#15 | |
Drives: N/A
Because E85 is pump gas, there's no reason they shouldn't allow it. |
#16 |
Drives: 2013 FRS Asphalt
I can run e85 with the ecu flash... I can not run the flex fuel kit because the kit takes you out of the class.
2013 Scion FR-S AT Picked up 5/30/2012
#17 |
Grip>Slip
#18 |
Drives: N/A
That's ridiculous. It's just new fuel lines and a sensor!
#19 |
Scca STX. Also this year is the only year I can run it. Next season I wont be able to run it if they have there way.
#20 |
Drives: WRB BRZ limited 6MT
It defaults to the stock 1 map. But some cars remember the last map they were on. Its a bug in those cars. But Ecutek or John will figure it out...
#21 |
Drives: ex500r
How would they even know you had a ecutek tune?
#22 |
Hold the cruise control stock in to see if you can change maps.
Sent from my SCH-I535 using Tapatalk 2 |
#23 |
Grip>Slip
#24 |
First86 / boat thief
Drives: MKIV Supra
E85 has 1/3 less energy than normal gas.
So when running 85 you must add 1/3 more fuel. The higher octane rating of E85 and the cooling effects of more fuel per part of air combine to allow you car to add timing and make some more power (a lot in turbo cars). So Driving on E85 tune with regular gas = very rich not the end of the world. At full throttle you could start to wash your cylinders and kill your O2 censer and cats but this will take time. Driving on Regular tune with E85 in the car is bad you are running very lean but should be fine if you don’t stress the motor. At full throttle could detonate bad enough to kill motor. |
#25 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
look like it depend how I switch it on. Here in France we have the switch button no Key. |
| BEspoke question and rattle question | bdanisi | Electronics | Audio | NAV | Infotainment | 2 | 01-30-2013 02:11 PM |
| Oil question.. | tintumz22 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 01-13-2013 12:41 PM |
| mpg question | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-10-2012 01:40 PM |
| TCS/VSC question. | Cheddar | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-10-2012 08:29 PM |
| Question for BRZ and GT-87 hps? | west2k95 | Scion FR-S / Toyota 86 GT86 General Forum | 276 | 03-13-2012 10:45 PM |
