Old 04-22-2013, 12:52 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by Enraged21 View Post
So looking into it more I'm going to end up getting Eibach sportlines. But some people are saying I'll need a camber kit and/or some LCAs? What would be good to go with the Eibach sportlines?
I would think hard about your priorities before making any commitments.
What's the order of importance here:
Ride quality
Cost (What is your total budget for ALL suspension parts, including install)
Stance/drop
Performance
Tire wear/life
The more information you can provide me, the better I can guide you.
Old 04-22-2013, 12:57 PM   #44
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Ride quality
Stance/drop
Performance
Tire wear/life
Ride quality stock or a little firmer.
I guess I don't have an actual budget but don't want to spend too much. If I have to hold out for a more priced item, I'll hold out.
Want to drop it to get rid of the wheel gap / possibly get better handling
Performance wise, I really don't auto x or track. I just don't want to affect the suspension geometry by any means. It's great as it is. If I can make it better, I will.
Enraged21 is offline   Reply With Quote
Old 04-22-2013, 01:38 PM   #45
CSG Mike
CSG Mike's Avatar
Reconsider the statements in bold. They're mutually exclusive. You can *correct* changed geometry, but it will still not be the same.
Old 04-22-2013, 01:42 PM   #46
Enraged21
#RememberTheBuster
Enraged21's Avatar
If I drop it to remove wheel gap I understand it'll change the suspension geometry. I just don't want it to worsen than it was stock. I would rather make it improve if possible, while getting rid of that wheel gap.
For a daily driver, if I decide to go with the Eibach sportlines, are front crash bolts and rear LCAs necessary?
Old 04-22-2013, 01:45 PM   #47
zoomzoomers
zoomzoomers's Avatar
Just throwing this out there, but the stock suspension is pretty darn good on the twins. If you're just looking for a bit more low, just get some springs and you should be good. If your budget allows, get something reputable. I mean you just spent $25k + on a great handling car, do you want to throw that out the window because you want to save $500? If so, I'd think that staying with the stock suspension on lowering springs would be a better route.
Old 04-22-2013, 01:51 PM   #48
CSG Mike
CSG Mike's Avatar
Correcting the geometry changes will cost you far more than the springs will. Unless you're serious about motorsport, I'd suggest you spend the extra money on a set of coilovers.
Lowering springs on stock shocks will worsen ride quality (damping quality) and simultaneously alter your suspension geometry for the worse. At least a cheap set of coilovers can improve ride quality AND overall handling. Geometry is gonna have to be sacrificed unless you're willing to spend a lot of $$
Neither LCA nor crash bolts are necessary. LCA can be usd to *remove* camber from the rear for tire wear, but the camber increase will give you more cornering grip. Which do you want?
Old 04-23-2013, 09:45 AM   #49
EnjukuAK
Drives: 1996 Nissan 240sx, 1999 Lexus GS300
That could not be less true. A well damped (and properly set up) system will ride *better* than stock. You'll have a very refined ride where you know exactly what is going on with the road (whether it's bumpy, smooth, rough, etc.) but without jarring, intrusive feedback and enhanced cornering grip.
Most people attribute that as a more harsh ride because they can feel what is going on beneath them, and therefore it does not ride as 'smooth' or good, so in their minds it is a compromise in ride quality..
With that being said we had some very nice 3 way coilovers on some of our race cars as well as one of the sales guys Z33's, and they did ride incredibly good for full coilovers when dialed in properly.. But then again, the ability for your average consumer to properly adjust rebound/damping on a coilover like that to achieve those results would be a bit questionable I would think.
EnjukuAK is offline   Reply With Quote
Old 04-30-2013, 03:41 PM   #50
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Have a set of OTS Stance CO's on the way... I'll try to have someone dyno them prior to me getting back to the states, however I can't promise it will get done before I arrive.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-30-2013, 11:52 PM   #51
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I have the Tein Monoflex. I don't feel qualified to 'review' them (since this is the only coilover I've used on the car) but they are very comfortable given the high-ish spring rates (8k F/9k R). The range of adjustability is quite large, so much that at full soft it felt like a crown vic with 15 year old suspension, and full hard felt like a go kart
dori. is offline   Reply With Quote
The Following 2 Users Say Thank You to dori. For This Useful Post:
Anthonytpt (05-02-2013), CSG Mike (05-01-2013)
Old 05-01-2013, 03:02 PM   #52
ShikoBariki
Drives: 89 240sx S13 SR20DET, 13 FR-S
I'm so lost
you need to figure out if you want this car to be built for track/driving or purely stance. Thats when you will know how much you want to invest in it. For example you dont need a kwv3 if all your going for is stance although if you want some ride quality some 1k coilovers are not that bad unless you are real anal about how you want it to ride. This is when your going to determine how much you want to invest in the car. Same thing with bolts on for power you do your research and hear he say she say and go with what you feel like is good to you but in suspension you do the same just alot more. Suspension should never be taken lightly. Alot of things factor in what you are trying to achieve for your car. You will invest majority of your money for a first step build to get the suspension right as oppose to basic bolt ons. Save your money and figure out what you are trying to achieve for your car.
ShikoBariki is offline   Reply With Quote
The Following User Says Thank You to ShikoBariki For This Useful Post:
Enraged21 (05-01-2013)
Old 05-01-2013, 03:05 PM   #53
CSG Mike
CSG Mike's Avatar
It's so difficult to explain to people that high spring rate =/= harsh ride. It's all in the dampers...
Old 05-01-2013, 03:36 PM   #54
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Agreed, but big hits benefit from a lower spring rate and more travel.
SubieNate is offline   Reply With Quote
Old 05-01-2013, 08:59 PM   #55
dori.
Señor Member
dori.'s Avatar
yeah well that is something I do know (especially now that I've played with the dampers), its just I see a lot of people complaining about some coils having 'high' spring rates and it doesn't really affect the ride much
Old 05-01-2013, 09:05 PM   #56
EarlQHan
Drives: Subarus
This is the most basic equation for creating a spring-mass-damper system
It's not easy to get right, BUT, as Mike said, high spring rate does not necessarily mean a harsh ride, but is a generality. If people want, they can plug in their numbers (if you know them) to see what your damper-spring combo is doing.
EDIT: It should say MASS, not WEIGHT in the key.
EarlQHan is offline   Reply With Quote
The Following 3 Users Say Thank You to EarlQHan For This Useful Post:
CSG Mike (05-01-2013), SubieNate (05-02-2013), WillRacer1jz (05-01-2013)
Rim/tyre choice for performance acro Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-20-2013 08:20 PM
What is your first mod choice? genometuning Scion FR-S / Toyota 86 GT86 General Forum 43 08-31-2012 12:53 PM
Rim Choice on Whiteout FR-S Kwickfox Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2012 12:07 AM
