Old 04-05-2013, 05:45 PM   #197
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by norm24 View Post
^ Thanks for the info. Now, how do we find out if the hardware is in the ECU???
I should have some time this weekend to look at it. Plug in some fuses and probe the pins to see if they output some power.
I swear I remember seeing a white/red wire already in that connecter. If so It may be really simple.
I also distinctly remeber hearing a relay clicking in the Body ECU area when I turned on the the fog lights so that could be the fog light relay. Hoping so.
FRSFirestorm is offline   Reply With Quote
The Following 4 Users Say Thank You to FRSFirestorm For This Useful Post:
civicdrivr (04-05-2013), norm24 (04-05-2013), PANDA86 (04-07-2013), PatGT86 (04-05-2013)
Old 04-05-2013, 06:02 PM   #198
PatGT86
Drives: 2013 Raven Scion FR-S
Looking forward to your findings!!
Keep us posted
PatGT86 is offline   Reply With Quote
Old 04-05-2013, 06:08 PM   #199
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
FRSFirestorm,
Oh, Man. I've a Nobel prize in Automotive Engineering with your name on it if you can actually verify and confirm all the above.
That would be a huge discovery, as I suspected all along that a relay already exists as part of the ECU.
This is not a hollow promise, I'm an R&D Engineer\Scientist Manager with the Corps of Engineers, so the least I could do is to send you a token of appreciation medal!
Zagmeister is offline   Reply With Quote
The Following User Says Thank You to Zagmeister For This Useful Post:
FRSFirestorm (04-07-2013)
Old 04-05-2013, 08:41 PM   #200
FRSFirestorm
Red is Fastest
Originally Posted by Zagmeister View Post
FRSFirestorm,
I'm an Automotive ME Knowledge is power, all it takes is the time investigating the schematics. The key was printing the dang manual. Couldn't follow things and trying to scroll through the PDF document.
I am 99% positive the relay is in the ECU. Before driving home I turned on the headlights which would have turned on the parking like relay on the ECU. Turning on and off the fog lights I could certainly hear another relay. I'm betting right now that the internal hardware and circuitry is there.
Old 04-05-2013, 09:11 PM   #201
FRSFirestorm
Red is Fastest
I've not actually probed the wires. My probe is at work.
10A fuses are already in the proper slots. FROM THE FACTORY
The white/red and red/white wires are already in the connector. FROM THE FACTORY
This really could be very simple.
The Following User Says Thank You to FRSFirestorm For This Useful Post:
Old 04-05-2013, 09:41 PM   #202
FRSFirestorm
Red is Fastest
Picture of the wiring. Connector bottom left. Count up 3 slots then to slot 5.
And they ouptut voltage with the fog light switch on and don't when the switch is off. The hardware is in the ECU and functions!
With the switch on.
Worst case you tap into the wiring here but they have to have another end somewhere and I'm betting its under the hood. Finding them is the next task.... back to the manual.
This is tooo easy!
The Following 5 Users Say Thank You to FRSFirestorm For This Useful Post:
civicdrivr (04-05-2013), kmbkk (04-06-2013), norm24 (04-05-2013), OmarGC (04-05-2013), zooki (04-06-2013)
Old 04-05-2013, 10:15 PM   #203
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Quick question: if this is indeed true would we still need to ground the wiring at the stalk if we changed that out?
kmbkk is offline   Reply With Quote
Old 04-05-2013, 10:20 PM   #204
FRSFirestorm
Red is Fastest
No, just plug up the stalk. Don't do anything with the white wire running in that circuit. When you turn the switch on the stalk it grounds that circuit and energizes everything. You get fused power out of the white/red red/white wires I have pictured above and the indicator light in the dash.
You don't need any more relays. Just tap into these wires and run them to each individual fog light. Ground the lights somewhere near them.
Old 04-05-2013, 10:43 PM   #205
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Awesome, thanks! I've got the EDM stalk on order, so this is good news indeed. Once. Get it installed ill have to investigate the rear fog light wiring.
Old 04-05-2013, 10:44 PM   #206
Sco2355
Wouldn't happen to have the part number to share do you?
Sco2355 is offline   Reply With Quote
Old 04-05-2013, 11:24 PM   #207
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I wish I did, but I wasn't given it, and I asked. I'll pass it along as soon as I get it, though.
The Following User Says Thank You to kmbkk For This Useful Post:
Sco2355 (04-06-2013)
Old 04-05-2013, 11:27 PM   #208
FRSFirestorm
Red is Fastest
May have found the wires. I'm gonna have to hit the auto parts store or stop by work and pick up a wire probe. Not going to cut into the harness until I'm sure these are the right wires. According to the schematics/wiring manual they should be run to this area. Right next to the fog lights.
civicdrivr (04-06-2013)
Old 04-06-2013, 12:01 AM   #209
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You sir, are a scholar and a gentleman.
I'm curious as to where the two wire terminate though.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Old 04-06-2013, 02:19 AM   #210
Retro86
Retro86's Avatar
Drives: Awesome
Holy shiiiii!!!! thank you for this!!! good thing i only got the stalk installed. i was ready and gonna install the rest this weekend, good timing guys!! thank you thank you
okay im on stand by!
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
