Old 04-08-2013, 11:55 AM   #155
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by Cadenz View Post
So the Greddy SP Elite does not overwhelm the sound of the TRD intake? Actually did the SP Elite overwhelm the stock sound tube in general? I tried on a Works AB-M and I couldn't hear the engine noise, below 4k rpm, coming through the sound tube anymore.
The GReddy SP does NOT overwhelm the TRD intake sound. The SP Elite somewhat overwhelmed the sound tube but I had the most aggressive TRD red sound changer on and could hear it if I listened for it. It'd probably overwhelm the stock sound changer, though.
I believe GReddy is known to be one of the quieter exhausts which might be a reason many owners have been selling theirs.
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
Cadenz (04-08-2013), Sargy (04-10-2013)
Old 04-08-2013, 02:40 PM   #156
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Anybody done any EcuTech logging on this yet?
tripjammer is offline   Reply With Quote
The Following User Says Thank You to tripjammer For This Useful Post:
acro (04-08-2013)
Old 04-08-2013, 03:13 PM   #157
bigjake
Drives: 2013 Scion FR-S, Firestorm
did you sell the takeda yet
bigjake is offline   Reply With Quote
Old 04-08-2013, 03:44 PM   #158
JMPoole
Drives: '13 BRZ LTD
Yep. No noticeable gain in volume but no loss either. However I didn't think to look at the times in the chart or in other words how quickly the volume was reached in comparison. I think I posed the question in another post but has anyone done before and after logs on any of the intakes?
JMPoole is offline   Reply With Quote
Old 04-08-2013, 05:07 PM   #159
tripjammer
tripjammer's Avatar
What was your volume?
Old 04-08-2013, 08:04 PM   #160
JMPoole
Drives: '13 BRZ LTD
I'll look when I get back to work tomorrow.
The Following User Says Thank You to JMPoole For This Useful Post:
tripjammer (04-08-2013)
Old 04-10-2013, 12:35 AM   #161
tripjammer
tripjammer's Avatar
Hey bro any new info?
Old 04-10-2013, 08:39 AM   #162
JMPoole
Drives: '13 BRZ LTD
I didn't drive the car for the last couple of days but I'll try to get some info today. Shop's pretty busy right now, no time for fun.
tripjammer (04-10-2013)
Old 04-10-2013, 09:34 AM   #163
Red2Liter
Drives: Subaru BRZ Limited, Red
TRD CAI Filter Size
Originally Posted by Mars2 View Post
what is the size of the filter?
Got the TRD CAI yesterday and I'll install tomorrow. I don't have access to a dyno and really don't care that much. The TRD install is much cleaner; eliminating a whole lot of plumbing. They do leave the vestiges of the lower sound-tube plumbed into the firewall, but cap it off, making reverting to the stock set-up easy.
The filter looks like a custom K&N filter built for the large box; stainless steel supporting a cotton, washable filter medium that's 15.5 X 4.75 inches. They recommend using the K&N wash & re-oil kit. That's 73.6 sq. inches of filter surface.
Kit comes with several pages of install instructions, w/photos and all the fittings required. Some of the OEM fittings & bolts are reused, so don't throw them out. Also don't forget to disconnect the battery to reset the ECU and then log some miles on the reset ECU before making any comparisons with the stock set-up.
We're installing a set of braided brake lines tomorrow and servicing the brakes while we're in there. I'm hoping to get a firmer pedal with that mod. It's all about the TOTAL car. I'll have more to report after I've driven it for a while. In time, I'll go to stickier rubber when I've worn out the OEM Michelins and I may go to slightly bigger brakes when they need replacing.
Red2Liter is offline   Reply With Quote
The Following User Says Thank You to Red2Liter For This Useful Post:
Old 04-11-2013, 06:30 AM   #164
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Have to agree there. A 2nd gear pull from 4.5k-7krmp sounds very nasty. Very much an aggressive growl.
Originally Posted by switchlanez View Post
I don't miss the sound tube at all. The idea of removing a few pounds of excess piping makes it easier to dimiss. The intake sound does compensate for it. It makes a snarling sound similar to the red TRD sound changer I had on my sound generator, just a bit more muffled/less direct. Oh yeah, that's another thing. Seems like it has a slight raspy growl whereas my Takeda was a [louder] continuous boom.
