Old 05-21-2013, 12:31 AM   #1
Octane
Octane's Avatar
Drives: FRS
Safe amount of boost on stock engine?
Anyone know what might be a safe amount to boost on a stock engine before having to build the internals?
Just weighing the option and prices for now.
Octane is offline   Reply With Quote
Old 05-21-2013, 12:42 AM   #2
whiteout13FRS
Drives: 2013 White FRS
I dont think anyone knows. if you boost at the levels the tunes come in i would say thats safe.
SBD turbo. Delicious tuning flex fuel. Kate oil cooling kit. Spencer crash beam. Perrin 3" Exhaust. Motiv pipes. Wilwood Front Big Brakes. Greddy Cold Air Intake. Stance Coilover kit. Spyder v2 tails. Sparcos driver seat. Race Creations duck bill cf trunk. 91/e85 tuned by Eric @ elite performance. All other installs by Neal @ the racers line.
Coming soon: track time
whiteout13FRS is offline   Reply With Quote
Old 05-21-2013, 12:45 AM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
All depends on your tune , kit and the way you intend to drive it
My estimates from hours of lurking around here
10~ on 91
14~ on 93 thanks to king tut
16sh on 9X + WMI
20+ on e85
Obviously this is the amount of boost, you have to consider fuel issues , drivetrain and cooling
My 1 cent
Old 05-21-2013, 12:53 AM   #4
Octane
Octane's Avatar
Drives: FRS
10~ on 91
16sh on 9X + WMI
20+ on e85
My 1 cent
Thanks. At least this can get me in the ball park on what to aim for. I think I'm going to aim at 8psi for now to be safe. Later on probably higher if I want to change the internals I can always crank it up.
Old 05-21-2013, 12:59 AM   #5
SmsAlSuwaidi
Boosted
I think on 91 ( your location says CA) you'd be fine with 7sh 8sh
I'm going boosted On 91 and e85 soon hopefully, i'll stay low for a month or two until I throw some low cr rods and pistons.
Old 05-21-2013, 09:29 AM   #6
nix
nix's Avatar
Drives: AVO BRZ
I heard via the ecutek and haltech networks of a few cars throwing rods around 300 whp!
Apparently it's just a load limit on the rod when it sees bursts of extreme accel.
There's a lot of big number charts on here but how many of them saw extended, high load use outside of a dyno room?
nix is offline   Reply With Quote
Old 05-21-2013, 10:16 AM   #7
topazsparrow
Drives: slow
If I'm not mistaken a fair number of them have seen a decent amount track and Drag use at 250+ whp
topazsparrow is offline   Reply With Quote
Old 05-21-2013, 10:30 AM   #8
dabocx
dabocx's Avatar
Drives: Scion FRS
Water/Meth injection seems like a good option if you have limited access to E85 or want to wait on building the motor. Ptuning is pulling 400whp on 93 and meth injection on the stock block. More than enough to get you in all sorts of trouble
dabocx is offline   Reply With Quote
Old 05-21-2013, 11:05 AM   #9
Whitigir
Drives: 450 awhp twin turbo vr4
While many people on the forum or the internet may throw this out and around. Personally, I do not enjoy the idea of E85 neither do Meth injections. If I was to do this with my VR4, she would break 550 AWHP.
Meth Injections = Rusty part + 70% more for catastrophic failure (Not practical for every armatures )
E85 = Very few fuel stations, and the Fuel consumption is 2-3x times more of the traditional 93. Your full tank of gas may just serve you 1/3 of the original mileage range
The best possible is to build a car running on 93, with conservative tune.
The good news is that with 93, and running around 10 PSI will have you in the range of 300-350 RWHP already. This already makes this car into a beast
Whitigir is offline   Reply With Quote
Old 05-21-2013, 11:08 AM   #10
SmsAlSuwaidi
Boosted
True, speaking for my self Im aiming for the 300 mark on e85 before I build my motor with a simple rod piston setup.
Aren't you pushing 3xx whp on a stock block @nix ?
Old 05-21-2013, 11:43 AM   #11
nix
nix's Avatar
Drives: AVO BRZ
Yeah with about 40% DI to port, over rich map and extra squirts of fuel at points for cooling. I wouldn't expect them to last at this power. I don't really want to go with a flat top head and lose the swirl atomisation of DI so waiting on options.
Old 05-21-2013, 11:45 AM   #12
lexusb3
Drives: FRS
im on 93 and 5.3 psi at 286hp and with exhaust close to 300 if not 300 so its very safe because i beat it up. next week or two ill be on 10 psi pump and e85 so hopefully ill be around the 400++ so ill beat that up and tell you if its safe also but it should be lol
lexusb3 is offline   Reply With Quote
Old 05-21-2013, 11:47 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It is really more of a three variable equation with two primary variables. The two primary variables are boost and timing and the third is your air/fuel ratio. For a given boost/timing/afr there is a maximum brake torque your car can achieve. For most turbo cars this is a few degrees of timing before knock occurs although it can also be past the knock threshold and be unachieveable at a given boost level. So in reality you can either run more boost and pull more timing or run less boost and run more timing. The fact is that knock becomes the limiting factor. Running a richer afr can help move this knock threshold a little bit as well which is why it is a lesser variable in the equation.
It seems most people on this site are not really that interested in the timing that cars are running as compared to the boost that they are running. The cars making good horsepower numbers on lower boost levels are going to be running considerably more timing. You throw in some E85 or meth and again you are going to be running considerably more timing. To get the total picture of how a kit is running you would need to see dyno plots with horespower, torque, afr, boost, and ignition timing.
TL;DR: There is no correct answer to your question.
Old 05-21-2013, 11:50 AM   #14
lexusb3
Drives: FRS
who ever has the better tuner lol pretty much ^^
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
2JZ engine swap on low boost - low 11's run HighLife FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 03-07-2013 05:55 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
