Old 05-21-2013, 11:53 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by lexusb3 View Post
im on 93 and 5.3 psi at 286hp and with exhaust close to 300 if not 300 so its very safe because i beat it up. next week or two ill be on 10 psi pump and e85 so hopefully ill be around the 400++ so ill beat that up and tell you if its safe also but it should be lol
This is a good example. Somehow FA20Club has found a way to make 22hp per psi. You can bet that he is running considerably more timing than I am at 14 psi, but he didn't say I am on 93 at 5.3 psi and 25 degrees of timing.
Old 05-21-2013, 11:55 AM   #16
lexusb3
Drives: FRS
my goal is 400 didnt say i would reach it but i would love to hahhaha
lexusb3 is offline   Reply With Quote
Old 05-21-2013, 11:55 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
who ever has the better tuner lol pretty much ^^
When tuning a boosted car there are the two different mindsets I mentioned. The fact is that with our 12.5:1 compression and 93 octane, we are severly knock limited and the only question is how does your tuner choose to approach that limit either through more boost or more timing.
Old 05-21-2013, 11:59 AM   #18
lexusb3
Drives: FRS
but dont you think with the compression we have more boost is not really the BEST solution it works fine as your driving with 14psi but lets say i push 10 and make what you make what you think would be the safer option ?
Old 05-21-2013, 12:07 PM   #19
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by nix View Post
I heard via the ecutek and haltech networks of a few cars throwing rods around 300 whp!
Apparently it's just a load limit on the rod when it sees bursts of extreme accel.
There's a lot of big number charts on here but how many of them saw extended, high load use outside of a dyno room?
thats part of the reason we chose the t3t4 route for our base kit. small turbos ramp in boost very early with big torque spikes. this is typically the same point any small turbo car will generate allot of knock and spit rods in comparison to the more progressive power found in a supercharger like vortech or a larger frame turbo like our kit. we didnt choose the turbo based on power it was based on minimizing stress on the engine. for a small turbo to make big power its going to have to ramp hard and create that initial spike in torque to do it.
FA20Club.com is offline   Reply With Quote
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
PrDarkKnight (05-21-2013), Pure Automotive (05-21-2013)
Old 05-21-2013, 12:16 PM   #20
FA20Club.com
LOL, well naturally i would be running more timing than your 14 psi map but nowhere near your guesstimate. my timing curve is still pretty conservative infact its almost identical to my vortech map. the issue is i can yield more power from a multitude of variables. first my turbo choice moves my power band in a different direction from yours. when tip-in occurs my setup requires less accell pump increases because my turbo didnt ramp up as fast. the timing map can be progressively ramped back in for a smaller turbo whereas retarded a bit more through the band for the larger turbo since it doesnt take as much energy to keep making power through the curve. if i were @14psi with my setup honestly i would be running even less timing than what you would be at with your GT28. for a gt28 to pump out 20+ hp/psi on low boost would be almost unheard of even with the rpm range and compression of this motor.
King Tut (05-21-2013), PrDarkKnight (05-21-2013)
Old 05-21-2013, 01:13 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks for the information. What size turbo is @lexusb3 running again? I know that power per psi is also largely determined by the size of the turbo.
Old 05-21-2013, 01:17 PM   #22
Sonolin
Ouch! That's scary as that's pretty much my goal
I'll keep an eye out as I don't baby my car at all. I drive her nuts off, and also plan on going to the track quite often...
How do you get in the "ecutek and haltech" networks? Is that a secret club for ecutek dealers?
Sonolin is offline   Reply With Quote
The Following User Says Thank You to Sonolin For This Useful Post:
Strife26 (11-26-2017)
Old 05-21-2013, 01:17 PM   #23
lexusb3
Drives: FRS
T3/4 60
Old 05-21-2013, 01:23 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think you have to be Australian because Haltech is an Australian standalone ECU company that competes with EcuTek. I have ZERO fear of the motor not lasting on 300 whp by the way.
Old 05-21-2013, 01:33 PM   #25
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Because boost numbers don't mean much. Might as well be an arbitrary number when you're talking about turbos.
This thread, several posters in it, hell the entire internet make it sound as if there's a magic boost threshold for any given engine where if you stay below that line, you're safe.
It's not that easy. Ever. For any engine. Even for two identical engines made on the same day in the same factory.
Equal powerbands are equally safe for the engine internals, whether you're at low boost and high timing or high boost and low timing. Torque breaks things, fuel washes down cylinder walls, bad tanks of gas blow engines, etc. The boost pressure in the intake manifold is not what determines "safe".
Sellout is offline   Reply With Quote
Old 05-21-2013, 03:09 PM   #26
zooki
Drives: waiting on a 2021...
So what kind of timing(in terms of degrees BTDC) are these cars running boosted versus N/A? I always thought you run the least amount of total timing possible to insure a complete burn. Too much timing on an efficient chamber design actually works against you. From what I've read, you want maximum cylinder pressure to occur ~6-10 degrees ATDC.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 05-21-2013, 03:39 PM   #27
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
stock for stocks, 11 psi at 15.5 degrees.
Do i fear for my motor ? no, i keep up the maintenance and it keeps me happy.
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
Strife26 (12-08-2017)
Old 05-21-2013, 04:24 PM   #28
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
this exactly...
the basics...
Your engine can only flow a certain volume of air.
Changing the density doesn't change the volume of air entering the engine.
The density that the air is at, decreases, if you shrink the tubing along the path and increases visa versa.
