Drives: Rocket Bunny FR-S
Moving in neutral....Engine turns off?
So this has been happening since I can remember every once and a while but the other day it happened twice in 2 minutes
Basically at 40mph I popped the car into neutral and all of a sudden the engine turned off and rpm dropped. A bunch of lights showed up like the TAC sweep lights ( tracation control, battery light, oil light, ABS light, engine light and the steering wheel light) so while i was moving in neutral I started the car again. Then another minute later I come to a complete stop and put the car in neutral again and the car turns off...it kind of concerns me that this has happened multiple times and I have no idea what it may be? Anyone experiencing similar issues? |
#2 |
Now w/ over 400 womprats!
Drives: BRZ LZR
New start/stop feature?
![]() I'm not sure what it is, but you should def. get it checked out by the dealer, sounds like a bad problem. It def. shouldn't be doing that from just going in Neutral.
- The Ancient BRZ Sacrament by Zaku |
#3 |
Drives: 6MT
Are you leaving it in neutral at 40mph and coasting?
#4 |
Drives: '13 FRS - STX
Manual or Automatic?
#5 |
Pull my finger...
Drives: Silver Scion Slushbox
Intake modifications?
#6 |
Yea i pop it into neutral to coast for a second or even when im slowing down from 5th gear to a stop, before the rpm drops low I just pop it into neutral
manual I have an injen intake
#7 |
Sounds like an ECU issue, take it into the dealer and if they're stumped I would ask for a reflash.
The car isn't holding idle rpm's, that's a problem on a brand new computer controlled car, warranty should take care of it. This is assuming the only mod is the intake of course. |
#8 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
I have seen this happen on a BRZ with an Injen intake.
Suggest you re-install the stock intake and try to reproduce the issue.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
#9 |
The Answer
Drives: Mazda 2
That injen sure is some trouble from what I read on here.
#11 |
Pull my finger...
My suggestion would be to reset the ECU by removing the negative cable from the battery and then go over your Injen installation thoroughly. Once you've checked your installation, and you're confident everything is in place and there's nothing unusual, press your horn, turn on your headlights to purge any remaining power from the electronics, wait 5 minutes or so and then reconnect your battery.
If the problem persists try putting the stock intake back on and see if you can duplicate the issue like @deucethemoose suggested. |
#12 |
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
I wouldn't take it to the dealer until you made sure it's not the intake. I can almost bet it is; the same thing use to happen on my Z and it was pop charger related.
-Alex
05 Raven R6 13 Raven FRS M/T |
#13 |
Drives: 2013 Scion FRS WhiteOut
i have an injen intake as well this has happened to me once but after the ecu relearned itself i havent had an issue, guess i got lucky.
![]() Winnipeg, Manitoba |
#14 |
Drives: Scion FRS in hot lava
IS the injun a short ram or CAI?
Im going to turbo/supercharge my car and i need to know what intakes i need to stay away from |
| Beeping after ignition turns off.. | chadstyle | BRZ First-Gen (2012+) — General Topics | 45 | 07-20-2020 01:53 PM |
| Engine shaking/vibrations at 1700rpm - when in neutral/idle | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 11-07-2013 10:00 PM |
| Auto Climate Control turns on randomly | cantaloupe | BRZ First-Gen (2012+) — General Topics | 18 | 03-14-2013 08:38 AM |
| Car rattle at neutral. | IloveBaldEagles | Issues | Warranty | Recalls / TSB | 3 | 12-23-2012 06:55 PM |
| FR-S: Highbeam turns on lowbeam, how to disable? | civicdrivr | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-03-2012 07:08 PM |
