View Poll Results: Should the Toyota H4 Support Flex-Fuel (E85)
Yes, It should be E85 Compliant. 12 48.00%
No, It should run on regular Fuel (91) 13 52.00%
Voters: 25. You may not vote on this poll
Old 02-04-2010, 11:12 PM   #15
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
so how big of a difference is it exactly? would it be feasible to run every day over 87? Or is consumption quite a bit higher?
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-04-2010, 11:16 PM   #16
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Drives: '08 xB '07 Yaris '06 EVO9 '89 240SX
I would expect at least a 40% increase in consumption. So it would basically take you 14+ gallons to go as far as you would have gone on 10 gallons of gasoline.
Biggie™ is offline   Reply With Quote
Old 02-04-2010, 11:19 PM   #17
Siriusly.Andrew
But you'll get there faster :P
Old 02-05-2010, 12:17 AM   #18
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
But if you had it tuned for E85, how well would it run if you were somewhere that didn't yet market E85 @ their pumps?
it would be tuned from the factory for E85. switchable maps would allow it to run on either fuel.
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-05-2010, 12:36 AM   #19
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by Biggie™ View Post
I like the people that admitted to not knowing anything about the fuel just checking NO.
Anyway... Where to start, I guess with the basics:
1. E85 has an octane rating of 105. The higher the octane rating the more compression, boost and timing you can safely run. These all increase power.
2. Ethanol evaporates at a relatively low temperature. The effect of evaporation does two main things to increase engine performance:
2a. The effect of evaporation cools the intake charge(the same way a methanol/water injection kit works). This increases the density of the intake charge, more fuel and air are then allowed into the cylinder. More fuel and air makes more power.
2b. The effect of evaporation cools the intake manifold and intake valves. This helps reduce detonation and allows even more boost and or ignition timing. This also helps cool the entire engine, thus while running E85 the engine will run cooler longer.
3. E85 has a much lower stoichiometric fuel-to-oxidizer ratio. This means it takes less air to burn the same amount of fuel, or you can add more fuel to the same amount of air to produce more power. This might confuse some people as Ethanol actually produces less power per gallon than gasoline. But the fact you can burn so much more E85 with the same volume of air allows it to make noticeably more power than gasoline on the same engine.
So, to sum it all up. On a car capable of running both E85 and normal gasoline, when running E85 the car can run more fuel at higher boost and with more advanced timing. Thus making considerably more power with just fuel and a basic tune.
Does that make sense?
1- high octane gas will produce the same effect more efficiently
2- That same evaporation can cause hydrolock at high temperatures
3- Again, you still end up using more E85 to make the same power as a lesser amount of gasoline.
I don't think that anyone who voted no does not know what they are talking about, quite the contrary, they(we) know exactly what we are on about.
Matador is offline   Reply With Quote
Old 02-05-2010, 01:02 AM   #20
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Not true, since E85 can make more power with the same amount of air. The stock turbo in the FT86 will be able to produce more power with E85. The E85's cooling effects will also let the stock turbo be effective beyond its normal efficiency range, pushing more air, making even more power.
You seem confused. Evaporation is the point when a liquid turns into a gas. You can compress a gas(no hydrolock). The low evaporation temperatures of Ethanol would prevent it from remaining a liquid(no hydrolock). Also, the combustible nature of gaseous ethanol would prevent it from accumulation in enough quantity to produce a hydrolock situation(no hydrolock).
http://en.wikipedia.org/wiki/Hydrolock
110 octane leaded is $8.55 a gallon which is comparable to E85 at $2.35 a gallon.
Oh, really?
Please note, this post is for those of us who know absolutely nothing about the flex fuel..
Sorry for my haste in checking No, just flexing my ignorance
Old 02-05-2010, 01:58 AM   #21
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
not that wiki is a 100% guarantee of good information, but:
If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual octane engine tests."
from: http://en.wikipedia.org/wiki/E85, where the citation for this quote takes you to: http://www.ethanolrfa.org/resource/t...pdatedLogo.pdf
Sooo my question to the E85 guru is this: Is the loss of efficiency in MPG, for the typical ~$0.20 difference between E85 and regular petrol, worth only a 1-3 octane boost?
OldSkoolToys is offline   Reply With Quote
Old 02-05-2010, 02:17 AM   #22
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Sooo my question to the E85 guru is this: Is the loss of efficiency in MPG, for the typical ~$0.30 difference between E85 and regular petrol, worth only a 1-3 octane boost?
Okay, I thick these are the official numbers:
E85:
Research Octane Number: 113
Motor Octane Number: 94
Anti-Knock Index (R+M/2): 104
Here is a GT-R running 92 octane Vs. E85, seeing an improvement of 61 hp and 73 tq from E85. The GT-R wasn't designed to run E85, so they had to upgrade injectors and fuel pumps. But other than that, both setups were identical. Click the graph to read the blog.
Old 02-05-2010, 02:33 AM   #23
Matador
hashiryu
Drives: Mk4 Supra
Oh, really?
Same amount of air, same amount of air.... we are talking about fuel here.
In my haste to post I wasn't very clear. E85 CAN cause hydrolock in your engine at high temperatures, especially if your car is stored for a long period of time.
Finally, you quoted the same person twice.
Old 02-05-2010, 02:44 AM   #24
Biggie™
Stassenkämpfer
Biggie™'s Avatar
We are talking about air and fuel, that's how an engine works. E85 takes less air to burn. Thus with the same amount of air you can burn more fuel, making more power. Simple stuff.
Um ya... Gas does the same thing. Just fill up before you store your brand new FT86 for a few years and it wont absorb too much water from the air in the fuel tank.
But the quotes are from two different post, proving my point.
Old 02-05-2010, 02:56 AM   #25
Siriusly.Andrew
< still learning
waving the ignorance good-bye gradually.
EDIT :::
observation so far :: It takes the same amount of AIR, but requires 30+% more FUEL to produce the same BANG. BANG drives us to the station to get more FUEL.
Is it worth the price difference at the pump?
Old 02-05-2010, 03:34 AM   #26
Biggie™
Stassenkämpfer
Biggie™'s Avatar
If we use that GT-R's results as an example. Would an 11+% bump in HP be worth the extra fuel costs over regular gasoline. And when you don't need it you just fill up with normal gasoline?
Anyway, there is a ton of information online about running E85 in factory turbo applications. I'm not planning on daily drive my FT86, so E85 is a great alternative to expensive race fuel. You just have to do research and find out what works best for your needs.
Old 02-05-2010, 04:10 AM   #27
Lexicon101
Inexperienced
Lexicon101's Avatar
Drives: Crappy old '90 civic. Frankie.
11+% boost, but the graph shows right there in the legend that the setups on the car are different.
I want to see the same setup produce those numbers. Then I'll take your claims of HP boosts srsly.
Lexicon101 is offline   Reply With Quote
Old 02-05-2010, 09:30 AM   #28
S2KtoFT86
Resident Post Whore
S2KtoFT86's Avatar
Drives: 2022 WR BRZ
This. And you can't use one person as your sample size and then generalize that for everyone.
Gavin
S2KtoFT86 is offline   Reply With Quote
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 03:55 AM
