Old 04-04-2013, 10:38 PM   #1
stoneman155
stoneman155's Avatar
Drives: 2013 Scion FR-S, Whiteout
Fortune Auto 500 Coilover Review
Alright guys, I've got a lot to say but I'm going to do my best to condense this into a reasonable/readable length.
First, I want to explain what my goal was with coilovers. I wanted to retain the "liveliness" of the stock car. Positive front end with a free rear end, still controllable, however with height adjustment and more high speed stability.
I'm currently running
275lb/in or 4.9kg/mm in the front
and 350lb/in or 6.25kg/mm in the rear.
The reasoning behind those rates are based off of the Eibach Pro-Street coilovers. Eibach spent a lot of time developing their suspension models side by side with the stock car. That gave me confidence that the Pro-Street spring rates would be a great starting point for my goals of retaining the stock balance of the car. @FT-86 SpeedFactory was awesome in helping me find out that information. Prompt email responses and more than knowledgeable about the products.
To break it down, the stock suspension spring rates are:
Front = 131 lbs/in or 2.3kg/mm
Rear = 211 lbs/in or 3.7kg/mm
and the motion ratios for front and rear are:
Front = 0.92
Rear = 0.77
So stock rates in correspondance with motion ratio are as follows:
110.8lbs/in or 1.97kg/mm
125lbs/in or 2.23kg/mm
with a Front/Rear ratio of 0.88
Now when we compare that with the rates I am running it looks like this:
Fortune Auto rates in correspondance with motion ratio:
232.7lbs/in or 4.1kg/mm
207.5lbs/in or 3.7kg/mm
with a Front/Rear ratio of 1.12
Essentially meaning the front spring rates have stiffened up, which makes a lot of sense based on the fact that our cars are front engine. This makes the car much more positive on initial turn in and through the center of the corner but we'll get more into that later.
Let's take a look at the coilovers!
Front:
Front Top Hat:
Front Bearings: (These work awesome, I know that because I don't hear them!)
Rear:
Rear Top Hat:
Front Installed: I'm running the car much lower (Less Thread) than shown here.
Rear Installed:
On the ground:
To the important bits, how it drives!
At first, I drove the car and had a bit of understeer through the center of the corner as I was continually applying throttle, this is normal, but I'm looking for the rear end to be free!
So here's the setup I'm currently running and continuing to refine:
Front thread length 2inches 12 clicks of rebound (From full soft)
Rear thread length 1 1/8inches full soft on the rebound.
I originally ran the car with 2 in of thread length at full soft up front and 1 inch of thread length and full soft in the rear.
But in an attempt to free the rear end of the car up, I needed to dial the front in a bit. I've been from full soft to 20 clicks of rebound. 20 overstressed the stock tires, so it was time to back it down. After going back and forth, I decided 12 clicks felt best for me. This is also completely baring the fact that I drive differently then all of you, on different roads at different speeds. So what works for me, may not be what you run.
The rebound got me close, but I needed to shift some weight forwards to stick those front tires down. Raising the rear thread length by another 1/8in did the trick. Lucky first try. Although I will be trying different settings this weekend at the track.
This is also all based on running the stock recommended alignment specs, which are as follows:
Front:
Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less)
Caster (Reference): 5°54' (5.90°)
Steering Axis Inclination (Reference): 15°31' (15.52°)
Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°)
Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.)
Rear:
Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less)
Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°)
Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.)
As the car is setup right now (With my driving style) the car is super positive on initial turn in, (and if driven correctly), the car drives down to the center of the corner and as you start to reapply throttle, the front end tracks true and the rear end is planted. This time, more planted than stock as well as easier to maneuver through the corner if you find yourself making adjustments. Basically, like stock, but more grip and more confidence. The coilovers are simply using the stock tire more efficiently.
However, if you want to get it loose, a simple exaggerated turn in, excessive weight transfer and a stab of the throttle and it goes into a controlled slide as beautifully as it did the day it came from the factory! Thats the fun stuff!
Daily driving, the car is softer and smoother over bumps when rebound is set at full soft, and feels almost identical to the stock car with the front rebound up 12 clicks.
The guys at @FT-86 SpeedFactory helped me through this process and it made life so much easier. Can't thank them enough for their help. Incredible customer service and great knowledge. Not much more you could ask for! They are a vendor for the coilovers, you can check them out at www.ft86speedfactory.com
I'll post updates as I continue to refine the suspension. But for now, time for a drive!
