Old 04-24-2013, 02:21 AM   #29
Turdinator
Señor Member
Turdinator's Avatar
Had a strange occurance earlier today. Dumped the clutch from 3k and floored it with TRAC/VSC off (both orange lights illuminated on dash) and obviously spun the rear tires, but as the car started to move sideways (after moving forward several feet) wheel hop occurred; that's not odd. What's odd is that the slip light illuminated when the wheel hop occurred. Theories? Ideas?
Tires are Michelin Pilot Super Sports in 225/45/17 and this occurred in the dry, albeit at a temperature bordering on "cold" when it comes to summer compounds.
Its the 'virtual diff' coming on. Due to how torsen diffs work if one wheel is in the air it will free spin. When the virtual diff detects a wheel in the air it applies the brakes to that wheel and flashes the slip light even with the nannies off. The only way i know of to disable the virtual diff is the pedal dance.
1974 TA22 Celica
2013 86 GT
The Following 3 Users Say Thank You to Turdinator For This Useful Post:
civicdrivr (04-24-2013), CSG Mike (04-24-2013), jeepmor (04-28-2022)
Old 04-24-2013, 03:22 AM   #30
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by WillBRZ View Post
I get the worst wheel hop around corners. Kinda freaks me out when it's a 100+ foot drop if I don't hook up around the corner. I used to drive that road all the time in my old cars and never had any issues. It's like I can't push this car as hard as I want to because it starts hopping around corners.
Nannies on, or nannies off? If it's Nannies on then it may be them kicking in which can feel like wheel hop. First time I felt them kick in while cornering I thought I'd run over a patch of gravel (Which is almost the same effect as wheel hop).
If that's the case they are doing what they are supposed to do and you should feel more secure
Panman is offline   Reply With Quote
Old 04-24-2013, 09:10 AM   #31
OrbitalEllipses
Drives: Attitude
Thank you sir!
Old 04-24-2013, 06:01 PM   #32
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
We're getting wheel hop / wheel spin at the track while running slicks - its always mid corner / corner exit as we are rolling back on the power. This car would probably be .5 sec to 1 sec faster per lap if we could get rid of it.
GTM_Challenge is offline   Reply With Quote
Old 04-24-2013, 06:19 PM   #33
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
i have a good amount of suspension parts and some bushings, i have never found wheel hop to be a problem, wet or dry spinning tires
never noticed it stock either, but i have not tracked it yet.
Jesse is offline   Reply With Quote
Old 04-24-2013, 06:25 PM   #34
GTM_Challenge
Drives: On track
We only notice it at the track when running r-comps or when in the mountains pushing it pretty good.
Old 04-24-2013, 06:28 PM   #35
Jesse
wheel gap
Jesse's Avatar
yeah, much different scenario than.
do you have any bushing upgrades? sorry if i missed it.
car does look great from the pics in the journal
Old 04-24-2013, 06:40 PM   #36
GTM_Challenge
Drives: On track
Car is all stock minus KW Clubsports and wheels/tires. We're wanting to experience the car as our customers will - weaknesses and all.
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Jesse (04-25-2013)
Old 04-24-2013, 07:30 PM   #37
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
Originally Posted by Pete156 View Post
Obviously these cars were designed with rear slippage in mind, never intended for the rear to actually 'hook up'. I don't think it's possible to experience true wheel hop with the Primacy summer tires, unless you air down. Once OEM tires are replaced these traction issues surface. Bushings do help a great deal IMHO.
Very possible, i got tons of wheel hop with the stock tires and i tried messing around with tire pressures. I haven't tried/tested the PSS out to see if they do the same. This reminds me of my 300zx days. Those beasts have tons of wheel hop. We tried to alleviate the problem with subframe spacers/bushings which calmed some of the hop on my Z down but not all of it. I bought the whiteline subframe bushing kit to try and address this issue on the FR-S; guess i will be needing more than those to fix the hop.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 04-25-2013, 12:02 AM   #38
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
most of the time in VSC SPORT. I feel like the car looses traction way to easily. and because of this I don't trust it with traction off all the way.
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 04-25-2013, 09:45 AM   #39
Mac1235
Mac1235's Avatar
I notice wheel hop quite badly when it is damp or wet outside and the nannies are off. The shifter bounces around like mad which is a little bit concerning, it can be kind of violent. I get this quite regularly if it is wet or if you hit a slight bump under acceleration. I am going to pursue some suspension fixes and see how it turns out.
Mac1235 is offline   Reply With Quote
Old 04-25-2013, 10:17 AM   #40
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Wouldn't a stiffer motor mount prevent wheel hop? Plenty of WRX/STi(And Hondas) combated wheel hop by doing this. A stiffer rear differential bushing will probably help too I think
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
Jesse (04-25-2013)
Old 04-27-2013, 02:46 PM   #41
JerryMichaels7
Drives: Whiteout FRS
I was at the local drag strip the other night( first time ever) just having some fun and it was either spin in first, full throttle launch or wheel hop from hell with a 1/2 ass launch at about 1/2 throttle both from about 5k. Figured it was just better to spin then have the whole drivetrain shake so viloently.
JerryMichaels7 is offline   Reply With Quote
Old 04-27-2013, 05:00 PM   #42
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
simple fix turn off all nannies....... Dont do this if you dont know what your doing of course or else we will have another wrecked twin
SMOKETREES is offline   Reply With Quote
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 10:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
