Old 05-07-2013, 06:09 PM   #15
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
There is a sticky on track pads used for this car and the user's experiences:
http://www.ft86club.com/forums/showthread.php?t=23680
Track pads can be noisy if not bedded in properly. After bedding the pads, they are relatively quiet and great for street driving. That bed-in layer will get scraped off eventually and re-bedding is required.
CounterSpace Garage is offline   Reply With Quote
Old 05-07-2013, 06:22 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by Calum View Post
I'll be honestly, I'm not pay that much for pads for my use. For the kind of lapping you're describing, sure. But come on man, 240 at set plus shipping.
Just letting people know what we are running and answering the OP's question
From the driver's seat, I will say they are worth every penny.
Cheers!:happy0180:
-Yo
FT-86 SpeedFactory is offline   Reply With Quote
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Calum (05-07-2013), Ryeong86 (05-14-2013)
Old 05-07-2013, 06:35 PM   #17
CSG Mike
CSG Mike's Avatar
Thanks for the replies guys... But (I know, I hate hearing that word when someone has asked for my opinion)... How are those pads on the street? My car will very rarely see track use so street use (NVH, dust, rotor wear) are more of a concern. I'm mainly looking for something with better bite, and slightly higher temperature range then stock. Honestly I didn't even know all of these pad existed.
Sounds like you may best be served by learning how to change pads, and using true race pads for the track.
If you can turn a wrench, and use a torque wrench, you can do it yourself at the track. You'll need a 14mm for the brake caliper bolt, and 19mm for the wheel lug nuts.
Calum (05-07-2013)
Old 05-07-2013, 08:11 PM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
Cheers!:happy0180:
-Yo
Cool, sorry I misunderstood.
Wrenching isn't an issue. I've even calibrated my compression test, fuel pressure test, and tire pressure gauges on a dead weight tester. I'm due to have my torque wrenches calibrated though...
I'm looking for the better bite and temperature range for the street.
Old 05-07-2013, 08:31 PM   #19
Calum
That Guy
Thanks. I have read that, I just feel lost in the sea of options.
Old 05-07-2013, 08:34 PM   #20
CSG Mike
CSG Mike's Avatar
Race pads, for the street. I'm absolutely serious. I do it myself. Properly bedded (not easy), the noise will permanently disappear.
Tons of brake dust through....
Old 05-07-2013, 09:07 PM   #21
Calum
That Guy
ok, I'll give it a try.
Old 05-07-2013, 11:02 PM   #22
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by Xdragonxb0i View Post
Who makes the TRD pads? Also upgrading the pads. Would it make it cause squeak?
the trd pads have zero noise. they are a cool color blue that looks sporty in your calipers too . i would assume toyota makes them? but im not sure...
troek is offline   Reply With Quote
Old 05-13-2013, 04:23 PM   #23
Uatu13
Drives: car
Here's the 2013 TRD catalog, but I don't see brake pads listed for the FR-S...
http://www.toyotaracing.com/trd/cata...g_lowres_R.pdf
Uatu13 is offline   Reply With Quote
Old 05-13-2013, 04:26 PM   #24
OrbitalEllipses
Drives: Attitude
TRD Japan has pads for the GT86.
Old 05-13-2013, 04:28 PM   #25
OrbitalEllipses
Drives: Attitude
CSG Mike (05-13-2013)
Old 05-13-2013, 07:56 PM   #26
troek
troek's Avatar
oh bummer trd usdm dosnt make them. i just put them through the ringer last night up in the mountains and was very impressed. brakes were super hot and had zero fade. slight loss in initial responsiveness but thats probably the stock brake lines and oem fluid. Im gona run them on Tsukuba in july as well.
Old 05-13-2013, 08:07 PM   #27
wparsons
wparsons's Avatar
Just ordered my new pads, Ferodo ds2500's at both ends. I was considering the project U HC 800's, but they're almost twice as much and the small increase in heat range wasn't worth it to me. Also picking up a MC brace, braided lines and new fluid for good measure.
flickr
Old 05-13-2013, 10:00 PM   #28
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Last I checked the Project Mu HC+800's (from @eauto) are cheaper at $220 a set than the Ferodos at $300 a set.
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 02:38 AM
DBA rotors w/ stock pads yomchi1989 AUSTRALIA 16 12-12-2012 08:46 AM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
