Old 12-06-2012, 05:58 PM   #1
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Header and Overpipe...
Should they be Ceramic Coated and/or Wrapped????
Discuss please..
Bill
Scooby South is offline   Reply With Quote
Old 12-06-2012, 05:59 PM   #2
OrbitalEllipses
Drives: Attitude
If you're min/maxing, why wouldn't you? Probably not as critical as on a turbo car.
Old 12-06-2012, 06:01 PM   #3
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
wrapped would be all you need. you could do both if you are really worried about it.
FreshFRS is offline   Reply With Quote
Old 12-06-2012, 06:07 PM   #4
Scooby South
Conedancer
I think Ceramic/Wrapped would be good for the header to maximize efficiency and probably just Wrapped on the overpipe.. thats my 2 pesos..
Old 12-06-2012, 06:57 PM   #5
BRZ?
Drives: 2014 SWP 6MT BRZ
I wrap the whole exhaust, from the engine to the tips. Why not?
BRZ? is offline   Reply With Quote
Old 12-06-2012, 07:10 PM   #6
FR-S Matt
A little excessive unless you have the extra money to throw at it. I'd most importantly want the headers coated or wrapped more than anything. You want that heat out of the engine bay. Like someone else said, furthest I'd go is probably the overpipe. Behind that, I don't think it matters too much unless someone can provide insight on why it would be valuable.
Old 12-06-2012, 07:40 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
Whatever you decide, a before and after dyno would be nice. Or temp readings or something.
Because titanium.
Old 12-06-2012, 07:43 PM   #8
Captain Insano
I've wrapped, coated, and coated/wrapped headers on past cars. I think obviously max heat proteciton is coat/wrap. I do think though on this car that EGTs probably won't be as high as a turbo car. With that in mind, it would be very nice if some of the header/exhaust vendors would have a coating option. If they did, that probably would be all I would do on the header/overpipe for this car. JMHO.
And I'm talking about real quality coating that makes a difference (like anything, there are good coatings and bad coatings out there). Something like swain inside and outside.
Old 12-06-2012, 08:53 PM   #9
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
http://www.jet-hot.com/
Check out Jethott coated... People use that to keep temps cooler and tends to make the parts last longer.. If im not mistaken.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 12-06-2012, 08:56 PM   #10
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Prefer coating to wrapping, especially on stainless parts.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 12-06-2012, 09:09 PM   #11
maj75
Drives: Blue FRS 6sp, 95 M3
Since most of the systems for our cars are stainless, you probably won't see a lot of coating options. Besides the thermal advantage, coatings are usually used on cheaper mild steel headers so they last longer without rusting. Since the stainless headers don't rust like mild steel, coating is redundant for all but the most hard core applications.
Wrapping is death to mild steel headers, but fine on stainless. Not only does it keep heat out of the engine, it keeps the heat in the exhaust. Theoretically, that helps exhaust flow.
maj75 is offline   Reply With Quote
Old 12-06-2012, 09:21 PM   #12
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Agreed...
I've had a set of Watson SS headers on my ZR the were Jet Hot Coated back in early '96--not a single issue & I'm certain it's helped w/ some of the heat radiation. My .02...
GTB/ZR-1 is offline   Reply With Quote
Old 12-07-2012, 11:03 AM   #13
BRZ?
Increases exhaust gas velocity, especially helpful in turbo vehicles
Old 12-07-2012, 11:33 AM   #14
gmookher
I'm going FI via SC, and feel just fine with a uncoated header. One of my big reasons for SC is you dont have the same heat concerns you do witha turbo. I could see where om a turbo application, coating can be more important depending on placement etc
gmookher is offline   Reply With Quote
P&L Motorsports BRZ / FR-S Overpipe P&L Motorsports Engine, Exhaust, Bolt-Ons 166 09-24-2015 04:43 PM
Motiv Concepts Prototype Overpipe MotivConcepts Engine, Exhaust, Transmission 36 07-17-2013 07:25 PM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
Perrin's catback, front and overpipe? rainmonkey Engine, Exhaust, Transmission 0 10-07-2012 01:48 AM
