Drives: White 86 Sport Plus
Spark Plug Broken : CEL P0301 C1201 and U0100
I have 15000 mi on my car. The CEL and Traction control light are both on this morning ans it shows CEL P0301 C1201 and U010. Anyone experiences this? The car run very rough and no power.
Drives: 2013 Subaru BRZ
The P0301 is a misfire in #1 cylinder. That's why your car is running rough. The other codes are likely there because of the P0301. Take it to your dealer and let them diagnose it (hopefully you're still under warranty).
#3 | |
The spark plug looks very bad. My car has only 15000mi. |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Yea the plug shouldn't be broken like that.
Two of them went so bad. Here is another plug picture.
Drives: GT86 DGM
Wow.... Hope they figure this out. Keep us posted!
Volunteer Fire and Rescue
Drives: Ambulance... sideways.
Main concern #1: Where is the missing metal from the spark plug. Did they find it or did it fall into the combustion chamber, and how much damage did it do in there.
Main concern #2: Why did the spark plug break like that in the first place. Question: do you have any modifications, a tune, anything?
It's more fun to drive a slow car fast, than a fast car slow.
Drives: Subaru BRZ
Are those stock spark plugs? What brand are those?
Drives: 4wd zooks
The metal from the plugs might just have arced away and not caused any damage.
Was the engine lifted and slid forward to remove the plugs? |
#10 | |
#11 | ||
They are stock. I replaced them with HKS M45HL because I do not have other options. |
#12 |
Drives: BRZ WRB LTD MAN
[QUOTE=peachch;838153]No lifted or slid need. You just need 3/8" tool set.
No lift to get the plugs out - now that is good news! Glad it was a simple fix! |
#13 |
Drives: WRB BRZ
Can you do a DIY to remove spark plugs without lift/slide the engine? If you can do that i'm sure a lot of people would be appreciated!
#14 |
Drives: Perrin/VORTECH Supercharger TestBRZ
wondering about your coil pack..suspect timing setup on your tune, namely exhaust timing
...you running a tune?? Last edited by Huehuecoyotl; 04-03-2013 at 11:30 AM. |
