| NY / NJ / CT / PA NY, NJ, CT, PA |
Drives: Raven Kraftwerks Supercharged FRS
CEL and Traction Light came on today
Just driving and both of these lights came on and the traction light went off then came back. The check engine light never went off. Called dealership so that I can bring it in but has anybody had this problem and if so what was the issue.
#2 |
Drives: Subaru Brz
same thing happened to me. ended up just being the gas cap wasnt on tight
#3 |
Señor Member
Drives: white BRZ 6MT
the gas cap would throw a CEL but the slip light?
#4 |
Drives: Subaru Brz
ya slip light came on too. it was weird
#5 |
That's crazy that it would cause the slip light to come on as well. I thought it might have been the gas cap as well. I opened it up and closed it back tight but lights are still on. So I'm gonna run it on my Toyota Techstream and see if the problem comes up. If not then I'm gonna take it into Toyota this week because I don't want to chance it if it happens to be something else. I just hope it isn't something major because I just got the car in March. But thanks for responding @mike123mdc
#6 |
Drives: firestorm frs, manual
they might have to update ur computer if they havent yet
#7 | |
Drives: 2013 Asphalt FR-S 6MT
http://www.ft86club.com/forums/showthread.php?t=15577 |
| The Following User Says Thank You to tvpr For This Useful Post: | myjobis2pimp (05-12-2013) |
#8 |
Drives: 2013 SWP BRZ Limited
Same thing happened to me a while ago, had to to get the ECU updated. Hopefully everything works out man!
| The Following User Says Thank You to jmelgar23 For This Useful Post: | myjobis2pimp (05-16-2013) |
#9 |
Drives: None
What was the problem?
#10 |
Drives: 2014 Subaru BRZ
I had this problem and checked the fault code on torque app. Mine was due to system too rich error. If you have aftermarket air intake then that might be it.
| The Following User Says Thank You to veck For This Useful Post: | Astroboy (10-05-2014) |
| Issues - Traction control and ABS warning light on | G86 | Issues | Warranty | Recalls / TSB | 109 | 10-17-2021 05:32 PM |
| Traction light flashing under trail braking; TC and VSC are both off... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 72 | 06-12-2016 09:18 AM |
| First Check Engine Light and Traction control | QFry | Issues | Warranty | Recalls / TSB | 26 | 10-05-2014 12:27 AM |
| hit a curb HARD, traction control and ABS light on now need help plz! | EvoXDD | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 02-28-2013 05:08 PM |
| CEL ABS and Traction Light | DieselxIndustry | Issues | Warranty | Recalls / TSB | 3 | 01-31-2013 02:04 PM |