Last edited by stoneman155; 04-08-2013 at 07:21 PM. Reason: Correcting calculations
stoneman155 is offline   Reply With Quote
The Following 10 Users Say Thank You to stoneman155 For This Useful Post:
autobrz (08-06-2013), diss7 (08-25-2013), Draco_PR23 (04-08-2013), FT-86 SpeedFactory (04-05-2013), gkubed (05-12-2016), gled21 (09-19-2016), go_a_way1 (11-25-2015), mou (04-22-2013), Spartan65 (04-16-2013), why? (10-31-2018)
Old 04-08-2013, 09:30 AM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Very nice! We love our set here as well.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Old 04-08-2013, 09:51 AM   #3
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Nice, I had the same initial impression of these!!
I got the Fortune Auto 500 Coilover with Swift upgrade from FT-86 speedFactory as well and I love it!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
FT-86 SpeedFactory (04-08-2013)
Old 04-08-2013, 10:11 AM   #4
Racecomp Engineering
wheel rate = spring rate x motion ratio^2
You have to square the motion ratio to get the wheel rates.
Also, raising the rear does not put any more static weight on the front tires. It's still essentially the same weight distribution. You are changing the roll-axis (in simplified terms). It sounds like you got the car behaving the way you want it to though, so good job!
- Andy
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
autobrz (08-06-2013), finch1750 (01-15-2020), Plumbus (08-23-2020), solidONE (11-09-2013), stoneman155 (04-08-2013), Tristor (10-24-2018)
Old 04-08-2013, 02:33 PM   #5
stoneman155
I changed the ride height to change the weight balance/transfer under load. I haven't gone as far to corner balance the car to change static balance. But thank you for the correction on my math, I spaced squaring the motion ratio, probably from writing it in a hurry.
Update: *Motion Ratio calculations corrected.
Old 05-20-2013, 10:33 PM   #6
normanb21
Drives: black frs
I'm thinking of purchasing these coilovers. I'm wondering if any clunking has arrived. Did you go with the 7k/7k rate?
normanb21 is offline   Reply With Quote
Old 05-21-2013, 01:28 AM   #7
Xauterus
Drives: GTS 86 Galaxy Blue
Was near the start of his thread.
Xauterus is offline   Reply With Quote
Old 11-07-2013, 05:10 PM   #8
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
After getting some time on track with these, how are they holding up?
Also, did you go with the swift spring upgrade option?
smbstyle is offline   Reply With Quote
Old 11-13-2013, 01:24 PM   #9
thebear21
thebear21's Avatar
Drives: scion fr-s (RIP)
im torn between these and the rce tarmac zeros... decisions decisions
thebear21 is offline   Reply With Quote
Old 11-13-2013, 01:29 PM   #10
Diode Dynamics
Diode Dynamics's Avatar
Send a PM to FT-86 SpeedFactory
They will give you all the information you need to make an informed decision
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
FT-86 SpeedFactory (11-13-2013)
Old 10-24-2018, 04:32 PM   #11
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
As long as the endlinks front and rear are adjusted correctly, whichever ones have more threaded into the body would be the ones I'd use.
The Following User Says Thank You to x808drifter For This Useful Post:
Leonardo (10-24-2018)
Old 10-30-2018, 08:31 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Roller bearings installed...
[surl=https://imgflip.com/i/2lcuah][/url]via Imgflip Meme Generator
I LIKE TIRES!
Old 01-15-2020, 08:32 AM   #13
Flex Luger
Drives: Red 86
Thanks for the thorough explanation comparison between the stock spring rates vs Fortune 500 spring rates. It helped me determine which spring rates i want now. Cheers!
Flex Luger is offline   Reply With Quote
Old 01-16-2020, 05:22 AM   #14
Contender
Drives: 2017 Toyota 86
So, you had to buy the roller bearings? My Apexi ExVs came with them...but, I am sure your 500s are far better since they were $500 bucks more. I have yet to put my coilovers on...so I can't say how they are.
Contender is offline   Reply With Quote
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Fortune Auto - SpeedFactory Review - Video / Pics - Tracked / Autoxed / Drifted FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 01-29-2015 09:15 PM
Fr-s on Fortune Auto 500s Propaganda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-10-2014 07:33 PM
Fortune Auto FRS/BRZ coilover kits - Tried and tested personally FreedE Brakes, Suspension, Chassis 15 10-24-2012 11:58 AM
Fortune Auto 500/cusco lca yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-09-2012 12:14 PM
