Old 12-21-2012, 05:44 PM   #1
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Question How often to rebuild coilovers or stock shocks?
I have read a lot on here that coilovers require rebuilding around every 5 years. I've never had coilovers, only Billstein strut/springs all in one on my Elise and R32. I'm wondering if the stock shocks (or that general type) on the BRZ/FR-S also needs to be rebuilt on an average of every 5 years or if the non-coilovers tend to last longer.
Also I need to start telling myself I don't need to upgrade the suspension if I like it how it is currently or since I haven't had it on the track for a HPDE yet (which I will probably only do a couple times a year). Good thing about suspension parts it that it doesn't generally void factory warranties, but engine related stuff has a higher chance of doing so.
I'm learning a lot from spending a couple weeks at work reading this forum since it's so slow slow at work currently.
stockysnail is offline   Reply With Quote
Old 12-21-2012, 06:11 PM   #2
Hanakuso
Depends on many factors such as mileage, roads, weather, etc. I've been on Showa shocks that lasted 100k+
On a side note I was just in Oregon and you guys have very nice roads. The highways are super smooth compared to Cali :P
Hanakuso is offline   Reply With Quote
Old 12-24-2012, 10:06 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Your shock could require a rebuild every month or week, depending on how you use them.
Higher quality shocks tend to have higher quality materials (like seals) that don't blow easily etc
There is no magical timeline,
(Application + Brand ^ Frequency)*chuck Norris =
Old 12-24-2012, 12:54 PM   #4
silversprint
Drives: Mr2 Spyder, Lexus Is350
Depends on the seals, specially the piston seal. Usually real racing shocks have seals that have less hysteresis, like some ohlins. These low drag seals decrease hysteresis and stiction and allow for much more precise shock tuning.
However the downside is these shock require rebuilding much more frequently, as often as every 10K-20K miles or once a year.
On a side note, shock have oil. The oil degrades just like any other oil in the car. Sure a suspension system may not "need" to be rebuilt but it doesn't mean it work as well as it did after 10K, 20K, or 100K miles. On a street car you may not notice but on a performance car specially on the track it will be noticeable.
Toyota MR-S 300hp, 2100lbs. Ohlins, Toyo, BFW,
silversprint is offline   Reply With Quote
KW Variant 3 coilovers in stock! Koru Brakes, Suspension, Chassis 3 12-09-2014 12:26 PM
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
KW Variant 3 coilovers - in stock for immediate shipment! No Limit Motorsport Brakes, Suspension, Chassis 49 01-21-2013 02:58 PM
KW K3 coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 5 12-17-2012 01:36 PM
Cusco Coilovers in Stock! Doug@WGP Brakes, Suspension, Chassis 0 09-12-2012 05:30 PM
