Old 04-12-2013, 06:28 PM   #225
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Sonolin View Post
@Sportsguy83 wow, thanks! That's very impressive & good to hear.
All the other turbos get rid of the cat in the header, which makes this the only (possible) option if I want to hope to get this to pass smog though. But that's pretty exciting stuff, I really like FBM's kit that curve looks amazing.
I am in the same boat as you. I am considering this kit but making my own intercooler piping out of intercooler piping from other OEM turbo vehicles. Maybe change the routing too so it isn't so obvious.
Or just call it a day and buy something CARB certified like vortech or dare I say....INNOVATE lol
The Following User Says Thank You to sw20kosh For This Useful Post:
Sonolin (04-12-2013)
Old 04-12-2013, 07:18 PM   #226
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by jsimon7777 View Post
There's a big difference between knowing generally what to do (free), specifically what to do (takes research and expertise), and actually doing it (expensive). I'm at step 1 of those 3.
It's a lot of R&D (planning followed by trial and error) to get a twinscroll working like a top, so anybody who does it would have to justify it by selling kits or having money to burn. As I said, PTuning knows where to put the turbo. Now they just have to do the R&D for a successful twinscroll then take all of our money.
Of course all the other companies would soon copy the cams, turbo, AR, and so on, but there would be a window of opportunity to make some serious cash.
PTuning has yet to release THIS kit, so probably asking about twin scrolls when THIS kit is not off the ground yet is just misplaced "wants". They are going to take my money without twin scroll...lol. So, would rather focus on this sick ass kick they have currently and save the twin scroll talk for a later discussion.
SnapOv3st3r is offline   Reply With Quote
Old 04-12-2013, 07:27 PM   #227
SnapOv3st3r
FBM from their Stg 1 thread:
AVO stg 1+, with supporting fuel to crank PSI up to 10
Does anyone remember if FBM and AVO were using a stock header when they made those #'s?
One thing about PTuning's setups if you look back with their tC and S2k systems, you will realize how integrated they are. They are VERY methodical down to the 10th degree. When I say they think of everything, they usually think of EVERYTHING. There is a reason why they have taken this long to release the details of their kit. I assure you, that whatever piping route you come up with, won't be as optimal as the original layout they have created here.
Old 04-12-2013, 07:36 PM   #228
Calum
That Guy
Drives: 2013 asphalt FRS MT
Both of those kits must use their manifold/header. This kit retains the stock header and the stock torque dip. Which to me is PERFECT. Just try not to drool while you picture this kit, making that much power at that low of a pressure, with the Nameless header added in. Now, turn the boost up to ten and go pull some stumps out for your neighbours.
As for the piping lay out, there was one kit that had shorter plumbing in and out of the bumper, but it required cutting which would be polarizing at best. I'm certainly not knocking their decision to take this path, just trying to keep things accurate. I'll see if I can find the thread but I don't want to clutter this thread too much.
edit, from what I could find Britz and Greddy both offer the routing I was remembering, but I'm remembering it on another car. It may have been a one off for the ultimate sports car challenge...
Old 04-12-2013, 08:17 PM   #229
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Both kits use their own header.
Old 04-12-2013, 09:53 PM   #230
sw20kosh
I assure YOU that my post and my intentions to use OEM plumbing have absolutely nothing to do with optimization of power...
Hint: I live in a CARB state. The CARB state.
Old 04-12-2013, 10:46 PM   #231
SnapOv3st3r
Which amazes me why there are so many companies based there.
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
Mr.Jay (04-13-2013)
Old 04-12-2013, 11:18 PM   #232
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I've been down the twinscroll road a time or two... or three, or several. Sigh.
I know this is off topic so I'll keep it short. The scavenging effects of the twinscroll design really lend themselves to a mid-range power boost. Transient response is improved, and torque output climbs as well... in the mid-range.
You need a large turbine housing to get the flow from the TS setups in t2 and t3 setups. They just don't flow well. On a flow-bench, a 1.06 T3 housing flows LESS than a .63 open housing. Top end flow always seems to suffer a bit with a TS setup, so it isn't all its cracked up to be. You have to pick your poison; Awesome top end, or tons of mid-range!
As far as cams go, a large duration cam typically doesn't work well with twinscrolls. Backpressure builds rapidly in the housing and the turbo chokes the engine at high rpm. So large duration cams, especially with higher overlap, will not work well with small-mid frame TS setups. You'd have to go with a big-lift, low duration cam to keep overlap levels down, which is counterproductive to higher rpm output. A good TS setup will work well for this engine until 7000rpm or so. But in my experience, the open scroll designs will outperform TS as the revs climb.
If you really want transient response, you should just design your setup for a smaller turbo and save money all around. TS adds a lot of cost and complexity for a comparatively small performance gain.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
ATSAaron (04-13-2013)
Old 04-12-2013, 11:23 PM   #233
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
It's nice here. We can drive on racetracks year round. Anything designed for here is acceptable anywhere else in the country. We love our cars here and have great country roads with corners.
Old 04-13-2013, 09:49 AM   #234
SnapOv3st3r
You can drive on race tracks year round in FL too, and there are no emissions in FL. People love their cars anywhere, Cali is not the only car loving community with race tracks.
You have cops that pull you over for an exhaust system, pop your hoods, measure your headlight to ground clearances...etc. If it was so epic, people wouldn't need to modify turbo setups to try and fool the authorities.
Old 04-13-2013, 10:44 AM   #235
EAGLE5
Dismember
EAGLE5's Avatar
Florida>California eh? Hehehehe.
Old 04-13-2013, 11:47 AM   #236
jamesm
I've tried both, and yes. No state tax, no emissions checks, you can shit without the state coming to inspect it, and you're allowed to defend yourself if need be. California is awesome, don't get me wrong. It's a great place to visit (I go to mammoth every year), but they have no concept of personal freedom or individual responsibility. They banned aluminum baseball bats for Pete's sake. It's a case study in reactionary politics.
Florida is humid, flat, and has lots of fire ants. You can't win them all lol.
Texas is, in my opinion, the best of both worlds. The best of all worlds, really. If I had my choice is be there . So Texas > florida > Cali > everywhere else, IMHO lol.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
SnapOv3st3r (04-13-2013), WRXGuy1 (05-08-2013)
Old 04-13-2013, 01:36 PM   #237
SnapOv3st3r
Oh yea forgot about TX I'm in TN, pretty lax here to. We have emissions based on what county you live in.
Old 04-13-2013, 01:40 PM   #238
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
That's like VA. Down here in Southern VA they don't really care about emissions, but they'll do a visual and safety inspection. In Northern VA its all about emissions.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
