Old 04-03-2013, 02:02 PM   #15
ft_sjo
Drives: GT86
If you don't go ITB's or carbs then you're unlikely to have any gain by porting the heads further.
Old 04-03-2013, 02:04 PM   #16
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Every cylinder head I have seen has always had tons of room for improvement. I don't see why the FA20 would be any different.
NomoreNA is offline   Reply With Quote
Old 04-03-2013, 02:20 PM   #17
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
That's a pretty broad stroke.
Do you now, or have you ever done head work for a living?
Scott
naikaidriver is offline   Reply With Quote
Old 04-03-2013, 02:26 PM   #18
cplabaunza
Could try milling the heads also while your at it for higher Compression Ratio if you plan on staying NA
*Red 2014 SRT Viper GTS
*Whiteout 2013 Scion FR-S(SOLD)
*Cyber Grey Metallic 2012 Chevrolet Volt(SOLD)
*Black 2010 Victory Cross Country
*Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6(SOLD)
cplabaunza is offline   Reply With Quote
Old 04-03-2013, 02:29 PM   #19
swift996
swift996's Avatar
That with some more aggressive cams (and supporting valve-train) would be nasty. It's just a lot more difficult compared to an inline engine because you have 2 heads and need to remove the engine. So it's going to be costly, but I'm waiting to see someone do this!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-03-2013, 05:03 PM   #20
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Scott
Yes I have done cylinder head work on everything from domestics to pro street drag bikes. I am also a lead machinist for a dev team that was recently blessed with the task of designing the worlds most efficient natural gas turbine.
Old 04-03-2013, 05:19 PM   #21
naikaidriver
Well, I was just a simple, part-time, "tuner" 20 years ago that worked in a small shop working on engines for drag cars. Nothing like your resume obviously.
I guess I will just shrug and walk off.
Scott
Old 04-03-2013, 06:30 PM   #22
FirestormFRS
Porting and polishing will make obviously make the air flow more efficiently if done correctly. Just not sure you'll move a large enough amount of air to get the type of gains you're looking for. Cost vs. reward just isn't going to work out imho.
FirestormFRS is offline   Reply With Quote
Old 04-03-2013, 08:03 PM   #23
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
What would the horsepower gain vs cost be? Prohibitive!
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 04-03-2013, 10:21 PM   #24
mswhong
Drives: FT86
Originally Posted by Hawk77FT View Post
How about doing just the ports? cyl head - intake and exhaust, and intake manifold, and exhaust. The intake is plastic? WTF?
There's heaps of cars being made recently with plastic manifolds.. i assume this is to prevent heatsoak from a metal manifold.
mswhong is offline   Reply With Quote
Old 04-03-2013, 10:42 PM   #25
swift996
swift996's Avatar
Cost and weight are usually the drivers with plastic. Cars will become more and more plastic base as fuel economy regulations take place.
Old 04-04-2013, 08:25 AM   #26
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by dwx View Post
The intake manifold is plastic so good luck with that one.
Extrude hone.... assuming the runners are smaller than the ports of course.
@Hawk77FT you are talking about a huge investment of cash and down time. The motor has to be pulled out, torn down, put back together, and re installed.. not to mention the cost of the actual PNP work, which will cost a good bit if your going with a reputable head-work shop.
Probably the lest gains per dollar you could do at this point in time. If the motor were going to be out for some other reason and torn down... then sure go ahead.
You would be far better off (power per dollar) to just do a supercharger kit. Probably cost about the same or even less as well.
I'm sure it won't be long before we have aftermarket exchange parts available (pre ported and built heads, cams in various profiles, intake manifolds) as well as modified stock parts. At that point the whole idea becomes more feasible imo since the skilled and dedicated DIY guys could then pull the motor and have it back in and ready to tune in a single weekend.
The Following User Says Thank You to mad_sb For This Useful Post:
Hawk77FT (04-04-2013)
Old 09-25-2013, 11:52 AM   #27
oldeskewltoy
dedicated enthusiast
oldeskewltoy's Avatar
Drives: Surreptitious(AE71), & Grunt(AE95)
I've got a flowbench........
4AGE
7MG
I just need an FA20 head - http://www.ft86club.com/forums/showthread.php?t=47375
Oh... btw.... there is some inaccuracies.... the smoothness of the ports surface for one..... when you have a carburtor, or T/B injection where the air and fuel are mixed before the head... then I more or less agree that a "textured" surface (80 grit) helps keep the air and fuel atomized.... but the FR-S has a mixture of injection system...neither of which has the air and fuel mixing before the head.... so the ports in an FA20 head should be a lot smoother... (200 grit)
Exhaust ports should be as smooth and reflective as possible....
4AGE exhaust port - before and after.......
Information is POWER - LEARN the facts!
oldeskewltoy is offline   Reply With Quote
The Following 4 Users Say Thank You to oldeskewltoy For This Useful Post:
Dimman (09-25-2013), flippy (09-26-2013), Lonewolf (12-16-2021), mad_sb (09-25-2013)
Old 09-25-2013, 12:12 PM   #28
rusty959
Drives: DGM BRZ limited
4AGE
7MG
I don't understand how a port injector isn't mixing fuel before the head.
rusty959 is offline   Reply With Quote
What did you wash/shine/polish/wax today? tuckdaddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-04-2013 07:42 PM
Glass polish? SubarooMike Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 11-08-2012 01:33 PM
Port and polish? Extrude hone? mrha Southern California 0 07-11-2012 09:54 PM
Saving / Re-using polish and waxing supplies? eikond Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-25-2012 04:25 PM
