Old 05-04-2013, 11:35 AM   #15
grodenglaive
Drives: asphalt FR-S
I just installed the H&R TC112 bolts - the threads did not need to be ground down. The threads rested entirely outside the bolt hole and did not interfere with the cam adjustment. Strange. H&R also makes a shorter 12 mm bolt called TC212; maybe those are what you had, not the 112. Or maybe there are two different LCA that were produced? Beats me.
Anyway, it looks like I got some decent camber out of it.
Original bolt on top - actually the nut would be tightened in about 3 more threads when installed.
grodenglaive is offline   Reply With Quote
The Following 3 Users Say Thank You to grodenglaive For This Useful Post:
Hyper4mance2k (05-06-2015), Indred (05-23-2013), raven1231 (05-08-2015)
Old 05-17-2013, 06:07 AM   #16
grodenglaive
update - just got a wheel alignment done. Rear camber maxed out at -1.3°.
Not a lot of camber with this method, but certainly better than stock. I'll probably upgrade to adjustable lower control arms next year.
Old 05-17-2013, 06:17 AM   #17
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Isn't stock camber -1 degree?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-22-2013, 06:16 PM   #18
grodenglaive
It varies. I got about half a degree out of the camber bolts. Not too impressive.
Old 05-27-2013, 03:22 AM   #19
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
If I could add a half degree one side and remove half a degree from the other I'd be happy. This is a much simpler solution for most people as we really need some basic adjustment.
I reckon it's a conspiracy that companies aren't releasing a bolt! -> Forces people to buy arms! Many other cars have this bolt for adjustment. Why is this car different?
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
CallmeDave (05-12-2015)
Old 05-27-2013, 03:29 AM   #20
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
My Pajero has these;
Name:  ImageUploadedByTapatalk 21369639776.226745.jpg
Old 05-29-2013, 09:57 PM   #21
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Attachment 38714
That would appear it could do the trick--but where to source them???
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 05-29-2013, 10:08 PM   #22
cnk
Drives: '13 DGM BRZ Limited
Those won't work on the stock arms since the stock arms aren't slotted and don't have the right tabs on either side for them to work correctly. Camber bolts like the ones shown further up will work because they have an oblong section. The one shown above won't because it works by having a slot for the bolt to move in/out and it uses the large disc to press against either a recess or tabs.
The Following User Says Thank You to cnk For This Useful Post:
GTB/ZR-1 (05-30-2013)
Old 05-07-2015, 08:49 PM   #23
FR-Shred
FR-Shred's Avatar
resurrecting an old thread.. its better than making a new thread for the same thing so don't bitch! haha
Anyone install the tc112 bolts lately, how are they going? any install tips? they go in the outer most lca slot correct?
thanks
FR-Shred is offline   Reply With Quote
Old 05-07-2015, 09:24 PM   #24
grodenglaive
thanks
For reference, here's a pic of mine (that's the inner most hole btw). Actually, the outer hole should have the same effect, although I don't know if the bolt size is the same.
The Following User Says Thank You to grodenglaive For This Useful Post:
Hyper4mance2k (05-08-2015)
Old 05-07-2015, 09:29 PM   #25
bfrank1972
Drives: 2013 FR-S Argento
thanks
Working just fine! Installed mine at the innermost points as well, I think that's where you want to do it. Went in very easy as well, not a huge amount of adjustment but enough to even my rear camber out.
Old 05-07-2015, 10:21 PM   #26
FR-Shred
FR-Shred's Avatar
Thanks guys! I am lowering soon so I just want to be able to even it out if needed. Thanks
Old 05-08-2015, 11:08 AM   #27
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Fantastic. These are perfect for people like myself that only need to dial out 1/2* of camber after lowering on springs. There are a ton of threads saying these don't exist for out cars. Oh happy day.
Thanks!
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-11-2015, 06:58 AM   #28
Cope52
Drives: 2014 BRZ
Are these the same thing, the "triple C". they look different. [ame="http://www.amazon.com/TC112-Triple-Camber-Adjustment-Bolt/dp/B00CBQ6M4O"]Amazon.com: H&R TC112 'Triple C' Camber Adjustment Bolt - Pair: Automotive[/ame]
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
