Old 01-25-2013, 05:49 PM   #1
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Wheel Gap & Wheel Size
I'm not the most cluey on these things so was hoping if someone can please confirm if wheel size affects the wheel gap, specifically when lowering?
Is there a formula that can work out the final wheel gap given suspension height and wheel size?
I'm thinking of rockin' 18"/8.75" with 235/40/18 and installing the Eibach Pro Kit.
While I would love to get the Sportline, I don't want the hassles that come with such a drop (scrapes/discomfort). I'm hoping getting the 18"s will close the gap even more.
white_knight is offline   Reply With Quote
Old 01-25-2013, 09:05 PM   #2
df.dima
Drives: FR-S and Mazda 3 Sky
Simply going to 18s would not "close the gap", it depends on the tire size you choose. I personally like this calculator: http://www.miata.net/garage/tirecalc.html
Taller tires will "close the gap", but will throw the speedo off as well. The size you mention is almost 1" taller (actually 245/35 would be closer to stock height), so with Pro kit, you will close the gap a bit by 1" +0.5" (half of total tire size increase). I think it's a bit too much of a difference in tire size.
df.dima is offline   Reply With Quote
Old 01-26-2013, 12:43 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I ran 235/40 all around on that same size and verified speedo was still accurate, if anything its off stock. Check my build thread or the wheel gallery and you can see it, closes the gap very nicely but still no scraping or rubbing.
H Tech springs but you get the idea
http://www.ft86club.com/forums/showp...1&postcount=49
JoeBoxer is offline   Reply With Quote
Old 01-26-2013, 01:46 AM   #4
white_knight
Hey Joe, what drop have you got?
Old 01-26-2013, 02:17 AM   #5
JoeBoxer
JoeBoxer's Avatar
Tein H Tech springs right now, probably changing out to Eibach coilovers or GC in a couple months though.
Old 01-26-2013, 04:14 AM   #6
white_knight
Sorry, meant to ask how much lower is it with those springs?
Old 01-26-2013, 09:35 AM   #7
JoeBoxer
JoeBoxer's Avatar
1" front, .8" rear
Wish i had went lower in the back but was trying to keep from having to buy camber correction parts, it didn't matter my car was out stock.
Old 01-26-2013, 10:01 AM   #8
cruzinbill
Drives: Argento 6spd FR-S
*sigh* shoulda got the Cusco Zero-3X's
cruzinbill is offline   Reply With Quote
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-07-2012 11:19 PM
Wheel Size vs. Balance jellygorilla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-11-2012 01:23 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
