Old 05-23-2013, 10:35 AM   #1
20firestorm13
Drives: 2017 Halo Toyota 86
ECUtek issues
Hey all,
I just recently took my car to get it tunes after replacing everything header back. They were able to get the license into the car but anytime they tried to upload anything the ecu would crash. Anyone know of these types of issues. The tuner seemed a bit confused with it and says that ecutek has been having some issues.
Thanks
20firestorm13 is offline   Reply With Quote
Old 05-23-2013, 10:48 AM   #2
Yruyur
Yruyur's Avatar
Never had issues on either of my ecu's. Is it locking up during tuning? You sure its not their pc locking up? Have they tried to restore back to stock? Did they run an ecutek software update first? Are they reputable? How many other cars have they tuned?
Old 05-23-2013, 10:53 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by 20firestorm13 View Post
Hey all,
Thanks
Who did you take it to? Odds are it's either a cable driver issue, or physical problem with their cable if the issue continues to occur.
Old 05-23-2013, 10:54 AM   #4
Apollo_1092
Flyboy
Apollo_1092's Avatar
Drives: Series 10 FR-S MT (Ordered)
^^ All of this. Make sure the connection to the car is solid as well. If the prongs don't connect correctly that'll cause an error during the install. I'd also try to avoid any pressure on the usb connections to the computer.
Current: Dynotronics Tune, Injen SRI, RevWorks UEL Header (ordered), GReddy Evo3
Future: Over pipe, front pipe, trunk spoiler, mud flaps
Whiteout FR-S: Totaled due to hail damage
Nobis Non Licet Mediocribus
Apollo_1092 is offline   Reply With Quote
The Following User Says Thank You to Apollo_1092 For This Useful Post:
Yruyur (05-23-2013)
Old 05-23-2013, 11:02 AM   #5
Yruyur
Yruyur's Avatar
When I flash I try not to breath for fear of moving either plug.
Could try just logging for a while with the same setup to make sure you are not losing connection. Crank up the volume on the laptop as well to hear if that usb unplug sound happens.
The Following User Says Thank You to Yruyur For This Useful Post:
Apollo_1092 (05-23-2013)
Old 05-23-2013, 11:09 AM   #6
Apollo_1092
Flyboy
Ah I needed a witty remark this morning. Just made it even better. I am paranoid when I flash my ECU. Had one error happen during an installation. Thankfully it wasn't a huge deal and just had to get the license reset.
Old 05-23-2013, 11:10 AM   #7
20firestorm13
They have tuned a few.. had issues with most of them. It's a pretty reputable tuner and they are ecutek licensed and have been for a while. They sent an email to ecutek who responded with that isn't a known issue. The license is still on the car but it's a stock map basically. It appears to crash when they try to update any information. If a tuner puts on a license, if I get a cable from a friend, am I able to try to mess with it myself? I'm running NA so I don't have to worry to much about blowing my car up.
Old 05-23-2013, 11:12 AM   #8
Dynotronics1
Hey all,
Thanks
If your still having problems, give me a call, and we will do what we can to help out
Dynotronics1 is offline   Reply With Quote
Old 05-23-2013, 11:17 AM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Assuming you had the new map from the tuner, yes, you could. I would not recommend that though until you have a better grasp on the ins and outs of EcuTek.
Don't be so sure about that.
Old 05-23-2013, 11:33 AM   #10
Dynotronics1
if the tuner has the license in the ecu, all you need do is load the calibration file. Sounds like they are using an older driver for the cable, or the file is keyed but not for your car.
If you have a cable and a laptop, I can remote access your laptop and see what the issue is if you like
Old 05-23-2013, 06:10 PM   #11
20firestorm13
It actually appears that it was a is use with data logging before the car started. It would crash unless you started logging after the car was started. Was able to get into it today with help from ecutek.
Old 05-23-2013, 08:57 PM   #12
Lonewolf
Lonewolf's Avatar
Drives: Moped
So is everything good now?
Old 05-24-2013, 12:09 AM   #13
20firestorm13
Yup should be good to go
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 11:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 02:10 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 10:34 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
