Old 02-07-2013, 01:55 PM   #1
Khánh
Khánh's Avatar
Drives: sc00ter
Fogs wiring; Will this work?
I want to wire up my fogs, but I don't know much about wiring. Will this do the job?
Khánh is offline   Reply With Quote
Old 02-09-2013, 09:31 AM   #2
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I had in mind the same setup, I believe it should work
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 02-09-2013, 12:33 PM   #3
Khánh
Khánh's Avatar
Drives: sc00ter
cool. thanks
Old 02-09-2013, 02:18 PM   #4
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
What relay are you using?
This wiring will not work unless it has pins internally tied together.
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 02-09-2013, 09:42 PM   #5
Draco_PR23
Fiebru
Draco_PR23's Avatar
Some one posted this site somewhere "http://autolumination.com/connectors.htm" and I was looking at it and I believe the "2 Channel 4 Blade Relay Pigtail & Plug (Heavy Duty)" should work.
Current Cars:
Old 02-09-2013, 09:49 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Your wiring is fine, don't cheap out on the relay
mashal is offline   Reply With Quote
Old 02-10-2013, 12:09 AM   #7
Khánh
Khánh's Avatar
Drives: sc00ter
will "4 Blade 40 Amp Relay (Heavy Duty)"work ? (it's next to the one u mentioned)
Old 02-10-2013, 08:05 AM   #8
Draco_PR23
Fiebru
Draco_PR23's Avatar
I think it should work too, I already ordered the bezels and the fog lights.
Once I get received them, I will try to figure out the harness and relay. Also I was thinking about getting the harness from Nigel since I will probably buy a few other stuff.
Current Cars:
Old 02-10-2013, 01:57 PM   #9
Khánh
Khánh's Avatar
Drives: sc00ter
i was going to order stuffs from him but i decided not to cuz of backorder and crap haha
Old 02-11-2013, 03:24 PM   #10
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I don't know i am right or not.
if you buy OEM fog light from Subaru, can't you install it Plug & Play on BRZ Premium?
I don't know on FRS
Old 02-11-2013, 03:29 PM   #11
Sco2355
The entire front harness for the car is different on the BRZ than the FRS. I got all the diagrams. It's a single harness that the fogs are wired into versus the FRS harness, the fog wires are non-existant. When my bezels get here we are wiring them up to the OEM BRZ stalk I bought. It doesn't look difficult, just time consuming.
Sco2355 is offline   Reply With Quote
Old 02-11-2013, 05:54 PM   #12
Khánh
Khánh's Avatar
Drives: sc00ter
I don't know on FRS
i dunno.. I should have stated I want to do this on my frs
Old 02-16-2013, 12:44 PM   #13
Draco_PR23
Fiebru
Draco_PR23's Avatar
@Khánh
did you figured out the harness? I just received my bezels and fog lights but havent installed them yet.
Current Cars:
My BRZ Exterior LED conversion (Incl. Fogs) Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 34 06-04-2016 12:01 AM
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
