View Poll Results: Should the Toyota H4 Support Flex-Fuel (E85)
Yes, It should be E85 Compliant. 12 48.00%
No, It should run on regular Fuel (91) 13 52.00%
Voters: 25. You may not vote on this poll
Old 02-04-2010, 06:43 PM   #1
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
E85 Fuel?
EDIT :: Figured out how to add a poll!
Also :: Due to me being an idiot, I'd like to revise the poll but I don't know how. Suppose thats out of the question since the poll is now active?
I also want to begin a discussion about what flex-fuel is, what its primary benefits and disadvantages are.
How it works in an engine, and how it may work in a H4 with DI.
Please note, this post is for those of us who know absolutely nothing about the flex fuel... I suppose I could JGID (When you don't know, JUST GOOGLE IT DUDE!) .. but I'd rather have a constructive topic here instead.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-04-2010, 07:04 PM   #2
S2KtoFT86
Resident Post Whore
S2KtoFT86's Avatar
Drives: 2022 WR BRZ
Great, now Matador and whoever Biggie is can continue their argument here. Getting out the
Gavin
S2KtoFT86 is offline   Reply With Quote
Old 02-04-2010, 07:11 PM   #3
Siriusly.Andrew
To be entirely honest, I really do I want to have that debate continue, but I am also interested to discover what they know to also improve what I know. At the moment, on this given topic I know absolutely nothing :P
Old 02-04-2010, 07:22 PM   #4
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Drives: '08 xB '07 Yaris '06 EVO9 '89 240SX
The poll's wording is misleading: All E85 compliant means is the fuel system can accept Ethanol, the ECU can tell the percentage of Ethanol in the fuel and the fuel injectors are big enough to support the extra fuel needs. The car would still be able to run 91, it would just have the option of also running E85. I'll explain the added performance benefits later today, when I have more time. But needless to say, saying no to flex fuel only limits the car's out of the box potential.
Biggie™ is offline   Reply With Quote
Old 02-04-2010, 07:35 PM   #5
Matador
hashiryu
Drives: Mk4 Supra
How exactly do you contend that it limits the potential?
Matador is offline   Reply With Quote
Old 02-04-2010, 08:33 PM   #6
Biggie™
Stassenkämpfer
Biggie™'s Avatar
I like the people that admitted to not knowing anything about the fuel just checking NO.
Anyway... Where to start, I guess with the basics:
1. E85 has an octane rating of 105. The higher the octane rating the more compression, boost and timing you can safely run. These all increase power.
2. Ethanol evaporates at a relatively low temperature. The effect of evaporation does two main things to increase engine performance:
2a. The effect of evaporation cools the intake charge(the same way a methanol/water injection kit works). This increases the density of the intake charge, more fuel and air are then allowed into the cylinder. More fuel and air makes more power.
2b. The effect of evaporation cools the intake manifold and intake valves. This helps reduce detonation and allows even more boost and or ignition timing. This also helps cool the entire engine, thus while running E85 the engine will run cooler longer.
3. E85 has a much lower stoichiometric fuel-to-oxidizer ratio. This means it takes less air to burn the same amount of fuel, or you can add more fuel to the same amount of air to produce more power. This might confuse some people as Ethanol actually produces less power per gallon than gasoline. But the fact you can burn so much more E85 with the same volume of air allows it to make noticeably more power than gasoline on the same engine.
So, to sum it all up. On a car capable of running both E85 and normal gasoline, when running E85 the car can run more fuel at higher boost and with more advanced timing. Thus making considerably more power with just fuel and a basic tune.
Does that make sense?
Old 02-04-2010, 08:51 PM   #7
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
^ very well put.
and i thought it was a higher octane than 105? i could and possibly will be wrong.
plus you can say your going GREEN so you can flip off all the prius drivers.
(no offense prius drivers )
Midship Runabout is offline   Reply With Quote
Old 02-04-2010, 08:54 PM   #8
Midship Runabout
and what would it hurt if it did have flex fuel capabilities. its not like you must run e85 only. it would be a bonus that doesnt really have any negatives. dont use it if you dont want to.
Old 02-04-2010, 09:11 PM   #9
Siriusly.Andrew
so because it uses more E85 with same amount of air, it would burn more fuel per say, so you end up at the gas station more, yes?
It all makes sense, how it would work that way. and personally, if it ment more trips to the station I don't care. They are all over the place here. I suppose for longer trips though I'd probably use O91 or so if my guesstimate is correct that E85 is consumed quicker.
EDIT :: Sorry for my haste in checking No, just flexing my ignorance :P
The fact that engines can effectively run BOTH fuels makes it worth having, especially if you can take some time and money and get it tuned for E85 if the benefits are there. But if you had it tuned for E85, how well would it run if you were somewhere that didn't yet market E85 @ their pumps?
Old 02-04-2010, 09:12 PM   #10
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
Biggie - thank you for typing that out much better and more thoroughly than I could have.
one thing I seem to remember about E85 is that in extremely cold temps, there can be some cold-start issues. this is probably not a big issue for some of you, but in my area we get temps of -15F in the winter. other than that the main reason i'm not a fan of actually using it on a daily basis is because the loss in fuel mileage.
i hope the FT is E85 ready. i don't have to run it, but they'll give me huge injectors for race gas!
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-04-2010, 09:23 PM   #11
Midship Runabout
dont go there. if you dont have local e85 dont tune for it
Old 02-04-2010, 09:59 PM   #12
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Yes, taking advantage of factory supplied "big" injectors is a plus. Take the MKIV Supra, its injectors were big enough to support massive power gains without an upgrade.
A device like the COBB Tuning AccessPORT would make switching between tunes a snap.
Old 02-04-2010, 10:01 PM   #13
Siriusly.Andrew
So a motor running E85 will hit E before a motor with the same amount of regular fuel will?
Like I said, it's not a huge deal. E85 is offered at every gas station here I've stopped at, and it's cheaper than regular fuel so I don't think I'd have any reason NOT to run it.
Old 02-04-2010, 10:09 PM   #14
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Yes, that is the one drawback. But the cost savings are considerable when measured against a comparable race gasoline. These prices are from last Saturday!
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
