Old 04-05-2013, 04:24 PM   #15
cregor
cregor's Avatar
Drives: Whiteout Scion FRS
Lemon Law is probably your best bet but requires some work on your end.
You will need to find how the Lemon Law is applied in your state, but I can give you an example of how it works in Texas.
In Texas after you have had repeated repair attempts (2 repair attempts in 12 months or 12,000 miles) for the "SAME" issue you have to send a Certified Mail, Return Receipt Request letter that gives them 30 days from the day they receive the letter to fix the problem. If they are unable to do, so they are legally obligated to repurchase the car or provide a replacement.
Here is a link to a sample letter:
http://ftp.txdmv.gov/pub/txdot-info/...mpleletter.pdf
If you read the letter you will note that it puts the ball in their court and informs them that you are ready to take legal action. One of three things typically happens:
  • They freak out because they realize you are serious and get their best technician to work the problem until its fixed, so they don't have to buy your car back. (Not really what you want, but at least you get your car fixed)
  • They freak out and put their best tech on it, but he can't fix the problem, so they buy your car back or you get a replacement.
  • They call your bluff and blow you off hoping that you won't get a lawyer. A lawyer armed with a letter like this will destroy them in court.
Side note: If you think the dealerships technician are incompetent, be sure that you send the letter to them and let them make a final attempt to repair, because if they can't figure it out, you get a new car!
P.S. Sorry that you are having so much trouble with your new car.
cregor is offline   Reply With Quote
Old 04-05-2013, 07:49 PM   #16
fred864
Drives: brz/fr-s
Okay I will take a look at it. But the technicien are not able to even find the issue! So they are definitively not able to fix it. But do you know what is the actual delay after a final attempt to change the car or take other actions? Because I have dozen of work order from my dealer that states that they don't find it and to wait because they don't want to repair.
fred864 is offline   Reply With Quote
Old 04-05-2013, 08:21 PM   #17
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
If the same issue happens to the same part in the car 3 times then the lemon law is in effect and they have to replace the vehicle
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
Old 04-06-2013, 01:36 AM   #18
fred864
Drives: brz/fr-s
Yes but I believe this is only true in the US, not in the canada side. I don't think there is a law like that! I have been looking for it for the entire night and coulnd find it!
Old 04-06-2013, 01:33 PM   #19
cf6mech
Drives: FRS Silver LS1 swapped.
Drive it into a lake,.....then report it stolen. Only half kidding,....I actually had a friend do this going through what your going through,....that was the level of frustration he was in......it worked btw, insurance picked up the tab.
cf6mech is offline   Reply With Quote
Old 04-06-2013, 02:15 PM   #20
jamesm
So what exactly is wrong with the car now that would necessitate giving you a whole new one? Sounds like it has a couple rattles after having been taken apart for a repair. What was the 'speaker grill appearance' issue? Are there driveability issues I'm missing or something?
The Following User Says Thank You to jamesm For This Useful Post:
Joeprelude (04-08-2013)
Old 04-08-2013, 12:34 AM   #21
fred864
Drives: brz/fr-s
The issues are all listed above! There are many rattlers in fact that my dealer is not able to locate and repair. Well they are not trying to much! There were drivisbility issue, I had an ECU breakdown the car would not even accelerate. The soeaker grill was just constantly popping out, nothing major there but just an additional problem. I am just tured of this because I am in the garage every week!
Old 04-08-2013, 02:28 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
So no current drivability issues? Your temp and window issues aren't well defined in your post.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-08-2013, 08:11 AM   #23
fred864
Drives: brz/fr-s
I can't describe the temp problem more subaru have no idea of the problem. The radio was just saying abnormal temp.Yes the car is driveable but it is not fun to drive since there are to many problem and the rattles everywhere are very annoying!
Old 04-08-2013, 04:57 PM   #24
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Every subaru I have ever owned has rattles. I know it doesn't help you, but I'm just saying..
Ranatsu is offline   Reply With Quote
Old 04-08-2013, 08:49 PM   #25
fred864
Drives: brz/fr-s
Maybe but it is absolutely not normal to add some when you repair/change a part on the car!
Old 04-09-2013, 09:08 AM   #26
cregor
cregor's Avatar
Actually this is very typical, when they are removing panels looking for rattles, they often break clips or other plastic pieces and instead of fixing them they just put the panels back on. Can't tell you how many times I have had one rattle fixed only to have the dealership create two new ones.
Old 04-10-2013, 05:05 PM   #27
fred864
Drives: brz/fr-s
Yess i know that, I jave alteady told them to change the broken clips are plugs and they will do it they said. Because now since the played in the door for the window problem I have have some rattles in the driver door. As well as in the dash and the back area of the car. In conclusion rattles everywhere!
Old 04-17-2013, 02:40 PM   #28
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
What was your "Major Window Issue"? If you don't mind me asking.
N_I_N is offline   Reply With Quote
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 09:08 PM
**IMPORTANT** Sand in the engine block USMC FR-S Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2013 08:44 PM
Another top ten list. Most important cars of the year by Jalopnik - #2 this time. dawnst3ar Scion FR-S / Toyota 86 GT86 General Forum 16 12-15-2012 05:50 AM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 11:25 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 06:53 PM
