Track brake pads - front and rear?
Just got my Argento 86 and plan on bringing it to an hpde next month. I plan on replacing the brake pads with better ones. Will do a brake fluid flush as well. The pads will be used only on track and will be swapped out after each event. It will be my first time doing hpde's.
My question is, should I buy pads for both front and rear? Or can I get away with just replacing the fronts and using stock ones for the rears? Also, any recommendations on what pads to use? I'm thinking something from hawk? |
#2 | |
Drives: H8R FR-S
If yes, I recommend Ferodo DS2500. You can run it on both track and street.
If you want to make a small fortune in motorsports, start with a large one
#3 |
Yeah, I'll stick with the stock tires for at least a few months. Still have to learn the car and how it behaves.
If I use ferodo for both track and street, is can I get away with just the front pads or just replace them both? Sent from my iPhone using Tapatalk |
#4 |
Driving Enthusiast
Drives: 2013 BRZ Limited
if your staying w/ stock tires theres tons of options and youll hear something different from everyone. good luck.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
#5 | |
Track Junkie
Drives: 2013 Subaru BRZ Limited, 2005 S2000
As for front and rears, I've been using the DS2500's all around. I've been told by faster folks that you want to use matching compounds on all 4 corners and from my own personal experience, the car feels very good with a full set of DS2500's.
| The Following User Says Thank You to ImperiousRex For This Useful Post: | oofie (05-06-2013) |
#6 |
Drives: 86 ZN6
go check out WORKS brake pads
they are engineered for both the street use and the track ---> http://www.86-zn6.com/WORKS-Blue-Brake-Pads_p_65.html |
#7 |
Because Racecar
Drives: 2013 Asphalt FRS
Still need to get these on the car but this is the setup ill be daily driving and having fun with! |
#8 | |
Driving Enthusiast
#9 |
Because Racecar
Shooting for Wednesday! I'm not too sure how the race compounds for the front are going to be (street able or not) but the HPS's are a solid pad! Wanted a good setup for runs and eventually when I can figure out track days and autocross but still be a streetable setup. I'll be sure to fill you in on my impressions of them. I think from the research I've done and just having buddies who continue to buy these for their cars and swear by them they'll be a good setup.
#10 | ||||
#11 | |
Track pads typically have a maximum operating temp of 1500-2000* F. As always, you want to prep your car for the most extreme condition it will be subjected to, not what it will normally be subjected to. Martial artists train for years for that 2 minute (or less) bout. Our cars have 200hp, but how much time do you actually spend at redline WOT compared to the time you spend in the car? |
| The Following User Says Thank You to CSG Mike For This Useful Post: | orthojoe (05-06-2013) |
#12 |
@oofie: check out this thread for feedback on different pads.
http://www.ft86club.com/forums/showthread.php?t=23680 |
#13 | |
#14 |
Drives: WR blue
I used work blue front and rear pads only with motul 600 last track day in infineon raceway ,it works not bad.through out the whole day,only one or two times felt brake fading,but all at the last round of the session. So I think with slotted front rotors should be good. Or may be additional air duct cooler for summer.
| WTB: Carbotech XP8 Front Brake Pads | n8dog11914 | Brakes, Suspension, Chassis | 0 | 04-17-2013 08:57 PM |
| rear brake pads | donutfilling | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 04-05-2013 11:43 PM |
| FS: NIB Hawk HP+ Front Brake Pads | djfuller | Brakes, Suspension, Chassis | 4 | 02-22-2013 12:59 PM |
| Delete | driver01 | Canada Classifieds | 1 | 01-11-2013 06:51 PM |
| Hawk HP Plus front brake pads on the track | mtsound | Tracking / Autocross / HPDE / Drifting | 30 | 11-15-2012 03:24 PM |
