Old 04-04-2013, 11:11 AM   #127
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by itdansharpe View Post
Dear king tut, I am in the middle of installing this kit, and ran into the threading issue you had with the brass T oil feed. What thread pitch did you run over it to make it fit?
Thanks!
I think it was the only NPT tap and die in my Craftsman metric tap and die set. Let me see if I can look it up, or I will check when I get home.
itdansharpe (04-04-2013)
Old 04-15-2013, 01:19 PM   #128
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Finally got some pics of the kit installed on my car. I also got the 9.4 psi Tial spring in my wastegate, and I am still doing testing to see if it helps hold boost better. I am definitely still getting boost spiking/valleying in the 5000 to 6500 RPM area just running off the wastegate that I really don't understand. I also ordered a GFB electronic boost controller last night to install this weekend. I am determined to get as flat of a boost curve as possible with this kit. @Visconti is also still looking over my logs to adjust my ROM to try and make more power in the upper RPM range.
akuhei (04-15-2013)
Old 04-19-2013, 11:02 AM   #129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Big thanks go out to @Visconti and @akuhei.
So I got my Omni Power 4 BAR MAP sensor in last week to be able to log the actual amount of boost I am running in EcuTek and to get some boost cuts programmed in. Well that meant I needed to flas a new ROM to work with the new MAP sensor. As anyone who has read my first post in this thread knows, flashing my ECU with EcuTek has been the biggest problem I have had since installing my turbo kit. I have never successfully flashed my ECU.
Well I had some free time last night, so I figured I would give it a shot. When John street tuned my car he had no issues flashing it, so I figured this should work no problem. I downloaded the ROM from the support console, and started the flash. I get to about 74% and it fails just like it has every time before. I still had a license on my dongle luckily, so I figure well let me try flashing back to the ROM John gave me when he tuned me. It failed at 85% just as before. So now I am left with a car that won't start and no EcuTek license to try and flash the car again. I have already tried a different laptop and a second EcuTek cable that John sent me and neither made any difference.
At this point I am VERY pissed. A buddy at work had his alternator fail on his family's only car, so I lent him my Tundra yesterday afternoon. With the BRZ out of comission, I now had no vehicle to drive to work today. At that point I contacted John and told him what happened. Luckily he was doing some late night dyno tuning and said to call him once I had a solution, and he would get me another license. Luckily I knew that Kris was running a Visconti tune and had successfully flashed his car with his netbook and EcuTek cable. I hit him up, and luckily I was able to meet him and get his netbook and cable. I figure if this doesn't work with a known good netbook and cable, then it never will.
I updated the EcuTek software on his netbook for my dongle, and I called up John. He had me a new license update in a couple minutes, and I was off to try the reflash. Just after midnight, I started the reflash, and it worked perfectly. I was able to quickly install the 4 BAR MAP sensor and the car fired up and ran perfectly on a test drive. I am now convinced it is either my laptop or cable even though I have tried replacing both already. I think in the future I will just go over to Kris's house to flash my car.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
ALbadboy (04-19-2013), charged86 (04-19-2013), Sportsguy83 (04-19-2013)
Old 04-19-2013, 11:12 AM   #130
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Great to hear its back up and worked out well. I'm glad I was able to help.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
The Following User Says Thank You to akuhei For This Useful Post:
Old 04-19-2013, 11:33 AM   #131
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Glad you got it figured out. Now lets hear some in-depth driving review!
Coheed is offline   Reply With Quote
Old 04-19-2013, 10:20 PM   #132
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Man, now you've got me nervous. I have a new flash to put in my car and sure don't want my car to be down.
kmbkk is offline   Reply With Quote
Old 04-19-2013, 10:28 PM   #133
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Go for it man! Worst case scenario, you have @akuhei's cable and laptop as back up!!
Old 04-19-2013, 10:50 PM   #134
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yeah I know, I'm just being paranoid...while drinking, lol!
The Following User Says Thank You to kmbkk For This Useful Post:
Old 04-20-2013, 12:56 AM   #135
Visconti
Drives: 05 STi
Glad I could help.
Time for a new laptop!
Visconti is offline   Reply With Quote
Old 04-20-2013, 12:54 PM   #136
akuhei
akuhei's Avatar
Yeah, the cable and laptop are closer to you than they are to me..since they are at tut's house right now.
Akuhei's Blog
"Inconceivable"
Old 04-20-2013, 01:47 PM   #137
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Lol, hopefully I won't need them! I'm going to try this afternoon, so keep your fingers crossed.
Old 04-20-2013, 06:17 PM   #138
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Tune uploaded very easily! Now I just have to figure out how to data log with EcuTek!
Old 04-22-2013, 10:43 AM   #139
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I heard you got the datalog working. When can we see this car in person and get a drive?
Old 04-26-2013, 10:22 AM   #140
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am not really good at reviewing things. I think the car drives great, and everyone that rides in it loves the way it feels. I know guys have been calling for more forced induction car videos not on a dyno, so I made one yesterday:
[ame="http://www.youtube.com/watch?v=jTbLvGyPEqo"]King Tut's 2013 Subaru BRZ Full Blown Turbo Driving - YouTube[/ame]
The Following 5 Users Say Thank You to King Tut For This Useful Post:
charged86 (05-18-2013), Coheed (04-26-2013), crook (04-27-2013), GTB/ZR-1 (05-15-2013), OjiGeorge (05-17-2013)
blown, fbm, full, king tut, turbo
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 08:27 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
