go_a_way1
Old 04-08-2013, 09:32 PM   #1135
bryzter
Drives: 2005 BMW 3 series / 2013 Scion FRS
Hi All.. will i have issues when i run 255/35/18 (rear) +35 offset with 25mm spacer and 225/40/18 (front) +35 offset with 25mm spacer? thanks
bryzter is offline   Reply With Quote
Old 04-08-2013, 09:43 PM   #1136
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yes, you will have issues. That is effectively a +10 offset, will not clear.
You didn't specify the wheel width but with a 10 offset it doesn't matter.
Leave the spacers off and you'll probably be fine.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
ill86 (04-08-2013)
Old 04-08-2013, 09:58 PM   #1137
bryzter
What if i'll camber it, will still have issues? thanks again..
Old 04-08-2013, 11:06 PM   #1138
86pro
Drives: frs
i got a ? Will 17*8 rpf 235 40 17 re11 tires be okay for my turbo power. I should get wider back rims ad tires shouldnt i? Just have stock suspension for now. I need help because even tire rack said the 245 could fit but i dont want to sacrifice handling at all.
86pro is offline   Reply With Quote
Old 04-08-2013, 11:18 PM   #1139
kidgogeta
Drives: FRS
got a question about the 57 extremes, would 18x9.5 +40 all round fit (don't like the flat look up in the front) with a 235 tire? or would you guys go 8.5 up front? mostly using it as street, but i do want it to retain handling as much as i can
I'm thinking about lowering it with RCE yellow too, would it all work?
kidgogeta is offline   Reply With Quote
Old 04-08-2013, 11:19 PM   #1140
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
^ what he said. Excellent reply.
ill86 is offline   Reply With Quote
Old 04-08-2013, 11:21 PM   #1141
ill86
ill86's Avatar
Drives: iG FR-S
You'll be fine with 235 or 245.
If it was my FRS and I was putting on a turbo kit i would go even bigger. Personal preference really. Your right foot, tire compound and LSD will dictate the traction issues.
Old 04-08-2013, 11:22 PM   #1142
ill86
ill86's Avatar
Drives: iG FR-S
9.5 is kinda pushing the limit up front. You'll be flush if not poking depending on alignment.
Old 04-08-2013, 11:27 PM   #1143
86pro
Drives: frs
Thanks im just on budget and these rims i had got before i bought turbo. Do you think the 245 all around with sticky tires be good for track or grippy cornering? I know over steer will be there but i still want to be safe. Dont want to always be sideways. got 2way lsd
Old 04-08-2013, 11:30 PM   #1144
kidgogeta
Drives: FRS
so 8.5 up front and 9.5 in the rear will be fine, what size tires would you recommend? and do you think the RCE yellow would be good for a slight drop?
Old 04-08-2013, 11:32 PM   #1145
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Anyone running a 10" rim up front with a higher then 35 offset?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-08-2013, 11:58 PM   #1146
ill86
ill86's Avatar
Drives: iG FR-S
You're welcome. 245 all around with a YH ADVAN AD-08 (my preference) would do well. It all comes down to how you are driving it though. :-). 2 way LSD would certainly help. Doesn't sound like you are on a small budget. :-) :-) turbo, 2way, haha just messin.
How much whp and what rpm max torque/boost? Lots of add'l factors. PM me rather than go off topic here, please.
Old 04-09-2013, 12:00 AM   #1147
ill86
ill86's Avatar
Drives: iG FR-S
I have no first hand experience with RCE on the 86, but have rode along instructing clients that have in other machines. I feel confident you will like the product. Your decision, bro.
Edit - re: tires
What diameter wheel?
Otherwise,
F, 235-245
R, 245-265
Old 04-09-2013, 12:08 AM   #1148
bryzter
anyone know what wheel and tire setup for this?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
