#15 |
Drives: 2013 Scion FR-S AT Asphalt
The only thing I can see "egregious" about this headlight "issue" is the proposing of a lawsuit because of it. Did you suffer any personal injury to yourself or your property because of it? No? Sorry.
Just because you are too (insert colorful adjective here) to turn your lights off when the car is beeping loudly at you to do so is you're own fault. Read the owner's manual. Now, that said, out of all of the minor "issues" an quirks with the FRS/BRZ/GT86, there is only ONE that I could think of that may be worth litigation and that is the failure of the ECU to COMPLETELY disable the ABS/TCS/VSC when the button has been held for 5 seconds. Search "the Pedal Dance" to find more detailed information. This in my opinion is a safety issue for a car that has been claimed to have been set up for drifting and track use that could result in a high-speed crash under the right circumstances. If you're one of those types just looking for a reason to sue someone, that would be the one that I would go after. Scott
#16 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
Features that enable laziness should be burnt anyways.
| The Following 2 Users Say Thank You to raul For This Useful Post: | Hardrock4445 (04-28-2013), lbroskee (04-27-2013) |
#17 |
Well, no. There are grounds for some complaint. It is in fact currently listed as a standard feature on the FR-S (just checked for myself). That means we paid for it in the base-price of the car. If they didn't want to install it, that's fine. But it shouldn't be listed as installed.
Would it be ok for them to say they gave you floor mats and charge the extra money for them but not do it? Why not just charge everyone for the Bespoke sound system but install the base unit? Conversely, how much would it cost to have a dealer install an auto-off function in the car? I'll bet it'd buy a few tanks of gas at least. |
#18 |
Directly from the Scion.com website under Exterior features, although not sur its lawsuit worthy...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#19 |
I've emailed Scion. We'll see what they say.
#20 |
Custom User Title
Drives: Asphalt FR-S MT
Mine shut off after a while of being on. It takes more than a few minutes, but it does shut off. I might time them tonight.
#21 |
I am doing my absolute best to not sound rude but...
<deep breath> According the US Scion FRS Service Manual document version 6.4 A From 201203, Document ID RM000004NUM00RX, Titled; LIGHTING (EXT): LIGHTING SYSTEM: CUSTOMIZE PARAMETERS (2013 FR-S) These are the settings that can be changed by the dealer by connecting to your ECU. Light Auto OFF Delay - Default 30 s - "Keeps the headlights on for a certain period of time after turning the ignition switch off and closing all doors with the low beam headlights on." Setting options: OFF, 30 s, 60 s or 90 s Summary: Go to the dealer and have them change it!! You're welcome! Scott
| The Following 5 Users Say Thank You to naikaidriver For This Useful Post: | avusblue (04-26-2013), Dake (04-25-2013), Fett4Real (04-14-2014), FRSBRZGT86FAN (09-02-2013), Hindi (04-26-2013) |
#22 | |
| The Following User Says Thank You to Dake For This Useful Post: | naikaidriver (04-25-2013) |
#23 | |
Drives: Whiteout FRS
Thanks, Scott. I'll relay this information to my dealer and hopefully they can resolve this issue.
I can turn off my headlamps perfectly fine without your comment on my apparent laziness, thank you. Quote:
#24 | |
Its not uncommon to have some "variance" in some ECU changes even in similar cars from the manufacturer. Scott
#25 |
Drives: 2015 Sti Launch Edition
Screw the auto off feature... I want those damn headlights off the special edition FR-S with the Led DRLs >_<
#26 |
Drives: Firestorm 6MT Scion FR-S
I might just go to the dealer and have them do that tomorrow! I got used to auto off lights in my tC for 8 years.
![]() 2013 Firestorm 6MT Scion FR-S |
#27 |
Drives: 2013 Fr-s Firestorm 2013 Fr-s 10ser
Most toyota have auto light off features when you open door or turn key off they go off. Even in my old 92 -94 camrys did it also 05 tundra
#28 |
Drives: Scion FR-S 10 #853
I want to install manual window roller bars so that I can furiously wind them up and down manually because yes auto features are for lazy asses!
| The Following User Says Thank You to oldpueblo For This Useful Post: | davesrave (04-25-2013) |
| True or False | monkie | Off-Topic Lounge [WARNING: NO POLITICS] | 231 | 02-05-2013 06:55 PM |
| Auto-Off Headlamps | nktech | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 12-10-2012 09:51 AM |
| Toyota Advertising Complaints | nzer | Off-Topic Lounge [WARNING: NO POLITICS] | 21 | 08-31-2012 08:35 PM |
| False Advertising | Mike Sino | BRZ First-Gen (2012+) — General Topics | 8 | 07-15-2012 03:59 PM |
