Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 12-10-2012, 01:58 AM   #1
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Smile DBA rotors w/ stock pads
Hi guys,
Just need some advice. I am picking up a set of DBA T3 4000 rotors for my 86. I am planning to get a set of Ferodo DS pads to suit.
I have no interest in tracking or aggressive racing, I am only doing this upgrade to minimalise rust and dust from the OEM pads and rotors.
Question is, would upgrading the rotors alone be enough to do this? or ideally should I upgrade the pads too (to reduce dust)?
yomchi1989 is offline   Reply With Quote
Old 12-10-2012, 02:34 AM   #2
nix
nix's Avatar
Drives: AVO BRZ
From what I've read the Ferodos are great pads, but do dust a bit more than oems. I have settled on stoptech street for my first set. Decent heat range but low dust/noise. For rotors, any uncoated one will rust. Here's an extreme pic of DBA 4000s from google:
nix is offline   Reply With Quote
Old 12-10-2012, 05:42 AM   #3
yomchi1989
n00b
Hey mate, what rotors do you have? Coz I heard some pads can damage certain rotors if too soft / hard etc.
Old 12-10-2012, 06:44 AM   #4
nix
nix's Avatar
Drives: AVO BRZ
Right now full stock setup, but soon I am going to DBA 4000's with STI brembos and the stoptech street pads.
The biggest issue with pads/rotor combos is bedding them in properly. New pads on new rotors aren't usually a big deal but mix new and old and it's hard to get them to 100% mate easily.
Old 12-10-2012, 07:15 AM   #5
yomchi1989
n00b
So why are you going the StopTech option? And where do you get them?
Old 12-10-2012, 10:18 AM   #6
gmookher
I'm on the ds2500s with cryo powerslots, happy so far, got rotors off tirerack pads from essex
gmookher is offline   Reply With Quote
Old 12-10-2012, 08:45 PM   #7
nix
nix's Avatar
Drives: AVO BRZ
They are one of the better options for low dust + noise, with a bit better range than oem. I will swap to track pads for heavy work.
Old 12-10-2012, 08:57 PM   #8
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
you just need to paint whatever rotors you buy..
Surok is offline   Reply With Quote
Old 12-10-2012, 09:25 PM   #9
86drift
86drift's Avatar
Drives: Toyota 86 GT
Hi guys,
I don't think buying 4000 series discs are going to help you reduce rust and dust.
First thing would be to look around at the 'street' pads that are available. These generally have lower dust and noise than track focused pads.
If you really want discs then T2 slotted DBAs should suit you fine.
86drift is offline   Reply With Quote
Old 12-11-2012, 12:44 AM   #10
yomchi1989
n00b
Hey mate, T2's don't have paint protection though...
Old 12-11-2012, 12:50 AM   #11
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
ask your mechanic to paint them for you
Old 12-11-2012, 01:24 AM   #12
70NYD
70NYD's Avatar
Drives: RX8 S1
Painting literally takes 1 hour, if that..
FYI, RDA new trislot/dimpled design comes painted, silver or black/gunmetal..
70NYD is offline   Reply With Quote
Old 12-11-2012, 01:59 AM   #13
yomchi1989
n00b
Yes, but does paint protection protect from rust? Isn't painting them different?
Old 12-11-2012, 09:33 PM   #14
86drift
86drift's Avatar
From DBA's PDF catalog:
T2 slot design
Features
Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation
Bi-Symmetrical T2 curve slots dampen the vibration harmonics or noise, resulting in a quieter, responsive and smoother brake pedal feel
T2 slot design provides even pad wear and assists in minimising glazing of pad surfaces
Non-directional slot design eliminates the need for left and right discs
Paint protection on non-friction areas enhances appearance
R1 Concepts Premium Rotors/ Hawk/ Stoptech/ Posi Quiet Pads/ S.S. brakelines Sale! r1concepts Brakes, Suspension, Chassis 419 06-10-2016 06:19 PM
Awesome deals on Stoptech pads , rotors , and brakeline from ERZperformance ERZperformance Brakes, Suspension, Chassis 51 05-21-2013 06:11 PM
FRS/BRZ StopTech Brake Pads, Rotors and Lines at Redline360 Redline360 Brakes, Suspension, Chassis 4 01-13-2013 02:42 AM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 05:20 AM
