Old 05-28-2013, 01:36 PM   #127
donutfilling
donutfilling's Avatar
Drives: frs
I think all the issues coming from people are really just street issues so far.
donutfilling is offline   Reply With Quote
Old 05-28-2013, 01:37 PM   #128
swift996
swift996's Avatar
Originally Posted by ayau View Post
For those that are disappointed, have you tracked with the coilovers yet? I have yet to track mine, and that's why I'm not going to give my opinion on them yet.
I'll be at Mid-Ohio on June 10th. I plan to give a review then too. As I mentioned, I like the performance thus far, they just aren't very street friendly. I'm having a really hard time dialing these things in for spirited driving.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-28-2013, 05:38 PM   #129
RYU
RYU's Avatar
Drives: really slow...
In my case donutfilling is correct. Just mild to aggressive street driving. No where near what I would experience at the track but enough for my TCS to go off more than expected. Typically, i'd expect TCS go off less with a good suspension setup.
Keep in mind I'm on the R1s. These guys with the R2s are able to dial these in better. I would argue though that a high quality single knob setup is more difficult to R&D because more time is involved but ultimately is better for the customer since the ratios of bump vs. rebound is at the best possible compromise. That's what I expected from previous setups i've had but learned my lesson here.
Still hoping I can provide a shining review for these R1s once I get my set back.
+1 on @JoeBoxer. You're awesome man
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
JoeBoxer (05-29-2013)
Old 05-28-2013, 05:52 PM   #130
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Hey guys,
I just want everyone to know that I'm following the open threads and we will do what we can to "fix" any of the open issues currently going on with the select users out there.
I think a good thing to keep in mind is that the R1 and R2 coilovers are going to be more track oriented than street. Some ride quality will have to be sacrificed for performance. If anyone is looking for comfort>track performance then the Pro-Street-S coilover might be the better option as we have not had a single complaint on these.
Also, we did lots and lots of road testing with these coilovers before releasing them. I personally have only track tested these coilovers at Buttonwillow with @mines13 and they felt great with 400/400lb rates. I haven't heard or felt the clunking or skipping some of you are experiencing on the street but this is being addressed with our engineers and techs.
If anyone has any future concerns or issues you can PM and I'll do my best to reply promptly and get you in touch with the appropriate department here at Eibach.
Tony
Eibach Brand Manager
Jackson is offline   Reply With Quote
The Following 5 Users Say Thank You to Jackson For This Useful Post:
CSG Mike (05-28-2013), JoeBoxer (05-29-2013), mines13 (05-28-2013), RYU (05-29-2013), swift996 (05-28-2013)
Old 05-29-2013, 01:40 AM   #131
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I haven't sold a set of Pro-Streets at all, gave a few quotes but not a single order. I didn't expect there to be any disappointment with these or i wouldn't have sold them, hopefully everything gets resolved soon and you guys get your money's worth. If there is anything i can do for anybody that ordered please let me know.
-Joey
Old 05-29-2013, 08:40 AM   #132
swift996
swift996's Avatar
Question:
When I was doing the alignment yesterday I realized that the camber plates only allowed me to max out at -1.2. I thought more about the plates and remembered when I installed them it seemed odd to be that they weren't perpendicular to the fender. Does anyone know how you can loosen the camber plate?
I think I need to spin it one degree to the right. When I installed them it didn't seem like it could be done. I figured they were mount ready from Eibach but apparently they weren't? The bottom of the assembly lined up to the bolts in this position, which is why I mounted this way.
Old 05-29-2013, 10:05 AM   #133
Squishy
Drives: 2013 WRB BRZ
You are correct they are not installed correctly - rotate clockwise one position of bolts and then you can get correct alignment orientation.
The tops can be rotated as long as you hold the bottom of the struts for grip - they are not fixed in place.
I had to rotate my plates as well before installation since they were not aligned with the strut lower half of my fronts.
Squishy is offline   Reply With Quote
Old 05-29-2013, 10:07 AM   #134
ayau
Drives: Some rust bucket
Originally Posted by swift996 View Post
Question:
Your shocks/plates are definitely mounted incorrectly. Maybe that's why you've been getting weird noises.
It should look like this:
Old 05-29-2013, 10:13 AM   #135
ayau
@swift996, the Eibach lettering should be closest to the bottom bolt (closest to the front of the car).
Mount the plates properly first, and then twist the whole shock assembly so that the knuckle lines up properly with the wheel hub. Also make sure you install the right shock on the right side of the car. The serial number of the shock will indicate a "R" for the right side, and vice versa.
Old 05-29-2013, 10:17 AM   #136
ayau
He needs to rotate it one direction counter-clockwise.
Old 05-29-2013, 10:50 AM   #137
Squishy
My bad - hard to visualize it from here I just work with my hands.
Old 05-29-2013, 10:56 AM   #138
RYU
RYU's Avatar
@swift996
Perhaps a visual representation is better (driver's side: top is toward the rear, bottom is towards the front). This is how I had mine. This provides camber and caster adjustment this way. There were no instructions on it so if I had done it the wrong way pls advise.
I love the way they went about the collar spring perches and I also commend the top hat/plate design. Very functional and the machining was top knotch. It was a bit annoying when some bolts in the kit were standard and some were metric but only mechanics would notice that.
Old 05-29-2013, 10:59 AM   #139
ayau
Originally Posted by RYU View Post
@swift996
Perhaps a visual representation is better (driver's side, top is toward the rear, bottom is towards the front). This is how I had mine. This provides camber and caster adjustment this way. There were no instructions on it so if I had done it the wrong way pls advise.
I love the way they went about the collar perches and the springs and I also commend the top hat/plate design. Very functional and the machining was top knotch. It was a bit annoying when some bolts in the kit were standard and some were metric but only mechanics would notice that.
You sure the top plates have caster adjustment? You can only move the shock side to side for camber, not front and back for caster.
Old 05-29-2013, 11:02 AM   #140
swift996
swift996's Avatar
Thanks for the feedback guys. I don't know if I'll have enough time to remount and get an alignment.
Do you think it would better to leave as is or remount and go w/o an alignment? I'm about to take a 300 mile or so trip.
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 01:32 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
