View Poll Results: Should the Toyota H4 Support Flex-Fuel (E85)
Yes, It should be E85 Compliant. 12 48.00%
No, It should run on regular Fuel (91) 13 52.00%
Voters: 25. You may not vote on this poll
Old 02-05-2010, 12:49 PM   #29
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
Originally Posted by Lexicon101 View Post
11+% boost, but the graph shows right there in the legend that the setups on the car are different.
I want to see the same setup produce those numbers. Then I'll take your claims of HP boosts srsly.
*sigh*
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-05-2010, 12:50 PM   #30
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Drives: '08 xB '07 Yaris '06 EVO9 '89 240SX
In the blog, it explained that the performance modifications were the same.
Biggie™ is offline   Reply With Quote
Old 02-05-2010, 01:47 PM   #31
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
this
Originally Posted by Biggie™ View Post
The GT-R wasn't designed to run E85, so they had to upgrade injectors and fuel pumps. But other than that, both setups were identical.
and if your talking about the extra 1.5psi that was because it is safer to run more boost with e85 or race gas because of its resistance to detonation.... the real reason we want e85 in the first place...
Midship Runabout is offline   Reply With Quote
Old 02-05-2010, 01:55 PM   #32
Biggie™
Stassenkämpfer
Biggie™'s Avatar
The nice thing is you don't have to run it if you don't see a benefit. But having the option does bring bigger injectors and higher capacity fuel pumps that will benefit anyone upgrading the performance. I believe that fact is getting lost on some.
Old 02-05-2010, 02:23 PM   #33
Matador
hashiryu
Drives: Mk4 Supra
That is true, but regardless the factory ecu is not able to take advantage of the bigger fuel system while running regular gas.
If that is the sole reasoning behind wanting an E85 capable car, I could think of many better things that could be added to the car which would result in the same price increase.
Matador is offline   Reply With Quote
Old 02-05-2010, 02:46 PM   #34
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Hum... What about the MKIV Supra Twin Turbo, with basic bolt ons and no tuning it made an extra 150 whp or more?
Anyway... I've already posted tuning options for factory ECUs, I'm sure with enough demand the FT86 would soon have something of its own.
Old 02-05-2010, 04:27 PM   #35
NESW20
2.1L 3SGTE
using another example: my MR2. from the factory, they come with 440cc injectors, and 160whp. my car is using all the factory fuel system components (with a walbro pump) and making 240whp. and i'm not running out of injector yet.
-Mike
2008 Civic Si Sedan
Old 02-05-2010, 04:41 PM   #36
Biggie™
Stassenkämpfer
Biggie™'s Avatar
-Mike
What is your duty cycle at 240whp?
My EVO needed 1000cc injectors to break 600whp on race gas. When I upgraded to run E85 I went to 1600cc injectors and now put down 648whp.
The thing some might be forgetting is the fact the FT86 will be direct injected. Without larger injectors from the factory, you will be stuck with whatever comes in the car, limiting potential power. The poor MAZDASPEED3 guys have learned this the hard way as they are limited to 400whp.
Old 02-05-2010, 06:15 PM   #37
NESW20
2.1L 3SGTE
when tuning my AEM, i think i'm using "raw" figures, so i couldn't tell you with much precision what DC i'm running. i would imagine in the 70% range, so there's still a little room there, but not a whole lot. to get my MR2 where i want it, my fuel system and turbo need to be upgraded, but that will wait until after i finish school this year. and i might change some parts inside the engine, but we'll see...
one thing i was wondering, since i haven't really done much research (never really had any reason to look): no one makes larger capacity direct-injection injectors?
-Mike
2008 Civic Si Sedan
Old 02-05-2010, 06:49 PM   #38
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Assuming you are getting 10% or more drive train loss, your injectors should be close to being maxed out at over 264 hp.
Since we are in theory dealing with a 2.0 liter Subie flat 4. Let's look at the last 2.0 liter Subie flat 4 that made it to the USofA, the 2002 WRX. It came with 420cc injectors, ones similar in size to yours. Stock power on 93 octane was 169whp and 174 lb/ft. Well those injectors got maxed out at Stage 2(tune and down pipe), about 225 whp and 223 lb/ft.
So without help from a bigger fuel system from the factory me might get stuck with relatively little room to improve engine performance.
Direct injectors and their ultra high pressure fuel pumps are very proprietary.
Old 02-05-2010, 07:02 PM   #39
Midship Runabout
-Mike
ATS 2.3L Stroker!!!!!!!!
ha i almost forgot the ft will have direct injection.
Old 02-05-2010, 07:40 PM   #40
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
Weren't the rumours that the FT would have dual injection? Direct + Port ?
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-05-2010, 08:08 PM   #41
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Yep and those rumors stated that the car would run totally on the direct injectors at high RPM. But who really knows?
Old 02-05-2010, 08:47 PM   #42
Matador
hashiryu
Drives: Mk4 Supra
Do I really have to explain that to you?
-Mike
You will soon
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 03:55 AM
