Old 05-24-2013, 02:40 PM   #71
Luis_GT
Originally Posted by boredom.is.me View Post
Conversion kit buddy. (Read in the inspirational voice of Flo) Now go....(dramatic pause)....go rebuild your car.
I don't think it's worth it to fix... since my RC is an HPI Super RS4 I don't have a good selection of bodies for it... It's been collecting dust for over 8 years now... Same as my Traxxas Sportmaxx
Old 05-24-2013, 02:46 PM   #72
bestwheelbase
Drives: 1985 P-Type
@boredom.is.me love your updates. Reminds me we need to post the BRZ racer we've been building.
Love tenth scale electrics!
Old 05-24-2013, 03:27 PM   #73
wparsons
wparsons's Avatar
Originally Posted by Sonolin View Post
Are there any decent mini drift chassis?
Traxxas has their mini rally, based on the 1/16th scale mini revo, but it's more like 1/12th scale in reality.
Can you still countersteer and whatnot with a 4wd RC?
4wd allows you to put power down to the road. At this scale, these cars have ridiculous power. For drifting, 4wd doesn't really allow you to counter steer, unless your rear wheels are spinning faster. Power to the front wheels helps pull you through the corners when drifting. What real drifters do is run a "counter steer kit" in their cars. All it is is a differently geared drive train. The most common kits are a 1.5 and 2. This is 1.5 rear rotations for every 1 front rotation and likewise for the 2. This allows for counter steering. I've only seen 2wd drifting on carpet, but like what was mentioned above, the perfect setup and surface is needed as well as a ton of skill or else you will just spin out in place all day.
This is the biggest annoyance I have with RC drifters... counter steering has NOTHING to do with wheels being under or over driven. Counter steering is when you steer into a slide, also known as opposite lock.
"Counter Steer" kits do nothing but overdrive the rear wheels so that the car doesn't want to drive straight under power. They force you to be better at counter steering to not spin out, but that's the only tie they have to counter steer.
flickr
boredom.is.me (05-24-2013)
Old 05-24-2013, 04:16 PM   #74
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by marky View Post
What paint are you going to use on the spoiler?
Where you get that compound clay putty ?
The paint is Tamiya PS-##. It must have PS on the can and not TS. I used the TS before and you see what happened.
It is just modeling clay from Michael's. It is Fimo Effect baking clay. It comes in a 56 gram block (about 2oz.) for about $3. I started with half of the block and probably worked half of that down.
Get those pics up. We (or at least I ) want to see.
That's exactly why I put "counter steering kit" in quotes. You explained it much better than I did. And I completely agree. It looks good, but takes away the ability to drive straight...the only thing that most cars can do.
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
bestwheelbase (05-25-2013), marky (05-24-2013)
Old 05-24-2013, 04:19 PM   #75
boredom.is.me
Custom User Title
These are MUCH brighter. They aren't as blue as I had hoped, but that's fine. I can get them bluer by boosting the voltage, but for reliability reasons, I built the system to operate at 12.6v. Of course the battery will not stay at 12.6v for ever, but that is the max, therefore the safest setup. If I had a constant voltage, maybe from the rx, then I would be able to raise the power level of the LEDs. The ESC I have sends direct 2s power though, so the brightness would drop of quickly.
The spoiler dropped off of the stand while I was putting the black base coat on, so now I have to re-sand and prime again. That will have to wait till later tonight though. I'm meeting up with some other 86ers.
Size:  253.5 KBName:  ImageUploadedByTapatalk1369426695.035494.jpg
Size:  381.5 KBName:  ImageUploadedByTapatalk1369426722.539161.jpg
Size:  185.3 KBName:  ImageUploadedByTapatalk1369426736.485127.jpg
Size:  185.3 KBName:  ImageUploadedByTapatalk1369426754.300342.jpg
Size:  185.8 KBName:  ImageUploadedByTapatalk1369426767.652160.jpg
Size:  143.9 KBName:  ImageUploadedByTapatalk1369426781.417228.jpg
Sent from my mind using telepathy.
Old 05-24-2013, 05:18 PM   #76
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Yeah I was going to get a tamiya paint at my hobby some to try it out on my buggy and I was wondering what TS was.. Glad I looked it up before getting it.. They didn't have any PS tamiya so I just got the pactra paints..
Your going to blind drivers with that light need a HID housing
Old 05-24-2013, 11:26 PM   #77
wparsons
wparsons's Avatar
PS is lexan/polycarbonate paint, TS is meant for hard plastics.
I'm a big fan of faskolor paints, that's what I've used on any bodies I've painted lately.
flickr
Old 05-24-2013, 11:46 PM   #78
Brndn704
Brndn704's Avatar
This is probably one of the coolest 'RC' cars I have ever seen. Props to you my man!
Brndn704 is offline   Reply With Quote
The Following User Says Thank You to Brndn704 For This Useful Post:
boredom.is.me (05-25-2013)
Old 05-25-2013, 02:10 AM   #79
boredom.is.me
Custom User Title
Believe it or not, I actually thought hard about experimenting with a cut off line. I may try later on.
Old 05-26-2013, 01:45 PM   #80
boredom.is.me
Custom User Title
I finally got to sand the spoiler again. I'm going out to spray the base coat again.
Old 05-28-2013, 05:12 PM   #81
boredom.is.me
Custom User Title
It didn't come out nearly as nice as I had hoped, but a ran out of paint so there was no turning back.
On a side note, the mirrors were also painted and are on. I just need to add the black to the underside. I also ordered magnetic body mounts so I won't have to put holes in te body. In expecting it to be here tomorrow or the day after. Lastly, I ordered new wheels and tires.
Size:  225.2 KBName:  ImageUploadedByTapatalk1369775311.094150.jpg
Size:  204.6 KBName:  ImageUploadedByTapatalk1369775327.290637.jpg
Size:  174.0 KBName:  ImageUploadedByTapatalk1369775341.313102.jpg
Old 05-30-2013, 06:01 PM   #82
boredom.is.me
Custom User Title
This was without the body mounts installed.
Not a great angle, but you can see how high the front is, even after I cut the metal mounting posts. I may just mod the springs. I am also probably going to spray the back of the LED bulbs so they do not shine on the inside.
The kit came with white double sided tape. I replaced it with black double sided tape.
Size:  199.3 KBName:  ImageUploadedByTapatalk1369951271.634761.jpg
The body mounting posts: The black kit was out of stock, so I may just paint the rear posts black.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Sonolin (05-30-2013)
Old 05-30-2013, 06:07 PM   #83
Sivtec
Sivtec's Avatar
Attachment 39092
Need some coils on this thing, you got a wheel gap
JK. Serioulsy this thread rocks. Good work
Old 05-30-2013, 06:54 PM   #84
boredom.is.me
Custom User Title
Haha thanks, ya definitely needs moar low in the front.
Should I get colored wheel nuts? If so, the options are red, black, or grey/gunmetal.
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
Mini NSX M-17 Other Vehicles & General Automotive Discussions 43 11-09-2012 10:10 AM
My Mini FR-S Supermassive Off-Topic Lounge [WARNING: NO POLITICS] 13 08-23-2012 01:53 PM
What about that 1.5L Mini FT? LexusFman Scion FR-S / Toyota 86 GT86 General Forum 39 04-10-2011 09:54 PM
