Reply With Quote
Old 05-29-2013, 11:13 AM   #144
Jackson
Jackson's Avatar
The studs for the plate have slotted holes on the bottom for caster gain.
The Following 3 Users Say Thank You to Jackson For This Useful Post:
ayau (05-29-2013), CSG Mike (05-29-2013), RYU (05-29-2013)
Old 05-29-2013, 11:18 AM   #145
ayau
Had no idea they were slotted, thanks!
Old 05-30-2013, 12:00 PM   #146
Hanakuso
Sorry I won't be able to give an update today. They will need my car till next week. They did ask for my permission beforehand for the extended stay. Eibach has been very accommodating, they've given me a rental and they will trailer my car back to the LA area so I don't have to make the hour drive to Eibach.
Hopefully Jackson or someone can give us some insight on what they've found.
Hanakuso is offline   Reply With Quote
The Following 6 Users Say Thank You to Hanakuso For This Useful Post:
CSG Mike (05-30-2013), Dave-ROR (05-30-2013), JoeBoxer (05-30-2013), Mgivens (05-30-2013), RYU (05-30-2013), tokiokun717 (05-30-2013)
Old 05-30-2013, 01:11 PM   #147
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
I'll be at Mid-Ohio on June 10th. I plan to give a review then too. As I mentioned, I like the performance thus far, they just aren't very street friendly. I'm having a really hard time dialing these things in for spirited driving.
I'll be there instructing. Let me know if you need any help with them while you are there.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
swift996 (05-30-2013)
Old 06-01-2013, 04:03 AM   #148
tokiokun717
Drives: 2013 FR-S Whiteout
Really disappointing week with the R1s. I took a joy ride on Monday through a route that I know pretty well. The road conditions there aren't that bad (or so I thought with the stock suspension) but I was losing traction through numerous turns since the car floats even through small bumps. The traction light just flickered through most of the turns and I actually had to drive a lot slower than my stock suspensions to even feel safe.
Fast forward to today, I decided to give it another shot on the same road this time adjusting the rebound just in case the car was bouncing due to the rebound being soft. No difference at all.
If there isn't any significant update next week from eibach, I think I'm giving up on these.
tokiokun717 is offline   Reply With Quote
Old 06-06-2013, 11:07 AM   #149
RYU
RYU's Avatar
Any updates perhaps?
Can you or @Jackson share what's being done to them?
I've been w/o coilovers for a month now
Old 06-06-2013, 11:20 AM   #150
Hanakuso
I'll get my car back today
The Following User Says Thank You to Hanakuso For This Useful Post:
CSG Mike (06-06-2013)
Old 06-06-2013, 11:24 AM   #151
swift996
swift996's Avatar
I got my camber plates rotated and the car aligned. Everything is running smooth. The car is a little less harsh but still a little bouncy. I'm on pretty bad pavement up here in Ohio though. Still a lot of noise more so from the rear struts now (sounds like they rattle around over bumps).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-06-2013, 02:12 PM   #152
CSG Mike
CSG Mike's Avatar
Hit me up. Lets do some testing.
Hanakuso (06-06-2013)
Old 06-07-2013, 01:09 AM   #153
Hanakuso
Got my car back. Eibach made changes but I don't know the exact details since spoke to Mark for only a couple of minutes since I was in class. From what I remember, they replaced the springs with longer springs and removed the helper springs, changed the valving, and he mentioned they did something about the noise issues. I don't know if the changes apply to kits other then the R2, but Kevin did mention they tested the R2, R1 and Pro Street S. They will make an official statement so basically just take what I said as hearsay.
I'll hopefully get the time this week to get an alignment and mess around. I'm just glad Eibach took our concerns serious and grateful they provided me with the rental car, trailered my car back, the small gift and working around my schedule.
The Following 4 Users Say Thank You to Hanakuso For This Useful Post:
CSG Mike (06-07-2013), DAMotorsports (06-07-2013), RYU (06-07-2013), tokiokun717 (06-07-2013)
Old 06-07-2013, 03:25 AM   #154
tokiokun717
That sounds like they pretty much redesigned everything
If you get under your car, can you take pics and post them?
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 01:32 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
