Old 12-12-2012, 01:37 AM   #1
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
CEL after removing cat?
Will I get a CEL after removing my catalytic converter and replacing with a test pipe? Would an o2 defouler or eliminator be needed?
corvino26 is offline   Reply With Quote
Old 12-12-2012, 01:42 AM   #2
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You will not unless you change your header (also catted) to a non-catted. I can't see many if any aftermarket headers coming with a cat.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
The Following User Says Thank You to ngabdala For This Useful Post:
corvino26 (12-12-2012)
Old 12-29-2012, 05:17 PM   #3
corvino26
corvino26's Avatar
what i was thinking of doing was getting a catless header and putting a 02 delete on it like the one in the link below... any thoughts?
http://www.ebay.com/itm/O2-Oxygen-Se...5b7d00&vxp=mtr
The Following User Says Thank You to corvino26 For This Useful Post:
ngabdala (02-02-2013)
Old 02-02-2013, 08:02 PM   #4
ngabdala
I've been banned from here for over a month but I still wanted to get back to you. I'm having a muffler shop do it for me.
Old 02-02-2013, 08:12 PM   #5
kosoku
Drives: 2013 fr-s
More than likely you WILL get a check engine light. The post o2 sensor will go nuts.
kosoku is offline   Reply With Quote
Old 02-02-2013, 08:16 PM   #6
AVOturboworld
If you remove the primary cat in the header, you will definitely get a CEL if you don't take steps to compensate. If you remove the secondary cat, there's nothing back there to take issue with that fact.
Old 05-16-2013, 04:36 AM   #7
corvino26
corvino26's Avatar
The part that I posted screws into the second o2 bung and the sensor screws into that piece... Once I get some cash up I will try it out and report back
Old 05-20-2013, 03:58 PM   #8
TAP Auto Parts
Drives: FRS
yes it will. I recommend the vibrant 02 simulator.
bj@tapautoparts
TAP Auto Parts is offline   Reply With Quote
Old 06-17-2013, 09:15 AM   #9
swift996
swift996's Avatar
This!
Some people have used washers to "fix" this issue. Search around the forum there's a lot on this. I have a catted header with no CEL issue.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Need help removing shifter trim spitz Cosmetic Modification (Interior/Exterior/Lighting) 10 09-28-2019 08:34 AM
removing the dash Surok Electronics | Audio | NAV | Infotainment 6 01-24-2014 12:06 AM
Removing decals sa1126 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-12-2012 12:48 PM
Removing pinstriping Zxtole Cosmetic Modification (Interior/Exterior/Lighting) 15 06-10-2012 08:12 PM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
