Old 04-16-2013, 11:26 AM   #15
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Originally Posted by firl21 View Post
IS the injun a short ram or CAI?
Im going to turbo/supercharge my car and i need to know what intakes i need to stay away from
stay away from all intake until what kit you want.
lots of kits comes with intake but some uses stock airbox like avo.
So wait until you know what you want, because you probably don't need to buy an intake
shu5892001 is offline   Reply With Quote
Old 04-19-2013, 07:51 PM   #16
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Update?
CircuitJerk is offline   Reply With Quote
Old 04-22-2013, 12:32 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It is the intake 100%. This is a very common issue on cars with MAF sensors close to the filter on aftermarket intakes. Either get an Injen intake EcuTek tune or take the intake off.
Old 04-22-2013, 11:38 PM   #18
CaptainSlow
CaptainSlow's Avatar
I agree it's the intake (I've had similar problems in the past with other cars where the RPMs drop faster than the ECU can account for, and it just stalls out)...although I'm having a hard time visualizing what is going on that would make that happen (physically in the system).
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 04-23-2013, 12:31 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It is the tumbling of the air from the pod filter (Aussie term). The ways to fix it are a different pod filter, an air straightener, moving the MAF sensor to a locaiton with straighter air, or adjusting the tune to compensate. This was an issue on E46 M3 as well.
Old 04-23-2013, 12:34 PM   #20
Sivtec
Sivtec's Avatar
This. Sucks soo much. I have an Injen as well and had the same exact problem even after reflashing the ECU. Will have to get it tuned.
Old 04-23-2013, 03:52 PM   #21
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
This is a common problem with the following intakes;
- AirRaid
- Injen
- HKS
I also have the Injen and it has happened to me as well. More often now that the weather is warming up.
I would strongly recommend re-installing your stock intake until you can get a tune. EcuTek and Unichip both have tunes that will fix this and your car will run properly with those intakes. No need to sell them, they are perfectly fine. Just be aware.
I'm taking mine off tonight and storing it until I get my tune.
Scott
naikaidriver is offline   Reply With Quote
Old 04-23-2013, 03:59 PM   #22
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Just throwing this out there, it seems most aftermarket intakes remove fins that are inside the stock airbox just before the MAF sensor. Why they remove it? Not sure. Why the stock airbox has it? Probably because it makes the reading more stable.
Rayme is offline   Reply With Quote
Old 04-23-2013, 04:09 PM   #23
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
any issues with the Perring intak causing this problem?
Old 04-23-2013, 09:23 PM   #24
deedz
Drives: Rocket Bunny FR-S
Originally Posted by CircuitJerk View Post
Update?
cars been in the shop for a little while so havent really been able to fix the problem but from these posts below I know what to do
- AirRaid
- Injen
- HKS
Scott
thanks for the help! will definetley remove the intake until i get a tune
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
deedz is offline   Reply With Quote
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 01:53 PM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 10:00 PM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 08:38 AM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