"This isn’t about specifications or numbers but a cultural phenomenon."
-Moto-P
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
tripjammer (04-11-2013), uspspro (04-23-2013)
Old 04-11-2013, 12:51 PM   #165
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
SO it's about 58-59% increase fllter area. Not bad!
Would like to know what is the length and diameter of Perrin filter to calculate area of it.
Mars2 is offline   Reply With Quote
Old 04-11-2013, 03:43 PM   #166
Red2Liter
This is what I've posted also in the thread--TRD, CAI. I'm happy with the item in question and I'm not going to debate or flog this dead horse further. I hope that what I've added to both these threads some folks find usefull!
OK, We installed the TRD CAI on the BRZ this AM. The instructions and parts were all quality and the install required about 25 minutes. Some hardware from the OEM CAI were used in the install. The original MAF sensor is simply moved to the new airbox. If you look at your engines I believe the covers say both Toyota and Subaru; I doubt that you will encounter any crap from your dealer on warranty issues
Note: this was included in the instructions___
" If your state requires an Emissions Compliance Label, one may be ordered through your Scion dealer or the Toyota Materials Distribution Center (MDC) 310-468-9800 or MDC@toyota.com"
Also: "This TRD Performance Air Intake Kit has received 50-State Emissions Compliance via the California Air Resources Board (CARB). Not all states require the Emission Compliance Label for this TRD Performance Air Intake Kit, please order MDC part number 00602-21140. Proof of ownership may be required."
Next up---I do not have access to a dyno. I am 71 years-old and have been an SCCA licensed driver as well having driven a variety of performance machinery my whole life. It's my opinion that the TRD CAI has dramatically improved the low-end torque. When I roll on the throttle I'm getting a nice seamless torque response throughout the RPM range, where the OEM setup was peaky at best. All of the OEM system is removed except the last little bit of the sound tube, which is blocked off with a cap. The cabin is slightly less noisy, I can now hear the injectors clicking (a common Subaru trait). The engine now sounds like an engine; lovely, smooth mechanical sounds instead of that "artifical sound-tube." There is no "magic" bullet to increase horsepower without spending cubic dollars. Subaru and Toyota have equipped these cars with technology that was common only to real racing cars not so many years ago. My goal has been to enhance my BRZ with practical additions that increase my driving pleasure and enjoyment. The only other items I've added were a master cylinder brace and braided stainless brakelines. These enhancements have produced a much firmer pedal that reminds of race cars I've driven. Now I'm going to enjoy driving the car and "learning" to get the most out of it with what skills I still have.
The Following 6 Users Say Thank You to Red2Liter For This Useful Post:
Cadenz (04-11-2013), CamryDS (04-30-2013), RazBRZ (04-11-2013), roddy (04-11-2013), switchlanez (04-13-2013), tripjammer (04-11-2013)
Old 04-22-2013, 11:56 PM   #167
tomkozski
Drives: 2017 WRB BRZ w/ PP
Motor Trend on their long-term test blog has videos comparing before/after sounds of their FR-S after it received the TRD intake and exhaust mods.
Videos are at the bottom of the article here: http://wot.motortrend.com/2013-scion...re-351939.html
tomkozski is offline   Reply With Quote
The Following User Says Thank You to tomkozski For This Useful Post:
Lonewolf (04-23-2013)
Old 04-23-2013, 12:21 AM   #168
Lonewolf
Lonewolf's Avatar
Drives: Moped
Damnit, the crickets even overwhelm the intake sound...
2013 Long Beach Pro Celebrity Race Specification FR-S Preview. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 58 04-13-2013 09:36 AM
Tuned Scion FR-S Chosen as Next Toyota Pro/Celebrity Race Car for Long Beach GP Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 03-07-2013 04:25 PM
Cerritos/Long Beach ggpaul Southern California 12 11-12-2012 07:53 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
First 86 Long Beach Last Supper fieryhooligan Scion FR-S / Toyota 86 GT86 General Forum 1 04-09-2012 05:47 PM