Turbine spool rate: faster is always better depending on the flow rate of that turbo and its threshold. high spool rates signify the efficiency of the turbo. aka needs less exhaust pressure to spool. this in turns lets air leave the engine faster. This decreases the amount of energy the engine has to exert to remove the ignited air and fuel out of the engine.
There are 3 places where energy is used in a natturally asparated combustion engine.
1 to turn the drive shaft
2 to evacuate exhaust gasses
3 pulling in air
this is where turbos help/hurt...
1 air is now being pushed into the combustion chamber
2 more air is available for combustion
but
3 they create more internal heat = loss in power
4 the turbine on the exhaust side creates lots of back pressure and when the air heats up from combustion, the volume of which the air wants to occupy increases dramatically making lots of pressure with the turbo holding it back like a damn behind the turbo. this is why a fast spooling turbo is recommended. air moves out faster and the engine has to do less work to achieve it.
gtx3076R is great turbo for this. Quick spool, high flow rate, and a high threshold
Now that we have the basics done.
reliability
1. measure the air density and flow rate as close to the intake valves as possible, preferably after the throttle body.
2 find a turbo that flows the best vs the amount of hp you want to achieve
too small and your engine/turbo will have to work harder, too big and you will increase lag and back pressure lower in the rpm band
the gtx3076R or comparable turbo is a great mid point, spools fast with lots of room to grow if you need it and you can rev high with it without running our of breath. also with less back pressure you have less heat and your turbo will run cooler during daily driving doing less damage to itself and all components around it.
3 larger intake inlet before the turbo the turbo will be able to flow more with less work = less heat/faster spool times (this is why the PTuning kit works so well with low boost, notice how large that intake pipe is!)
4 a high flow/efficient intercooler. This allows the air to move slower through the intercooler allowing more time for the compressed air to cool. and remember above picture, the larger path compressed air has to move through the denser it is = more power
5 think about getting a larger throttle body as an upgrade at some point to relieve the bottle neck effect of air that reduces air density but not too large that it hurts the flow rate a few mm larger can yield some pretty good gains on a turbo set up. also with a larger opening the air is cooler by the awesome means of physics. when you accelerate air through a confined space it heats up.
6 watch those air fuel ratios, keep them conservative. with the set up above you should be able to make the same power as someone with a less efficient kit that is running more boost and timing and be more reliable than them
7 Turbo placement, is the turbo placed where it can do the least amount of damage as it radiates heat, and is it near a place that has a flow of air to cool it?
8 Oil coolers for the engine/turbo oil and transimission
9 use better oils that have the correct additives for your application and last longer. I personally like 15k mile extended performance M1, track days i like motul.
more reliability!
1 have custom pistons made with the same tolerances in mind as the factory (pretty strict) that are made specifically for your engine's measurements.
2 have water sprayers installed to cool your intercooler for hotter days. (just like STI's )
3 Titanium valves, springs, and retainers (more heat resistant than stock, but from what I've read the stock valve train is pretty good as is)
4 proper fueling: make sure your running equipment that can exceed what you need so you aren't running your pumps at 100% at redline wearing them out. I've always gone by the rule that the pumps/injectors should be around 60%-75% of their threshold at fuel cut
5 change oil more frequently, like every 2k - 3k miles.( for dd's that never see track time just a bunch of hooning)
even more reliability! (lots more money)
1 get a baffled pan and a dry sump to cure oil starvation
2 sump system in the fuel tank so you don't have fuel starvation issues, if you lean out you could blow up your engine! (accelerated performance is developing a kit!)
3 if you want more power, run e85 and get a flex fuel kit in case you get shit E85 like we do in Texas that not always E85 plus you can just pour 93 when ever you don't feel like running E85 and not have to switch any maps
there's more you can do and there's a million different factors i could go over but i don't feel like typing any more
I hope this clears some things up
so reliably isn't measured in whp
its measured in tq, intake and exhaust temperatures, how efficient the engine flows from the intake to exhaust tips, timing, and are all parts up to the job?
if you build your engine, make it as efficient as possible, and keep up with standard maintenance. I don't see why the engine couldn't last for over 100k miles of daily driving at 400 whp and 200k miles at 280 whp. of course track hours are completely different but it should reflect in the same way.
and to answer the OP question
as long as the kit is efficient, sensors are in their correct place for accurate readings, running a conservative tune and low boost (under 9 psi) your turbo frs/brz/gt86 should last you 100k miles
my last car i modified it to run up to a 9800 rpm redline, beat it for 74k miles putting a grand total of 152k miles on a 12 year old car. and never once had an issue. i raced to work on a bone cold engine ever day during the winter and bounced off that almost 10k fuel cut every day. if you want to turbo. do it right the first time and you'll never regret it.
I'm not turbo yet... why? the parts i want to build my kit with don't exist yet. until the fuel fix with accelerated performance is finished i wont even consider doing my build. good thing flex fuel is though! thanks visconti!
Like for example there's a silver frs in north texas that was turbo'd, it was build, tuned by the right people. and because a catalytic converter wasn't up to the task, it melted and shit itself into the turbo. 1 small part like that that could have been replaced with a much better part and that failure would have never happened.
EDIT: also a water-meth injection kit can also be added, these kits clean the inside of the engine's combustion chamber. ive seen photos of cars that ran water/meth for 70k miles and the insides of them look brand new
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 6 Users Say Thank You to carbonBLUE For This Useful Post:
Brayden_23 (12-06-2017), cmss2000 (05-21-2013), killerkid08 (05-22-2013), Sonolin (05-21-2013), Strife26 (12-08-2017), Whitigir (05-21-2013)
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
2JZ engine swap on low boost - low 11's run HighLife FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 03-07-2013 05:55 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
