Old 04-30-2013, 01:17 PM   #1
Kregar
Kregar's Avatar
Drives: 2013 Scion FR-S, Asphalt
Overpipe rattle?
So I just upgraded my stock over/frontpipe to a Nameless Front/over pipe combo and now I seem to have a rattle vibration. It seems to happen under acceleration turning left, I called Nameless and they gave me somethings to check which I will. Just wondering if anyone else has had a similar issue with after market pipes?
Kregar is offline   Reply With Quote
Old 04-30-2013, 01:23 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Could be something is loose. When I installed PPE overpipe with Berk front pipe, it rattled a bit at first and I had a small exhaust leak where the two met. After tightening, the leak has gone away.
JDKane527 is offline   Reply With Quote
Old 04-30-2013, 01:36 PM   #3
mrk1
Drives: Sterling BRZ Ltd
Did you have to lift the motor to install the combination pipe?
sorry its not really relavant to your problem.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-30-2013, 01:36 PM   #4
Kregar
Kregar's Avatar
yes that was part of the install for this pipe
Old 04-30-2013, 03:42 PM   #5
reeves
Yea mines rattle a bit too, sometimes at idle, sometimes at 2-2.5K.. most times it doesn't rattle at all. I just chalk it up to trying to fit an extra large pipe through an opening that was made for the skinny OEM crushed pipe. Something's gotta give..
The Following User Says Thank You to reeves For This Useful Post:
Kregar (04-30-2013)
Old 04-30-2013, 04:13 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
Stock header?
DJCarbine is offline   Reply With Quote
Old 04-30-2013, 04:22 PM   #7
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I would guess the overpipe is running close to the body, and on higher g turns it will push over and rub.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
Kregar (04-30-2013)
Old 04-30-2013, 04:48 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
I've not noticed any issues with my nameless over/front pipe with helmholtz and cat.
Did you re use your stock doughnut gasket from the end of the front pipe to the midpipe (or catback depending on what the rest of your system looks like?
Old 04-30-2013, 06:10 PM   #9
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Probably hitting the frame. Try to loosen it and push up while you tighten.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 2 Users Say Thank You to Simmons For This Useful Post:
Kregar (04-30-2013), number1Tango (07-23-2013)
Old 04-30-2013, 07:00 PM   #10
NickFRS
Drives: 2013 Asphalt FRS
What version are you running? I have the 2.5 w/ highflow cat. Never rattles.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-30-2013, 07:24 PM   #11
Kregar
Kregar's Avatar
so after a some what hot inspection
Old 04-30-2013, 07:27 PM   #12
Kregar
Kregar's Avatar
yeah stock header, 2.5 inch high flow without the resonator. I couldn't by hand force it to make contact with the frame and it only really seems to do it under heavy turning loads or first thing in the morning.
Old 04-30-2013, 07:34 PM   #13
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Get a roll of header wrap and loop it around a few times.
http://www.summitracing.com/parts/de...FaZFMgodCzcAzQ
eikond is offline   Reply With Quote
The Following User Says Thank You to eikond For This Useful Post:
Kregar (04-30-2013)
Old 04-30-2013, 07:46 PM   #14
Kregar
Kregar's Avatar
I did use the stock dougnut gasket with the front pipe. I have the stock midpipe and the dealer upgrader Borla axleback
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
wtb overpipe hunter3232792 Engine, Exhaust, Bolt-Ons 7 05-12-2013 01:38 AM
Header and Overpipe... Scooby South Engine, Exhaust, Transmission 17 04-06-2013 08:35 AM
Invida N1 ti tip w/ overpipe Evilbrz151 Engine, Exhaust, Bolt-Ons 4 03-29-2013 09:34 PM
overpipe? ft86me Engine, Exhaust, Transmission 19 03-28-2013 09:57 AM
