Old 04-29-2013, 01:33 PM   #1
wparsons
wparsons's Avatar
How much spacer is safe on stock rear studs?
What's generally safe to run with the stock rear studs? I'm considering 10mm spacers but don't want to bother if I have to replace the studs.
flickr
Old 04-29-2013, 01:42 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It seems most of the 10mm kits come with studs, so I wouldn't do it.
Old 04-29-2013, 05:30 PM   #3
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
What is the rule? isn't it "seven threads engaged in the lugs minimum"? Don't quote me on that but I remember hearing something like that, so if you can't get them that far on the stud they should be replaced.
Cade01 is offline   Reply With Quote
Old 04-29-2013, 06:04 PM   #4
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I've heard only 3mm on factory studs with spacers.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 04-29-2013, 06:14 PM   #5
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
This.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-29-2013, 07:24 PM   #6
PRORICAN
PRORICAN's Avatar
Yup 3mm is fine but anything over that needs extended studs.
Size of Bolt or Stud Mininum Number of Turns
14x1.5mm 7.5
12x1.5mm 6.5
12x1.25mm 8
1/2"e; 8
9/16"e; 8
Found here http://adaptitusa.com/wheellugnuttorquing.aspx
PRORICAN is offline   Reply With Quote
Old 04-29-2013, 09:44 PM   #7
wparsons
wparsons's Avatar
That's what I figured, thanks guys! I'll wait until I'm doing something more drastic to replace the studs (like when putting in adjustable UCA's maybe).
flickr
Old 08-12-2013, 07:24 PM   #8
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
I'm running 5mm spacers onto the rear without problems.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 08-12-2013, 07:48 PM   #9
KONVERTER
KONVERTER's Avatar
I wouldn't use any spacer that is not hubcentric or does not have a hubcentric ring.
KONVERTER is offline   Reply With Quote
Old 08-12-2013, 09:54 PM   #10
wparsons
wparsons's Avatar
You do realize that no one sells a 5mm hubcentric spacer, right? It's because the depth of the hub flange is more than 5mm so the spacer would need to have a different center bore or be thicker than the flange to be hubcentric on its own.
At 5mm the wheel (if it's hub centric) would still be centered by the actual hub.
flickr
Old 08-12-2013, 09:56 PM   #11
KONVERTER
KONVERTER's Avatar
That is why I would never use a spacer that is not hub centric. That means no 3mm no 5mm etc...
I especially would never use those 3mm stamped / cast spacers
Any spacer must be hub centric to the wheel as well.
Sent from my Nexus 4 using Tapatalk 4
Old 08-12-2013, 10:02 PM   #12
pche
Guy on internet
Drives: Slowly
This^ replacing studs is an easy job. Don't do it at all if you're not gonna do it right
pche is offline   Reply With Quote
Old 08-14-2013, 11:43 AM   #13
wparsons
wparsons's Avatar
That's simply not facts, sorry. I'd agree with not using cheap stamped spacers, but a thin spacer is plenty safe.
The flange on the hub is usually around 10-12mm on most cars, which means with a 5mm spacer the wheel is still centric on the hub itself. That's also the reason why you only see hub centric spacers in > 10mm thicknesses for most vehicles.
flickr
Old 08-14-2013, 12:24 PM   #14
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
HUH? I've been using an aluminum slip-on 5mm spacer for my work equips on my mr2 for the last 7 years. All is fine and dandy and absolutely no vibration issues or whatever.
Stop spreading misinformation.
hmong337 is offline   Reply With Quote
Wheel Directory: Enkei PF01 17x8.0 +45 NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-30-2019 08:39 AM
MAX Spacer thickness for stock studs? FRSpdDmn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-09-2016 01:02 PM
Extended studs with stock setup eckoflyte Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-10-2013 09:13 AM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
