Old 04-20-2013, 09:58 PM   #29
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
Originally Posted by KSC View Post
Ugh! Not trying to be a jerk, but couldn't you have said that up front? For 3 weeks you had everybody thinking, "Oh shit, now what?!" and all the while this issue is most likely due to the factors above.
So many threads detailing issues and 9/10 cases it's probably due to AM stuff. Not that I'm against it, but If I had a dollar for every problem thread that mentions, "...I have a CIA...", I'd be able to buy my own!
Conspiracy!! :P
OP: Have you talked with Visconti about your issues? Done any datalogging?
|-Goku-| is offline   Reply With Quote
Old 04-21-2013, 05:24 AM   #30
peachch
Drives: White 86 Sport Plus
I didnt mean to create an issue here. I was out of the country almost two weeks and did not have internet access. Anyway, It was my mistake that I did not give enough information at the beginning. Before the Tune, my car was completely stock except K&N filter.I used 95RON E10 which is regular gas here. It is very difficult to find 100% gasoline in my country. Mileage was around 14,000mile before tune. About a month ago, I got visconti E20 tune. Then, I replaced my mid pipe. About a week after, I got Cel and found out about spark plug issue.
Sorry to bother you guys. I just want to share what I found.
Originally Posted by |-Goku-| View Post
Conspiracy!! :P
John mentioned that the damage may be caused by gasoline quality. I have done some dataloging. They looked okay excpet oil temp is quite high, 250F, when I drove hard on the high way.
After I have popping sound, i took the plug off to check and found out about the plug gap.
peachch is offline   Reply With Quote
Old 04-22-2013, 03:17 AM   #31
peachch
Originally Posted by vubaru View Post
I get the C1201 with a different set of codes (P000B/P0014/P0019) which also trigger the slip light/traction light and CEL light. I haven't had the misfire code.
I think C1201 is just a general "hey something is wrong" DTC code which pulls power.
In my case, It started from P0301 and other codes came later when I was driving to the shop. I think P0301 came up because the spark plug damage.
Old 12-21-2013, 12:30 PM   #32
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
hi Peachch, same issue today on the track engine and traction on, just past 30 000 km ( 14000 mile) running a trubo and 95 on the pump. Did the plug replacemet fix your problem and what plug did you use.
Jacques Blom is offline   Reply With Quote
Old 12-21-2013, 04:37 PM   #33
fradet
Drives: sentra ser
Im not an expert in tuning, but you might take a look at the 2015 subaru wrx to see which spark plugs they are using since they are also using the FA20.
fradet is offline   Reply With Quote
