| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1135 |
Drives: 2005 BMW 3 series / 2013 Scion FRS
Hi All.. will i have issues when i run 255/35/18 (rear) +35 offset with 25mm spacer and 225/40/18 (front) +35 offset with 25mm spacer? thanks
#1136 | |
Drives: FR-S Firestorm 6MT
You didn't specify the wheel width but with a 10 offset it doesn't matter. Leave the spacers off and you'll probably be fine. |
#1137 |
#1138 |
Drives: frs
i got a ? Will 17*8 rpf 235 40 17 re11 tires be okay for my turbo power. I should get wider back rims ad tires shouldnt i? Just have stock suspension for now. I need help because even tire rack said the 245 could fit but i dont want to sacrifice handling at all.
#1139 |
Drives: FRS
got a question about the 57 extremes, would 18x9.5 +40 all round fit (don't like the flat look up in the front) with a 235 tire? or would you guys go 8.5 up front? mostly using it as street, but i do want it to retain handling as much as i can
I'm thinking about lowering it with RCE yellow too, would it all work? |
#1140 |
VehicleDynamicsSpecialist
Drives: iG FR-S
#1141 | |
Drives: iG FR-S
If it was my FRS and I was putting on a turbo kit i would go even bigger. Personal preference really. Your right foot, tire compound and LSD will dictate the traction issues. |
#1142 | |
Drives: iG FR-S
#1143 |
Drives: frs
Thanks im just on budget and these rims i had got before i bought turbo. Do you think the 245 all around with sticky tires be good for track or grippy cornering? I know over steer will be there but i still want to be safe. Dont want to always be sideways. got 2way lsd
#1144 |
Drives: FRS
#1145 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Anyone running a 10" rim up front with a higher then 35 offset?
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#1146 | |
Drives: iG FR-S
How much whp and what rpm max torque/boost? Lots of add'l factors. PM me rather than go off topic here, please. |
#1147 | |
Drives: iG FR-S
Edit - re: tires What diameter wheel? Otherwise, F, 235-245 R, 245-265 |
#1148 |
anyone know what wheel and tire setup for this?
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
