Old 02-17-2013, 07:25 AM   #1
acro
Drives: GT-86
Rim/tyre choice for performance
Ok so i have the stock 16 inch rim (comes on the base gt model)
This rim weighs 15.9 lbs according to reports and comes with a 205/55 16 tyre
i had planned to upgrade to enkeis http://www.tirerack.com/wheels/Wheel..._19&sort=Brand
which weigh 18.2 pounds.
The tyre i would use would be the continental extreme DW.
the question is since the 16' wheels weigh 2lbs less each which would perform better the 16' with 205/55 conti tires or the 17' with 215/45 tires
acro is offline   Reply With Quote
Old 02-17-2013, 07:36 AM   #2
Burrcold
Drives: Subaru BRZ Limited
I would say the 17's since you are putting a slightly wider tire on, that will get a bit more grip. And the fact that you're going to a much lower profile tire will help take the flex out and keep you planted.
I wouldn't worry about the weight at all. The other thing to consider if you really are hung up on the weight, is how much the tires weigh. You might find the bigger, but lower profile 17 weighs slightly less. I'm grasping here but I think you get my point.
Old 02-17-2013, 07:15 PM   #3
acro
Drives: GT-86
Any other thoughts?
Old 02-17-2013, 09:41 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
Define perform..
Old 02-17-2013, 09:50 PM   #5
acro
Drives: GT-86
Originally Posted by mad_sb View Post
Define perform..
Accelerate Corner and Brake better.
Basically looking at unsprung weight vs increased tyre contact patch.
Old 02-17-2013, 10:47 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
RPF1's, 17x8 weigh 15.6 lb., 17x9 weigh 15.9 lb.
Continental DW weighs 20 lb. in 225/45-17, 22 lb. in 245/40-17
Michelin Pilot Super Sports weigh 22 lb. in 225, 23 lb. in 245
235/40-17 might be a very good tire size, but not many make/model options in that size.
Old 02-17-2013, 11:08 PM   #7
acro
Drives: GT-86
Saw the rpf1's but not liking the styling.
not really looking to go beyond 225 tire size
Old 02-17-2013, 11:20 PM   #8
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
O.K. no Enkei RPF1, so how about one of these:
Kosei K4R 17x7 14.0 lbs
Kosei K4R 17x8 15.8 lbs
O.Z. Alleggerita HLT 17x7.5 15.4 lbs
Old 02-18-2013, 03:27 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
A little heavier, but look great: Enkei PF01 17x7.5 = 16.8 lb., 17x8 = 17.4 lb
Old 02-18-2013, 04:53 PM   #10
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
CE28N 17x9 +43 5x100 with some grippy 245/40-17
Probably it's the best wheel choice for low weight, strength, and big brakes clearance
adprokid is offline   Reply With Quote
Old 02-19-2013, 08:21 AM   #11
acro
Drives: GT-86
Ok some great rim choices here. Much thanks guys
Are Kosei rims strong?
Old 02-20-2013, 06:12 PM   #12
Mitch
form follows function
Drives: RIP '13 BRZ
They just cost three times as much as an RPF1.
They're not particularly resilient, no, but they're very affordable. I'd be careful with potholes, but otherwise not worry about them daily driving.
Mitch is offline   Reply With Quote
Old 02-20-2013, 08:20 PM   #13
fatoni
they make one of the most popular spec miata rims so i think for what youre doing, they will be alright.
Tyre Thoughts Captain Snooze AUSTRALIA 15 02-24-2013 08:44 PM
Choosing a tyre brand white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-20-2013 10:02 AM
More grippy tyre only front. Mars2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-08-2012 07:02 AM
Tyre pressures st162celica AUSTRALIA 6 08-08-2012 05:25 AM
Tyre you will be getting Staticfrost AUSTRALIA 38 06-22-2012 09:02 PM
