Old 05-28-2013, 03:26 PM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by brichard0625 View Post
Ok so i have probably done no more than 1500 miles on e85...I know alot of people might have this question. If i check my return fuel and it is going bad
what do i need to change?
how much will it hurt my pocket?
See First post for answer to the first question. As far as how much $$? Who knows..
Sportsguy83 is offline
Old 05-28-2013, 03:26 PM   #44
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by AVOturboworld View Post
The carrier that holds the pump is a "sealed" unit with a non-replaceable filter inside it. It looks like they had to cut that apart to get at the filter to check it.
Our fuel pump upgrades for the other Subaru models had an option for a new carrier unit for that reason, so you could put a fresh secondary filter in at the same time as replacing the fuel pump.
Are you by chance creating a product for the BRZ with an e-85 friendly filter? Like your other Subaru offerings, or are u super secret doing R&D on it right now and your hush hushed?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline
Old 05-28-2013, 03:26 PM   #45
Yruyur
Yruyur's Avatar
I assume an aftermarket pump that is e85 safe should help with the issue. As long as its not the only thing disintegrating.
Yruyur is offline
Old 05-28-2013, 03:27 PM   #46
Sportsguy83
Drives: Limited BRZ
The problem is not the pump nor it being E85 ready or not. Its an OEM filter that is embedded inside the fuel canister assembly.
Old 05-28-2013, 03:39 PM   #47
AVOturboworld
Well, if we are working on something like that, they haven't told me...
AVOturboworld is offline
Old 05-28-2013, 03:40 PM   #48
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Damn that looks like alot of shit they replaced...this is going to suck big time..hopefully mine is not that bad...think i did about 1000 miles on it..robi did about 5000 so hopefully mine is not as bad
brichard0625 is offline
Old 05-28-2013, 03:40 PM   #49
Sportsguy83
Drives: Limited BRZ
Even better, hope nothing got damaged!!
Old 05-28-2013, 03:45 PM   #50
markitect
Drives: Scion FRS
Originally Posted by xjohnx View Post
Right, I was just wondering specifically how they get around this issue with the fuel filter. It seems like it would be hard not to use adhesive when manufacturing it.
Car companies making flex fuel cars basically use an entirely different set of materials for the fuel system. They use different gaskets, different soft hoses, and NO glue.
The fuel filter would just be the first thing to fail(the glue dissolves first), eventually the gaskets would fail, then tubing, then eventually the injectors may be damaged.
markitect is offline
Old 05-28-2013, 03:48 PM   #51
robispec
Drives: Black frs project
and we moving LOTS-O-FUEL too lol
But I'm not crying wolf here I was working to 02:00 AM to get this figured out before a competition!..
robispec is offline
Old 05-28-2013, 03:49 PM   #52
CBR600RR
Drives: Raven Black
where is the intake sump bowl located? and how is it accessed?
CBR600RR is offline
Old 05-28-2013, 03:52 PM   #53
brichard0625
not an optimistic person lol...just hoping that my filter is not fucked up....calculating all my e85 mileage and i probably did around 1100 miles on e-85...just hoping for the best..i guess 93 tune it is for now...e85 was fun tho
Old 05-28-2013, 03:53 PM   #54
Carwhisperer
Drives: A lot of supercars.
2nd DI that's went out on me this month. Been running straight e85 since 10k miles and im at 22k ( January til' beginning of May )
I'll check my filter soon. If that's gone then I'm guessing my issues with My DI's are e85 related and not related to this.
Honestly all my conditions are pointing towards the Telfon band leaking.
The Note* at the bottom fits my driving style most of the time.
Carwhisperer is offline
The Following 5 Users Say Thank You to Carwhisperer For This Useful Post:
F1point4 (05-28-2013), GTM_Challenge (05-28-2013), PANDA86 (05-28-2013), Pete (05-28-2013), robispec (05-28-2013)
Old 05-28-2013, 03:58 PM   #55
robispec
left side gas tank access panel under rear seat
once it is out you need to unclip the fuel pump holding assembly and remove the assembly holding the fuel pump in the sump then look at the botem of the then open sump...
robispec is offline
The Following User Says Thank You to robispec For This Useful Post:
CBR600RR (05-29-2013)
Old 05-28-2013, 03:59 PM   #56
Sportsguy83
Drives: Limited BRZ
This is the SPECIFIC reason I didn't want to run E85 on this car for some years, until tons cold hard data were available. I knew all about other Subaru's handling it pretty well, but no one had any data on it working with out DI system.
drama, e85, santa loses it
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 06:52 AM
Marginally good use for BeSpoke users! Mandy Electronics | Audio | NAV | Infotainment 12 02-15-2013 09:07 AM
E-85 users thread Crossover Auto Engine, Exhaust, Transmission 41 11-16-2012 07:21 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 09:34 PM
