Old 03-21-2013, 11:02 AM   #1
Frsexxxy
Drives: White Virgin frs
Which should I get ecutek stg 1 or stg 2?
I have a front pipe mid pipe and dual exhaust with dual mufflers. Deleted the second catalyctic. I also have an injen intake. I was thinking about getting a stg2
Frsexxxy is offline   Reply With Quote
Old 03-21-2013, 11:03 AM   #2
2forme
I don't think it will matter. "STG1" handles exhausts about the same as "STG2". And the Intake makes nearly nothing once a tune is applied.
Old 03-21-2013, 11:08 AM   #3
Frsexxxy
Really!?
Old 03-21-2013, 11:23 AM   #4
vtmike
vtmike's Avatar
Drives: Scion FR-S
Most of the power from the injen intake is created by maf trickery. Once you have a tune that accommodates for that I'd imagine there wouldn't be much of a difference.
Sent from my Galaxy Nexus using Tapatalk 2
vtmike is offline   Reply With Quote
Old 03-21-2013, 11:23 AM   #5
2forme
Originally Posted by Frsexxxy View Post
Really!?
Yup. The only reason Injen makes power on a stock tune is because it tricks the MAF into running the car leaner. Once you get a tune, which levels that AFR out to something safe. They all mostly make the same power. The flow of the stock intake isn't a restriction until you're above 195whp NA.
Old 03-21-2013, 01:10 PM   #6
Xdragonxb0i
Drives: ex500r
stage 2? I dont think it will matter, because your e-tuner will change the log to tune to your car. Correct?
Xdragonxb0i is offline   Reply With Quote
Ecutek From FA20Club.com tonytduc Issues | Warranty | Recalls / TSB 1 01-11-2013 10:12 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
EcuTek options? twincamRob Engine, Exhaust, Transmission 6 09-04-2012 05:14 AM
Ecutek Cable jpit Northwest 0 09-04-2012 01:14 AM
Ecutek Cable brz007 Northwest 0 08-25-2012 06:11 PM
