Old 04-05-2013, 10:06 AM   #29
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by firl21 View Post
So i was doing some digging around and I found out that the TS of the frs is 125, and its drag limited. That doesn't seem right. My 02 es300 would hit 140 Drag limited, it was heavier, rode higher, and had less horses. How does the frs not go faster? What can I do to make it go above the 125 mark. I plan on tracking mine. Im assuming droping the car with coilovers, adding a spoiler for down-force, and just pushing the engine with a turbo/charger.
Am I correct in my assumptions?
Step 1
Step 2, Dash says 125
step 3
Step 4
You dug Incorrectly
There are electronic limiters in the rom that can be changed to suit whatever you want. I think by default the US limiter is around 140 - 145 area. It will be based on the speed rating of the stock tires.
Old 04-05-2013, 10:55 AM   #30
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
When I was younger and more stupid I took my Evo up to 150 and then slammed the brakes hard.
They made quite a lot of noise after that.
That was 7 or so years ago.
Chewie4299 is offline   Reply With Quote
Old 04-05-2013, 11:16 AM   #31
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
I think mines limited to 88mph... Every time I hit it I see a flash of light and end up in 1955 :/
Narcoden is offline   Reply With Quote
The Following 5 Users Say Thank You to Narcoden For This Useful Post:
BigJyoungblood (04-07-2013), Blighty (04-08-2013), cuddefred (04-05-2013), JiB (04-07-2013), usptwins (04-05-2013)
Old 04-05-2013, 11:17 AM   #32
2forme
Bring me back some baseball cards next time you go.
Old 04-05-2013, 11:22 AM   #33
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Originally Posted by Gixxersixxerman View Post
On a closed road mine did 142..
142 at the end of 5th gear?? I redline fifth gear and I'm only doing 126... Please explain the difference
I'll be back!!
F3dzo is offline   Reply With Quote
Old 04-05-2013, 11:43 AM   #34
firl21
Drives: Scion FRS in hot lava
Im more surprised he is getting 28.7 MPG going 140
firl21 is offline   Reply With Quote
The Following 2 Users Say Thank You to firl21 For This Useful Post:
2forme (04-05-2013), eddieEndo (04-05-2013)
Old 04-05-2013, 11:58 AM   #35
CSG Mike
CSG Mike's Avatar
Our car has seen 147mph (GPS verified).
Random factoid: Cruise control is capped at 90mph. You can "set" it at higherspeeds , but it'll bring you down to 90mph. It's finicky and at over 100, it won't necessarily even "set".
tripjammer (04-05-2013)
Old 04-05-2013, 11:59 AM   #36
CSG Mike
CSG Mike's Avatar
Manual vs auto. Gearing in the auto is different
Old 04-05-2013, 12:04 PM   #37
HunterGreene
Hail Magnet
HunterGreene's Avatar
Well, there you go. I learned something today.
Old 04-05-2013, 12:13 PM   #38
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
THIS!!
Don't even bother shifting into sixth with the auto!
Scott
naikaidriver is offline   Reply With Quote
Old 04-05-2013, 02:41 PM   #39
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by 2forme View Post
Misfire above 7300, I think it's a bad coil.
I'm gonna swap the coil from cylinder 4 to 3 to see if it follows. If not, then I'll replace the plug. I just got to sears to pick up the AXESS sockets to make my life easier LOL.
So that is the key to getting the coils and plugs out eh. Let me know which ones you get and how well they work.
Old 04-05-2013, 02:49 PM   #40
mad_sb
Ahh... I think i may have seen that limiter in the stock rom too and just assumed it was not actively used for anything... I'll have to go look again and see. Although I not sure i would ever need to set the cruise higher than 90 lol
Old 04-05-2013, 02:52 PM   #41
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I redlined fifth at around 130 and it's manual
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 04-05-2013, 03:08 PM   #42
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Anybody try top speed after getting an EcuTek tune with your redline raised to 7800 RPM or higher?
tripjammer is offline   Reply With Quote
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
What speed have you taken your 86 too Ryan86 AFRICA 52 04-16-2013 02:45 PM
Need For Speed... Really? Texas BRZ Tracking / Autocross / HPDE / Drifting 61 01-11-2013 11:59 PM
Top Speed L3P47 Scion FR-S / Toyota 86 GT86 General Forum 6 12-18-2012 12:06 AM
D-SPEED ANREX Cosmetic Modification (Interior/Exterior/Lighting) 2 10-29-2012 07:47 AM
