#267 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
So basically someone could start making and selling pre built harness that plugs into the side maker connector and jumps to the foglight h11? Shit I wish I was I'm America
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#268 | |
Drives: Scion FR-S Asphalt AT & XB
#269 |
Drives: Awesome
i used a safety pin and basically unhook it. its like unzipping a ziptie.
#270 |
give us this day
Drives: AE86 - FRS
http://www.ft86club.com/forums/showthread.php?t=34078
full fog light kit put my own kit together for 150 ..
#271 | |
#272 |
Drives: 2003 Camry Blue | 2013 FR-S White
If anyone wants to make harnesses just to sell here's a picture of the harness for reference:
#273 |
Old School Status
Drives: .
is there a complete listing of parts list? i.e. stalk, light harness part/model# etc? TIA.
#274 |
#275 | ||||||
give us this day
Drives: AE86 - FRS
Heres everything you need to know how to install a fog light on your frs..
Here's all the references I used.. FRS Fogs using BRZ Stalk http://www.ft86club.com/forums/showthread.php?t=29263 Fog Light Powered with Factory Stalk and BCM http://www.ft86club.com/forums/showthread.php?t=33025 Scion Frs Fog Lights http://www.ft86club.com/forums/showthread.php?t=27581 for more information and guide please visit these threads above.. ![]() Parts Needed: 1. L&R Fog Lights $84 Quote:
Item#: 83115FJ070 http://subarupartsforyou.com/cp_part...p?partid=23294 H11 Harness $15-25 Any h11 harness you prefer, wether you buy one from amazon.com or get Nigel fog light harness kit. Mounting Hardwares $5 You need 4x m5 or m6 Allen bolts, 4x m5 or m6 washer, 4x nylon m5 or m6 nuts. Extra Harness Pins, to make a new harness with your h11 connectors, to connect to the signal lights connectors. ![]() http://www.ft86club.com/forums/showt...=29263&page=12 Or get the full kit at Ishii Motors http://www.ft86club.com/forums/showthread.php?t=34078 for $385 2. Start by disconnecting the battery 3. Positive Terminal disconnected 4. 3x fuses for the Horn were taken off. Heres a reference http://www.ft86club.com/forums/showthread.php?t=12257 5. Now take off plastic splash guard underneath the bumper, both passenger and driver sides, there 1x 10mm nut you need to take off and 2 pop offs on each side.. 6. take off the plastic cover on passenger side, be patient, you can actually pull it off once you get a corner off. ![]() 7. Now same for the driver side just carefully take off driver side plastic cover 8. Here both driver and passenger side plastic covers are taken off 9. Now its time to take the steering wheel off, first you need to take the airbag off. once again dont forget to disconnect battery off. now go to the cabin and push the pin forward the center of the steering wheel on all three holes. while pulling the airbag itself towards you. Reference http://www.ft86club.com/forums/showt...ghlight=Airbag 10. remove the orange, black harness and ground for the horn off the airbag. remove the nut that's holding the steering wheel, then gently pull the steering wheel towards you. 11. make sure to tape the steering angle sensor so it does not move I used a tape to make sure it does not move, basically you want the orange to be visible in the window just like the picture. 12. remove two bolts to take upper and lower plastic steering cover. Quote:
![]() 13. now remove the white connector on the steering angle sensor 14. remove all off the sensors underneath, the yellow one is a tricky one you actually need to push it from the end. Quote:
16. Then unclip the clip on the 9 oclock position to remove the steering angle sensor 17. Finally, unclip the clip on the 3 oclock position to remove the steering anlge sensor 19. You need to remove the wiper switch first before you take the light switch stalk. ![]() 18. After removing the sensor, locate the clamp thats holding the switch, the clamp is at the back at your 12 oclock, just squeeze the clamp thats holding the original stalk switch at the back and wiggle the stalk out towards you.. It might take some time but be patient and wiggle it in and out towards you. The idea is to push it away first to get it off the notch that's holding it then quickly pulling it towards you. 20. you should see this when you take the original stalk switch while depressing the clamp and pulling it towards you. Quote:
22-23. take off the original turn signal lights driver and passenger side harness, and make a new one by putting a new pin on the fourth slot. and tappping into the black wire for ground. Refer to.. Quote:
24-25. install fog lights. your choice of hardwares. Just so you know the top is larger than the bottom. So you might wanna buy two different sizes of bolts. Also an Allen stylel bolts works best for me. ![]() 26. you should now end up with this ![]() 27. turn fog light switch on 28-29. enjoy! 30. Also ere is a fog light indicator inside the cabin! For more higher resolution pictures please click the link below: http://s1353.photobucket.com/user/im...%20Light%20FRS If youre having s hard time following you need to read the first three references for you to fully understand what is going on.. Please take the time to do some research... as I did as well.. But I hope these pictures will guide you.. If you have any questions feel free to send me a message!! Have a good one! To the op's , if you guys have any suggestion on the write up I can make some changes. As I was rushing typing this down..
#277 | |
Drives: Awesome
#278 |
First 86 Driver Baby!
Drives: FR-S, Flex
#279 |
give us this day
Drives: AE86 - FRS
btw how come the fog lights does not fit the legacy socket?
| Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 10:54 PM |
| Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 12:44 PM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 05:09 AM |
| new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 03:20 AM |
| for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 12:53 AM |
